LFSPXO054046REEL
LFSPXO054046REEL
    IQD
    SMD2016_4P
    有源晶振 10.000000MHz 3.3V -40℃~+85℃ CMOS
LFSPXO054046REEL 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO054046Reel Customer Part: Description Standard 2 x 1.6mm crystal oscillator in a hermetically sealed ceramic package with a seam sealed metal lid Model IQXO-540 Model Issue number 3 Frequency Parameters Frequency 10.0MHz Frequency Stability ±50.00ppm Operating Temperature Range Ageing -40.00 to 85.00°C ±5ppm max per year @ 25°C Electrical Parameters 3.3V ±10% Supply Voltage Current Draw 4.000mA Output Details CMOS Output Compatibility Drive Capability 15pF max Rise and Fall Time 5.0ns max 45/55% Duty Cycle Start up time: 10ms max. 0.7ms typ to 90% of final amplitude (under ideal conditions @ 25°C) Outline (mm) Output Control Standby Operation: Logic ‘1’ (≥70%VS) to pad 1 enables oscillator output Logic ‘0’ (≤30%VS) to pad 1 disables oscillator output; when disabled the oscillator output goes to the high impedance state No connection to pad 1 enables oscillator output Standby Current: 10μA max, 1.0µA typ @ 25°C Environmental Parameters Test Circuit Impact: Weight of 10G dropped to centre of part from a height of 6mm Storage Temperature Range: –40 to 85°C Vibration: IEC 60068-2-6: 1.5mm amplitude, 10Hz-55Hz, 1min in 3 mutually perpendicular planes, duration 2hrs each plane (total 6hrs) RoHS Terminations RoHS Reflow Temp 250°C max for 10s max Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant Not Applicable Packaging Details Pack Style: Reel Pack Size: 1,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 1 Oct 21 14:58 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO054046Reel Customer Part: Test Circuit Wave Form Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 1 Oct 21 14:58 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFSPXO054046REEL
1. 物料型号:LFSPXO054046Reel 2. 器件简介:这是一个标准2 x 1.6mm晶体振荡器,采用密封陶瓷封装,带有密封金属盖。 3. 引脚分配:文档中未明确提供引脚分配图,但通常晶体振荡器会有电源、地和输出引脚。 4. 参数特性: - 频率:10.0MHz - 频率稳定性:在-40.00至85.00°C下为±50.00ppm - 老化:在25°C下每年最大±5ppm 5. 功能详解: - 工作电压:3.3V ±10% - 电流消耗:4.000mA - 输出兼容性:CMOS - 驱动能力:最大15pF - 上升和下降时间:最大5.0ns - 占空比:45/55% - 启动时间:最大10ms 6. 应用信息:文档中未提供具体的应用场景,但晶体振荡器通常用于时钟信号生成。 7. 封装信息:封装尺寸为2 x 1.6mm,采用密封陶瓷封装,带有密封金属盖。 8. 环境参数:包括冲击、振动和存储温度范围。 9. RoHS合规性:符合RoHS指令2015/863/EU和REACh法规。 10. 包装详情:卷装,符合EIA-481-D标准,每卷1000个。
LFSPXO054046REEL 价格&库存
很抱歉,暂时无法提供与“LFSPXO054046REEL”相匹配的价格&库存,您可以联系我们找货
LFSPXO054046REEL
    • 1+27.82080
    • 200+11.10240
    • 500+10.73520
    • 1000+10.55160
