Low Current Consumption 32.768kHz
OZ-I Type
2.0 x 1.6 mm SMD Crystal Oscillator
Actual Size
FEATURE
- Low Power Supply Voltage: 3.3, 2.5, 1.8V Supply Options
- Singled-end Output: CMOS
- Frequency: 32.768kHz
- Low Current Consumption: 18µA Max
- Temperature Range: -40oC to 85oC Operation
- Pb-free/RoHS Compliant
RoHS Compliant
TYPICAL APPLICATION
- RTC Module
- Smartphone
- IoT
- Wearable Device
– Watch, Medical
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ B O T T O M V IE W ]
[ TO P VIEW ]
0.1 μF
1.27±0.10
#4
#2
#2
0.47±0.10
1.65±0.10
#1
#1
0.97
#3
#3
0.97±0.10
#4
0.60
2.05±0.10
0.57±0.10
0.75±0.10
[ S ID E V IE W ]
1.27
Pin#
1
2
3
4
Function
Tri-state
GND
Output
VDD
0.75
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
3.3V
Parameter
Supply Voltage Variation (VDD)
2.5V
1.8V
Min.
Max.
Min.
Max.
Min.
Max.
VDD-10%
VDD+10%
VDD-5%
VDD+5%
VDD-5%
VDD+5%
Frequency Range
32.768
Supply Current (No Load)
Output Level
Transition Time (10%90%)
Unit
V
kHz
18
18
18
uA
Output High
2.97
2.25
2.25
V
Output Low
0.33
0.25
0.25
V
Rise Time / Fall Time
15.0
15.0
15.0
nSec
45
55
45
55
45
55
mSec
Duty Cycle
Startup Time
Tri-State Mode
Enable
0.7 x VDD
0.7 x VDD
0.7 x VDD
(Input to Pin 2)
Disable
0.3 x VDD
0.3 x VDD
0.3 x VDD
V
Stand by Current
3
3
3
Output Loading (CMOS)
15
15
15
pF
Aging (@ 25oC, 1st Year)
±3
±3
±3
ppm
-55
+125
-55
+125
-55
+125
Storage Temp. Range
uA
o
C
FREQ. STABILITY vs. TEMP. RANGE
ppm
Temp.( oC)
-10~+60
-20~+70
-40~+85
±20
25
50
*O: Available △: Conditional X: Not available
*Inclusive of calibration @ 25 oC ,operating temperature rrange,input
Voltage variation,load variation,aging (1st year),shock,and vibration
Note: not all combination of options are available. Other specifications may be available upon request.
26
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(1)01/2020
OZKIDLJANF-0.032768 价格&库存
很抱歉,暂时无法提供与“OZKIDLJANF-0.032768”相匹配的价格&库存,您可以联系我们找货
