LFTCXO082851BULK
LFTCXO082851BULK
    IQD
    SMD-8
    有源晶振 20MHz 3.3V SMD-8
LFTCXO082851BULK 数据手册
TCXO Specification Part No. + Packaging: LFTCXO082851Bulk Description Temperature Compensated Crystal Oscillator (TCXO) Model IQXT-210-34 Model Issue number 1 Outline (mm) Frequency Parameters Frequency 20.0MHz Frequency Tolerance ±0.50ppm ±0.14ppm Frequency Stability Operating Temperature Range Ageing -40.00 to 85.00°C ±0.02ppm max per day, ±1ppm max per year Frequency Tolerance: Measurement referenced to frequency observed with TA=25°C and Vs=3.3V within 30 days after ex-works. Frequency Stability: TA varied across the operating temperature range, measurement referenced to frequency observed with fref=(fmax+fmin)/2, Vs=3.3V, load=15pF and temperature variable speed less than 2°C/min. Ageing: measurement referenced to frequency observed with TA=25°C and Vs=3.3V after 1hr of operation. Supply Voltage Variation (measurement referenced to frequency observed with TA=25°C, Vs varied from 3.13V to 3.47V and load=15pF): ±0.1ppm max Load Variation (measurement referenced to frequency observed with TA=25°C, Vs=3.3V and load change=15pF ±5%): ±0.2ppm max Electrical Parameters 3.3V ±5% Supply Voltage Current Draw 10.000mA Current Consumption (@ TA=25°C, Vs=3.3V and load=15pF): 10mA max Output Details HCMOS Output Compatibility Drive Capability 15pF Rise and Fall Time 8.0ns max 45/55% Duty Cycle Output Voltage Levels (@ Vs=3.3V and load=15pF): Output Low (VoL): 0.4V max Output High (VoH): 2.4V min Noise Parameters Phase Noise (typ @ 25°C): -85dBc/Hz @ 10Hz -115dBc/Hz @ 100Hz -130dBc/Hz @ 1kHz -145dBc/Hz @ 10kHz -150dBc/Hz @ 100kHz -150dBc/Hz @ 1MHz Phase Noise (max @ 25°C): -80dBc/Hz @ 10Hz -108dBc/Hz @ 100Hz -125dBc/Hz @ 1kHz -140dBc/Hz @ 10kHz -145dBc/Hz @ 100kHz -145dBc/Hz @ 1MHz Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 7 Mar 20 0:20 using Part Data Sheet V1.00015 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 TCXO Specification Part No. + Packaging: LFTCXO082851Bulk Environmental Parameters Storage Temperature Range: -55 to 105°C ESD Levels: ANSI/ESDA/JEDEC JS-001-2010: Human Body Model, Class 2: 2000V to 4000V Machine Model, Class B: 200V to 400V Shock: IEC 60068-2-27, Test Ea, Severity 50A: 100g acceleration for 6ms, half sine wave, 3 times in 3 mutually perpendicular planes. Vibration: IEC 60068-2-06, Test Fc: 10Hz-2000Hz, 0.75mm amplitude, 10g acceleration, 30mins per cycle, 3 times in 3 mutually perpendicular planes, test duration 2hrs. RoHS Terminations RoHS Reflow Temp 260°C max for 30secs max Compliance RoHS Status (2011/65/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant 2 Packaging Details Pack Style: Bulk Pack Size: 1 Loose in bulk pack Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 7 Mar 20 0:20 using Part Data Sheet V1.00015 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFTCXO082851BULK 价格&库存
很抱歉,暂时无法提供与“LFTCXO082851BULK”相匹配的价格&库存,您可以联系我们找货
