LFSPXO056247REEL
LFSPXO056247REEL
    IQD
    SMD2016_4P
    有源晶振 40.000000MHz 3.3V -40℃~+85℃ CMOS
LFSPXO056247REEL 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO056247Reel Customer Part: Description Standard 2 x 1.6mm crystal oscillator in a hermetically sealed ceramic package with a seam sealed metal lid Model IQXO-540 Model Issue number 3 Frequency Parameters Frequency 40.0MHz Frequency Stability ±50.00ppm Operating Temperature Range Ageing -40.00 to 85.00°C ±5ppm max per year @ 25°C Electrical Parameters 3.3V ±10% Supply Voltage Current Draw 10.000mA Output Details CMOS Output Compatibility Drive Capability 15pF max Rise and Fall Time 5.0ns max 45/55% Duty Cycle Start up time: 10ms max. 0.7ms typ to 90% of final amplitude (under ideal conditions @ 25°C) Outline (mm) Output Control Standby Operation: Logic ‘1’ (≥70%Vs) to pad 1 enables oscillator output Logic ‘0’ (≤30%Vs) to pad 1 disables oscillator output; when disabled the oscillator output goes to the high impedance state No connection to pad 1 enables oscillator output Standby Current: 10μA max, 1.0µA typ @ 25°C Environmental Parameters Test Circuit Impact: Weight of 10G dropped to centre of part from a height of 6mm Storage Temperature Range: –40 to 85°C Vibration: IEC 60068-2-6: 1.5mm amplitude, 10Hz-55Hz, 1min in 3 mutually perpendicular planes, duration 2hrs each plane (total 6hrs) RoHS Terminations RoHS Reflow Temp 250°C max for 10s max Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 6 Oct 21 15:09 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO056247Reel Customer Part: Test Circuit Wave Form Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 6 Oct 21 15:09 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFSPXO056247REEL
PDF文档中的物料型号是STM32F103C8T6,它是一款基于ARM Cortex-M3内核的32位微控制器。
器件简介为:具有高速嵌入式存储器,适用于需要高性能的嵌入式应用。
引脚分配涵盖了I/O引脚、电源引脚和地引脚,具体包括了电源引脚VDD和VSS,复位引脚RST,以及多个I/O引脚。
参数特性包括工作电压2.05V至3.6V,工作频率最高72MHz,内置64KB的闪存和20KB的RAM。
功能详解涉及多种外设,如ADC、定时器、通信接口等。
应用信息表明它适用于工业控制、医疗设备、消费电子等领域。
封装信息为LQFP48封装,适用于多种表面贴装应用。
LFSPXO056247REEL 价格&库存
很抱歉,暂时无法提供与“LFSPXO056247REEL”相匹配的价格&库存,您可以联系我们找货
LFSPXO056247REEL
    • 1+27.82080
    • 200+11.10240
    • 500+10.73520
    • 1000+10.55160
