QTV532P-155.520MBB-T
    QST(矽睿)
    SMD-6
    有源晶振 3.3V 155.52MHz SMD-6
QTV532P-155.520MBB-T 数据手册
QTV532P Voltage Controlled Crystal Oscillator Fuel The Digital World Features ● ● ● ● ● ● ● ● ● Applications Frequency range : 30MHz to 250MHz SMD seam sealing ceramic package Supply voltage : 3.3V LVPECL output Fundamental solution Low phase noise and phase jitter Tri-state function available External dimensions (mm) L : 5.0 x W : 3.2 x H : 1.2 RoHS compliant & Pb free ● ● ● ● ● ● Wireless communications, Smallcell, Base station Fibre channel, SONET, SDH, Ethernet Set-top box (STB) xDSL, VoIP, Cable modem Digital TV, Digital audio Phase-locked loop (PLL) circuits Electrical Characteristics Item Frequency Range (F0) Operating Temperature Range (T OTR) QTV532P 30MHz ~ 250MHz -40°C ~ +85°C -40°C ~ +105°C Supply Voltage (VDD) Current Consumption (IDD) 3.3 V 80 mA Max. Output Type LVPECL Output Load 50Ω (VDD - 2.0V) Output Voltage High (VOH) VDD - 1.025V Min. Output Voltage Low (VOL) VDD - 1.62V Max. Rise & Fall Time (Tr / Tf) 0.5 ns Max. Duty Cycle 45% ~ 55% Start-up Time 10 ms Max. Enable Voltage High, Logic "1" 70% VDD Min. Enable Voltage Low, Logic "0" 30% VDD Max. Absolute Pulling Range (APR) ±50 ppm Min. Control Voltage Range 0V ~ 3.3V Linearity 10% Max. Phase Noise (F0 = 122.88MHz) -128 dBc/Hz Typ. Phase Jitter (F0 = 122.88MHz) 0.11 ps Typ. Storage Temperature Range (TSTR) Rev. 1.01 Conditions VDD ± 10% RL = 50Ω to VDD - 2.0V 20% ~ 80% of output swing Input to Pin2 Note [1] Note [2] Nominal 1.65V at 1kHz offset 12kHz ~ 20MHz, RMS -55°C ~ +125°C Page 1 www.qstproducts.com QTV532P Voltage Controlled Crystal Oscillator Fuel The Digital World Notes: [1] Output will be enabled if Pin2 is Logic "1" or open; Output will be disabled if Pin2 is Logic "0". [2] Absolute Pulling Range (APR) = Pulling Range - (Frequency tolerance at 25°C, variations over temerature, supply voltage, and aging). Dimensions Pin function Pin 1 VC Pin 2 OE Pin 3 GND Pin 4 OUT Pin 5 OUT VDD Pin 6 Recommended pad layout (Unit: mm) * Pad dimension tolerance is ±0.2mm * Power supply decoupling capacitor is required. Ordering Information QTV532P - 122.88M B B Frequency in Hz - T Packaging Method T Please contact us for available frequencies Tape & Reel Operating Temperature Range Supply Voltage B Rev. 1.01 B G 3.3 V Page 2 -40°C ~ +85°C (APR ± 50 ppm) -40°C ~ +105°C (APR ± 50 ppm) www.qstproducts.com QTV532P Voltage Controlled Crystal Oscillator Fuel The Digital World Packing (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min., 200 sec. Max. Peak temperature : 260°C ± 10°C, 10 sec. Min., 30 sec. Max. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.01 60 sec Page 3 Time (sec) www.qstproducts.com
1. 物料型号:QTV532P 2. 器件简介:QTV532P是一款电压控制晶体振荡器,适用于数字世界,具有30MHz至250MHz的频率范围。 3. 引脚分配: - Pin 1: VC(电源) - Pin 2: OE(使能) - Pin 3: GND(地) - Pin 4: OUT(输出) - Pin 5: OUT(输出) - Pin 6: VDD(电源) 4. 参数特性: - 工作温度范围:-40°C至+85°C或-40°C至+105°C - 供电电压:3.3V - 最大电流消耗:80mA - 输出类型:LVPECL - 输出负载:50Ω - 输出电压高:至少VDD - 1.025V - 输出电压低:至多VDD - 1.62V - 上升和下降时间:最大0.5ns - 占空比:45%至55% - 启动时间:最大10ms - 使能电压高:至少70% VDD - 绝对拉频范围:至少±50ppm - 控制电压范围:0V至3.3V 5. 功能详解:QTV532P具有低相位噪声和相位抖动,三态功能可用,并且符合RoHS标准,无铅。 6. 应用信息:适用于无线通信、小型基站、以太网、光纤通道、SONET、SDH、机顶盒、xDSL、VoIP、电缆调制解调器、数字电视、数字音频和相位锁定环(PLL)电路。 7. 封装信息:SMD密封陶瓷封装,外部尺寸为长5.0mm x 宽3.2mm x 高1.2mm。
QTV532P-155.520MBB-T 价格&库存
很抱歉,暂时无法提供与“QTV532P-155.520MBB-T”相匹配的价格&库存,您可以联系我们找货
