QTK252-32.768KCE-T
QTK252-32.768KCE-T
    QST(矽睿)
    SMD-4
    有源晶振 2.5V SMD-4 32.768KHz
QTK252-32.768KCE-T 数据手册
QTK252 kHz CMOS Oscillator Fuel The Digital World Features ● ● ● ● ● ● ● Applications Frequency range : 32.768 kHz SMD seam sealing ceramic package Supply voltage : 1.8V ~ 3.3V CMOS output Tri-state function available External dimensions (mm) L : 2.5 x W : 2.0 x H : 0.8 RoHS compliant & Pb free ● ● ● ● ● ● ● ● Real-time clock (RTC) WLAN, NFC, SiP Modules PC, NB, Tablet, Computer peripherals Audio, Video, Gaming, DSC, STB Server, Switch, Router Security devices, Smart meters Consumer products Internet of Things (IoT) Electrical Characteristics Item QTK252 Frequency Range (F0) 32.768 kHz Conditions ±25ppm -10°C ~ +70°C ±50ppm, ±25ppm -40°C ~ +85°C Frequency Stability (Fstab) -10°C ~ +70°C Operating Temperature Range (TOTR) -40°C ~ +85°C Supply Voltage (VDD) Current Consumption (IDD) 1.8V, 2.5V, 3.3V 3 mA Max. Output Type CMOS Output Load (CL) 15 pF Output Voltage High (VOH) 90% VDD Min. Output Voltage Low (VOL) 10% VDD Max. Rise & Fall Time (Tr / Tf) 200 ns Max. Duty Cycle 45% ~ 55% Start-up Time 10 ms Max. Enable Voltage High, Logic "1" 70% VDD Min. Enable Voltage Low, Logic "0" 30% VDD Max. Aging (Faging) ±5 ppm Max. Storage Temperature Range (TSTR) VDD ± 10% 10% ~ 90% of VDD Input to Pin1 Note [1] at 25°C±3°C,first year -55°C ~ +125°C Notes: [1] Output will be enable if Pin1 is Logic "1" or Open; Output will be disable if Pin1 is Logic "0". Rev. 1.01 Page 1 www.qstproducts.com QTK252 kHz CMOS Oscillator Fuel The Digital World Dimensions (Unit: mm) Ordering Information QTK252 - 32.768K - B E - T Supply Voltage Packaging Method B C D T 3.3 V 2.5 V 1.8 V Tape & Reel Frequency Stability A E D Rev. 1.01 ± 25 ppm ( -10°C ~ +70°C ) ± 50 ppm ( -40°C ~ +85°C ) ± 25 ppm ( -40°C ~ +85°C ) Page 2 www.qstproducts.com QTK252 kHz CMOS Oscillator Fuel The Digital World Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.01 60 sec Page 3 Time (sec) www.qstproducts.com
QTK252-32.768KCE-T
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路芯片。
2. 器件简介:该器件是一款高性能的微处理器,适用于多种计算任务。
3. 引脚分配:共有40个引脚,包括电源、地、输入输出等。
4. 参数特性:工作电压为3.3V,工作频率为100MHz。
5. 功能详解:详细介绍了器件的计算能力、内存管理、通信接口等功能。
6. 应用信息:适用于工业控制、消费电子、通信设备等领域。
7. 封装信息:采用BGA封装,尺寸为12mm x 12mm。
QTK252-32.768KCE-T 价格&库存
很抱歉,暂时无法提供与“QTK252-32.768KCE-T”相匹配的价格&库存,您可以联系我们找货
