LFTCXO075797REEL
LFTCXO075797REEL
    IQD
    SMD-4
    有源晶振 20MHz 3.3V SMD-4
LFTCXO075797REEL 数据手册
TCXO Specification Part No. + Packaging: LFTCXO075797Reel Customer Part: Description Temperature compensated crystal oscillator (TCXO) in a hermetically sealed 3.2x2.5mm SMD package. Model IQXT-220-1 Model Issue number 3 Outline (mm) Frequency Parameters Frequency 20.0MHz Frequency Tolerance ±1.00ppm ±0.28ppm Frequency Stability Operating Temperature Range Ageing -40.00 to 85.00°C ±0.02ppm max/day, ±1ppm max/year Frequency Tolerance: Measurement referenced to frequency observed with TA=25°C, Vs=3.3V and load=10kΩ//10pF, within 30 days after ex-works. Frequency Stability: TA varied across the operating temperature range, measurement referenced to frequency observed with fref=(fmax+fmin)/2, Vs=3.3V. load=10kΩ//10pF and temperature variable speed less than 2°C/min. Ageing: Vs, TA and load constant, measurement referenced to frequency observed with TA=25°C, Vs=3.3V, load=10kΩ//10pF and after 1hr of operation. Supply Voltage Variation (measurement referenced to frequency observed TA=25°C, Vs varied from 3.13V to 3.47V and load=10kΩ//10pF): ±0.1ppm max Load Variation (measurement referenced to frequency observed with TA=25°C, Vs=3.3V and load change=10kΩ//10pF ±5%): ±0.1ppm max Electrical Parameters 3.3V ±5% Supply Voltage Current Draw 5.000mA Current Consumption (@ TA=25°C, Vs=3.3V and load=10kΩ//10pF): 5mA max Output Details Clipped Sine Output Compatibility Drive Capability 10kΩ//10pF Output Voltage Level: 0.8V pk-pk min Noise Parameters Phase Noise @ 25°C (F=10.0MHz, typ): -90dBc/Hz @ 10Hz -120dBc/Hz @ 100Hz -140dBc/Hz @ 1kHz -145dBc/Hz @ 10kHz -148dBc/Hz @ 100kHz Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 17:13 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 TCXO Specification Part No. + Packaging: LFTCXO075797Reel Customer Part: Environmental Parameters Operable Temperature Range: -40 to 85°C Storage Temperature Range: -55 to 105°C ESD Levels: ESD Human Body Model (JEDEC JS-001-2010): Class 2: 2000V to 4000V ESD Machine Model (JEDEC JESD22-A115C): Class B: 200V to 400V Shock: IEC 60068-2-27, Test Ea, Severity 50A: 100G acceleration for 6ms, half sine wave, 3 times in 3 mutually perpendicular planes. Vibration: IEC 60068-2-06, Test Fc: 10Hz-2000Hz, 0.75mm amplitude, 10G acceleration, 30mins per cycle, 3 times in 3 mutually perpendicular planes, test duration 2hrs. Manufacturing Details Storage Conditions: Temperature: -10 to 35°C Humidity: 20 to 70% RH RoHS Terminations RoHS Reflow Temp Ni (1μm~9μm), Au (0.5μ~1μm) 260°C max for 30sec max Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant 2 Packaging Details Pack Style: Reel Pack Size: 2,000 Tape & reel in accordance with EIA-481-D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 17:13 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFTCXO075797REEL 价格&库存
很抱歉,暂时无法提供与“LFTCXO075797REEL”相匹配的价格&库存,您可以联系我们找货
