PART CODE:
RA12M00000L100
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
N0504-RA12M00000L100
DATE
May 04, 2021
REVISION
A0
DESCRIPITION
MHz Thru-Hole Crystal Oscillator, L20.8*W13.2*H5.08mm
Full- Size/14 pin, CO14 series
12.00000MHz, 5.0V, +/-50ppm, Symmetry 45/55,
Operating Temp. Range -40°C ~+85°C,
HCMOS//50pF, Supply Current 10mA Max, Tristate function - Enable
Thru-Hole type, Packed in Tube, 25pcs/Tube
RoHS/RoHS III compliant
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
TGS CO1451BGI05 BLF−12M000
PART CODE
RA12M00000L100
VENDOR APPROVE
Issued/Checked/Approved
DATE: May 04, 2021
CUSTOMER APPROVE
DATE:
NextGen Components, Inc.
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
RA12M00000L100
MHZ THRU-HOLE CRYSTAL
SMD CRYSTAL
OSCILLATOR
2520 CO14
TYPE 4SERIES
PADS
MAIN FEATURE
• MHz Thru-Hole Crystal Oscillator L20.8*W13.2*H5.08mm
• Industry-standard
• Hermetically sealed package for reliability
• Tristate function -Disable
• Cross more competitors part
• RoHS/RoHS III compliant
APPLICATION
• Communication Electronics
RFQ
PART CODE GUIDE
Request For Quotation
RA
12M00000
L
001
1
2
3
4
1) RA: Part family Code for MHz Thru-Hole Crystal Oscillator, L20.8*W13.2*H5.08mm, Full-Size/14 pin, CO14 series
2) 12M00000: Frequency range code for 12.0000MHz
3) L: Thru Hole type, Packed in Tube, 25pcs/Tube
4) 100: Specification code for original part No.: TGS CO1451BGI05 BLF-12M000
MORE FREQUENCY RANGE AVAILABLE (MHz)
2.0480
20.000
24.000
25.000
27.000
40.0000
48.000
50.000
100.00
125.000
PART CODE:
RA12M00000L100
MHZ THRU-HOLE CRYSTAL OSCILLATOR CO14 SERIES
DIMENSION (Unit: mm, Tol. +/-0.15mm)
Image for reference
Marking
Line 1: 12.0000
Line 2: Special Code
CO14
Pin Function
#1 Tristate Enable Via #1
#4 Ground
#5 Output
#8 VDD
Circuit Principle
RA12M00000L100
PART CODE:
ELECTRICAL PARAMETERS
Parameter
Part No.
Symbol
Units
Value
Min.
Original Manufacturer
Holder Type
Typical
Condition
Max.
TGS
TGS Crystals
CO14
MHz Thru-Hole Crystal Oscillator, CO14 Series,
Supply Voltage
5
Enable/Disable -Tristate
Function
1
Overall Freq. Tolerance
B
ppm
-50
+50
G
°C
-40
+85
°C
-55
+125
45
55
V OH
V
90%
V OL
V
Load
pF
Storage Temp. Range
Symmetry
Output
I
Output Waveform
V
5.0
+/-10%
@ Control via
pin 1
High (Logic “1”)
10%
HCMOS
@OutputLoad
50pF
Startup Time
ms
10
Supply Current
mA
10
Rise/ Fall time
ns
10
Phase Jitter
ps
Others
Low (Logic “0”)
50
05
Aging
@25°C
N/A
ppm/year
@1st year
±3
Package
L
Thru - Hole type, Packed in Tube, 25pcs/Tube
RoHS
Status
LF
RoHS III compliant
Add Value
N/A
Internal
Control
Code *
N/A
Frequency Range
-12M0000
12.0000MHz
Note: 1) Original Part Number: TGS CO1451BGI05 BLF-12M000
2) * Internal Control Code- 2 letter or digits; Blank: N/A
PART CODE:
RA12M00000L100
ENVIRONMENTAL AND TECHNICAL CONDITIONS
Test Items
Test Method And Conditions
Temperature Cycle
Mil-std 883, Method 1010, 10 Cycles -20° C To 85° C
Shock
Mil-std-202, Method 213, Test Condition C
Vibration
Mil-std-202, Method 204, Test Condition A
Resistance To
Soldering Heat
Mil-std-202, Method 210, Test Condition B
Humidity
85% Relative Humidity At 85° C 250 Hours
Gross Leak Test
Mil-std-883, Method 1014, Test Condition C
Fine Leak Test
Mil-std-883, Method 1014, Test Condition A
Terminal Strength
Mil-std-202, Method 211, Test Condition A And C
Moisture Resistance
Moisture Resistance Mil-std 202, Method 106, Omit Step 7b
Solderability
Mil-std-202, Method 208, 95% Coverage
Solvent Resistance
Mil-std-202, Method 2002, Method 215
DISCLAIMER
NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained
herein without notice. No liability is assumed as a result of their use or application. No rights under any patent
accompany the sale of any such product(s) or information
