Think of Frequency Think of
SMD LVDS SAW
Oscillators - Differential Output
5.0 x 3.2 x 1.2 mm CT Series
Oscillators
Series
come visit our site http://www.txccorp.com
Features
.SAW base solution.
.3.3V and 2.5V operation available.
1H
TSY 500
C
T B 156.2
.LVDS output, output frequencies 150 MHz to 700 MHz.
.Excellent low phase noise and jitter.
.Tri-State function available.
.Applications : Fibre Channel, Gigabit Ethernet, Serial ATA, Serial Attached
SCSI, PCI-Express, SDH / SONET.
.RoHS Compliant / Pb Free.
Item / Type
CT
Output Type
LVDS
Output Load
100 Ω
Oscillation Mode
Fundamental
Supply Voltage
2.5 V , 3.3 V
Frequency Range
150 ~ 700 MHz
Overall Frequency Stability *
± 100 ppm , or specify
Operating Temperature Range
-10 ~ + 70 ℃ , - 5 ~ + 85 ℃ , or specify
Storage Temperature Range
- 55 ~ + 125 ℃
Voltage Vol(Min.) / Voh (Max.)
0.9 V / 1.6 V
Rise ( Tr ) / Fall ( Tf ) Time ( 20 % ~ 80 % )
1 nS Max.
Supply Current
80 mA Max.
Symmetry
45 ~ 55 %
Start-up Time
10 mS Max.
Phase Jitter ( 12 KHz ~ 20 MHz )
1 pS Max.
Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com
Electrical Specifications
* Inclusive of frequency tolerance at 25 ℃, variation over temperature, supply voltage variation, aging and vibration.
Dimensions
5.0±0.2
5
4
1
2
3
1.2±0.2
3.2±0.2
6
Land Pattern:
1.27
6
0.89
5
4
2
3
5
4
1.20
1
6
2.60
1.60
0.64
0.90
Pin Function:
1. Enable Control or NC
2. Enable Control or NC
3. GND
4. OUT
5. OUTN
6. VDD
1.27 1.27
Pad dimension tolerance ±0.2 mm
12
3
Power Supply Decoupling Capacitor is Required.
Units: mm
71
很抱歉,暂时无法提供与“CT-425.000MCB-T”相匹配的价格&库存,您可以联系我们找货
