RF4M096000S300
RF4M096000S300
    NEXTGEN
    SMD-4
    有源晶振 4.096MHz 3.3V SMD-4
RF4M096000S300 数据手册
PART CODE: RF4M096000S300 SPECIFICATION SHEET SPECIFICATION SHEET NO. N0217- RF4M096000S300 DATE Feb. 17, 2021 REVISION A0 DESCRIPITION SMD Oscillator, 2520 Type, L2.5*W2.0*H1.0mm, 4 Pads, COM22 series 4.096000MHz, 3.3V, +/-50ppm, Symmetry 45/55, Operating Temp. Range -40°C ~+85°C, Reflow Profile Condition 260 °C Max. HCMOS//15pF, Tristate via Pad 1, Supply Current 20mA Max. Tape/Reel, RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS COM2231BGI03 TLF-4M096 PART CODE RF4M096000S300 VENDOR APPROVE Issued/Checked/Approved DATE: Feb. 17, 2021 CUSTOMER APPROVE DATE: NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RF4M096000S300 MHZ SMDSMD OSCILLATOR CRYSTAL 2520 TYPE 4 PADS MAIN FEATURE • SMD Package, Seam Sealed, 2520 Type, L2.5*W2.0*H1.0mm, 4 Pads • Low noise and Low current • Industry standard • Reflow Profile Condition 260 °C Max. • Cross more competitors part • RoHS/RoHS III compliant APPLICATION • PDA, PND, DSC, Smart phone, WiLAN, Bluetooth and more • Communication Electronics RFQ PART CODE GUIDE Request For Quotation RF 4M096000 S 300 1 2 3 4 1) RF: Part family Code for SMD Oscillator, 2520 Type, L2.5*W2.0*H1.0mm, 4 Pads, COM22 series 2) 4M096000: Frequency range code for 4.0960000MHz 3) S: SMD type, Package Tape/Reel, 3000pcs/Reel 4) 300: Specification code for original part No.: TGS COM2231BGI03 TLF-4M096 MORE FREQUENCY RANGE AVAILABLE (MHz) 4.0960 4.9152 12.000 NextGen Components, Inc. 19.200 24.000 25.000 sales@NextGenComponent.com 27.000 33.000 48.000 50.000 www.NextGenComponent.com PART CODE: RF4M096000S300 MHZ SMD OSCILLATOR 2520 TYPE 4 PADS DIMENSION (Unit: mm, Tol. +/-0.15mm) Image for reference Marking 1 Line 1: Company Code + Supply Voltage Line 2: Freq. Range + QC Code (A~Z) COM22 Marking 2 Line 1: Frequency Range Pin Function #1 Enable (Tri-State) #2 Ground #3 Output #4 VDD Recommend Pad Layout NextGen Components, Inc. Circuit Principle sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RF4M096000S300 MHZ SMD OSCILLATOR 2520 TYPE 4 PADS ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Original Manufacturer Holder Type Typical Condition Max. TGS TGS Crystals COM22 SMD Oscillator, 2520 Type, L2.5*W2.0*H1.0mm, 4 Pads Supply Voltage 3 Enable/Disable Function 1 Overall Freq. Tolerance B ppm -50 +50 Operating Temp. Range G °C -40 +85 °C -55 +125 % 45 55 V OH V 90% V OL V Load pF Storage Temp. Range Symmetry Output I Output Waveform V 3.3 +/-10% Tri-State @ Control via pin 1 @25°C High (Logic “1”) 10% Low (Logic “0”) 15 03 HCMOS @OutputLoad 15pF Startup Time ms 10 Supply Current mA 20 Rise/ Fall time ns 10 Phase Jitter ps 1.0 @12KHz~20MHz ppm/year ±3 @1st year Aging Others Package T Tape/Reel RoHS Status LF RoHS III compliant Add Value N/A Internal Control Code * N/A Frequency Range -4M096 4.0960MHz Note: 1) Original Part Number: TGS COM2231BGI03 TLF-4M096 2) * Internal Control Code- 2 letter or digits; Blank: N/A NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RF4M096000S300 MHZ SMD OSCILLATOR 2520 TYPE 4 PADS RELIABILITY Test Items Test Method And Conditions Reference Documents High Temperature High Humidity Storage Temperature: 85℃±3℃ Relative Humidity:85%RH Time: 96 Hours JIS C5023 High Temperature Storage Temperature: 125℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1005.8 Low Temperature Storage Temperature: -40℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1013 Thermal Shock Temperature 1: -55℃±5℃ Temperature 2: 85℃±5 ℃ Temperature change between T1 and T2 5 min 10cycles maintain T1 and T2 for 30 minutes each cycle MIL-STD-202F Method 107 Condition A Resistance to Solder Heat Solder Temperature: 260℃±5℃ Time: 10±1 Seconds MIL-STD-202F Method 210E Solderability The solder pot temperature is 245±5℃ , dwell time 5±0.5sec J-STD-002B Drop Test 3 Times Free Fall from 50cm height table to 3cm thickness hard wood board J-STD-002B Mechanical Shock Half sine wave,1000 G 3 Times for all 3 directions(X,Y Z) MIL STD 202F Method 213B Vibration Frequency Range: 10Hz~55Hz Amplitude: 0.75mm 2 Hours in each direction, total 6 Hours MIL-STD-883E Method 2007.3 Leakage Test Take measurements with a helium Leakage detector Leakage Rate≤1×10ˉ³Pa cm³/s MIL-STD-883E NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RF4M096000S300 MHZ SMD OSCILLATOR 2520 TYPE 4 PADS SUGGESTED REFLOW PROFILE (For Reference Only) Total time: 200 Sec. Max. Solder melting point: 220℃ Profile Feature Pb-Free Assembly Average Ramp-up Rate (Ts Max to Tp) 3℃/second Max Preheat Temperature Min (Ts Min.) 125℃ Temperature Max (Ts Max.) 200℃ Time (ts Min. to ts Max.) 60~180 seconds Temperature (TL) 217℃ Time (tL) 60~150 seconds Time maintained above Peak/Classification Temperature (Tp) 260 ℃ Time within 5℃ of actual Peak Temperature (tp) 20~40 seconds Ramp-down rate 6 ℃ /Second Max. Time 25 ℃ to Peak Temperature 8 minutes Max. Suggest reflow times 3 Times Max. NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RF4M096000S300 MHZ SMD OSCILLATOR 2520 TYPE 4 PADS TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-2 and specifications, 3000pcs/Reel DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
RF4M096000S300
物料型号为 RF4M096000S300,是 NextGen Components, Inc. 生产的 SMD 振荡器。
器件简介包括其为 2520 封装类型,尺寸为 L2.5W2.0H1.0mm,4个焊盘,属于 COM22 系列,频率为 4.096000MHz,工作电压为 3.3V,频率容差为 +/-50ppm,对称性为 45/55,工作温度范围为 -40°C 至 +85°C,最大再流温度为 260°C,HCMOS/15pF,三态通过焊盘 1,最大供电电流为 20mA,卷带包装,符合 RoHS/RoHS III 标准。
引脚分配如下: - #1 使能(三态) - #2 地 - #3 输出 - #4 电源
参数特性包括: - 工作电压:3.3V +/-10% - 使能/禁用功能:通过引脚 1 控制,为三态 - 总体频率容差:25°C 时为 +/-50ppm - 工作温度范围:-40°C 至 +85°C - 对称性:45% 至 55% - 输出高电平(VOH):90% VDD - 输出低电平(VOL):10% VDD - 负载电容:15pF - 输出波形:HCMOS,15pF 负载下 - 启动时间:10ms - 供电电流:最大 20mA - 上升/下降时间:10ns - 相位抖动:12KHz 至 20MHz 时为 1.0ps - 老化:第一年 +/-3ppm
功能详解包括振荡器的工作原理和如何通过外部电阻 Rs 减少电磁干扰。
应用信息涵盖 PDA、PND、DSC、智能手机、WiLAN、蓝牙等通信电子产品。
封装信息为 2520 封装类型,尺寸为 L2.5W2.0H1.0mm,4个焊盘,符合行业标准,100% 符合 RoHS 标准。
RF4M096000S300 价格&库存
很抱歉,暂时无法提供与“RF4M096000S300”相匹配的价格&库存,您可以联系我们找货
