TLSM-L50HM25ST1-166.666M
    TRANSKO
    SMD7050_6P
    有源晶振 166.666000MHz 2.5V 0℃~+70℃ LVDS
TLSM-L50HM25ST1-166.666M 数据手册
TLSM RoHS Compliant CERAMIC SMD LVDS OUTPUT OSCILLATOR (7.0 x 5.0 x 1.6mm) FEATURES:  HIGH FREQUENCY   ULTRA LOW PHASE JITTER PERFORMACE ENABLE / DISABLE ■ SPECIFICATION 2.5V: 12.000MHz ~ 312.500MHz 3.3V: 12.000MHz ~ 800.000MHz FREQUENCY RANGE FREQUENCY STABILITY OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE RANGE SUPPLY VOLTAGE ± 10% SUPPLY CURRENT LOGIC FAMILY LOAD LEVEL LOGIC ‘1’ (VOH) LEVEL LOGIC ‘0’ (VOL) OUTPUT DIFFERENTIAL OUTPUT VOLTAGE OFFSET VOLTAGE SYMMETRY(DUTY CYCLE) RISE AND FALL TIME (Tr/Tf) START-UP TIME ENABLE (VIH) STAND-BY VOLTAGE DISABLE (VIL) ±15ppm ~ ±100ppm STD: 0°C ~ 70°C, Option: -40°C ~ 85°C (See P/N guide for other options) -55°C ~ 125°C 2.5VDC ~ 3.3VDC 100mA max. LVDS 100Ω (Output - Complementary Output) 1.4VDC typ. 1.6VDC max. 1.1VDC typ. 0.9VDC min. 0.247V ~ 0.454V, 0.350V typ. 1.125V ~ 1.375V, 1.25V typ. STD: 40% / 60%, Option: 45% / 55% 250pS typ. 1nS max. @ 20% / 80% 5mS typ. 10mS max. 0.7 x VDD ≤ VIH ≤ VDD or N/C VIL ≤ 0.3 x VDD ±3.0ppm / 1st year max., ±5.0ppm / 10 years max. AGING @ +25°C ±3°C PHASE JITTER (12kHz ~ 20MHz) 1.0pS max. ■ PACKAGE DIMENSIONS ■ SOLDER PATTERN ■ REFLOW PROFILE Soldering 2.0 6 5 4 170 ±5°C 1.8 150 ±5°C MARKING
TLSM-L50HM25ST1-166.666M 价格&库存
很抱歉,暂时无法提供与“TLSM-L50HM25ST1-166.666M”相匹配的价格&库存,您可以联系我们找货
