SXO75P3D481-156.250M
    SUNTSU
    SMD7050_6P
    有源晶振 156.250000 MHz -20~+20ppm 3.3V -40℃~+85℃ LVPECL
SXO75P3D481-156.250M 数据手册
Ceramic SMT 6 Pad LVPECL Oscillator SXO75P Series 7.0mm x 5.0mm Features Applications • ±20ppm (Frequency Stability) Available • Fiber Channel • Ceramic Package • Gigabit Ethernet • LVPECL • PCI Express • Tape and Reel • Part Numbering Guide SXO 75 P 3 A 48 1 - 156.250M SUNTSU OSC FREQUENCY MHz TRI-STATE (ENABLE/DISABLE) 1 : Pin 1 2 : Pin 2 7.0mm x 5.0mm LVPECL SUPPLY VOLTAGE 2 : 2.5V±5% 3 : 3.3V±5% CO M P L I A N T FREQUENCY STABILITY A : ±50ppm B : ±30ppm C : ±25ppm *D : ±20ppm Cage Code : 4GUT4 To customize your parameters, contact a Suntsu representative. * For Frequency stability option D, contact a Suntsu representative. Electrical Parameters Typical OPERATING TEMPERATURE RANGE 07 : 0°C - +70°C 16 : -10°C - +60°C 17 : -10°C - +70°C 27 : -20°C - +70°C 38 : -30°C - +85°C 48 : -40°C - +85°C Units Minimum Frequency Range MHz 20 Maximum 200 Frequency Stability (Includes Initial Tolerance at 25°C, Frequency Stability over Operating Temperature, Output Load Change, Supply Voltage Change, and First Year Aging at 25°C.) ppm -20 +20 See part numbering guide for options Operating Temperature °C -40 +85 See part numbering guide for options Storage Temperature °C -55 +125 Supply Voltage (VDD) - 2.5V option V 2.375 2.5 2.625 Supply Voltage (VDD) - 3.3V option V 3.125 3.3 3.465 Current (IDD) - 2.5V option mA 65 Current (IDD) - 3.3V option mA 80 Output Load (LVPECL) Ω Output Logic Levels High (VOH) V 50 V Rise (TR) and Fall (TF) Time ns Symmetry (Duty Cycle) % 45 Tri-State Input Voltage - Enable V 0.7*VDD Tri-State Input Voltage - Disable V Start-Up Time ms ps www.suntsu.com Specifications are subject to change without notice. 50 Ω into VDD-2.0VDC VDD-1.025 Output Logic Levels Low (VOL) Phase Jitter (12kHz ~ 20MHz) Remarks VDD-1.62 0.4 0.8 50 55 No Connection 0.3*VDD 10 0.4 1 Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad LVPECL Oscillator SXO75P Series 7.0mm x 5.0mm Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Test Circuit (LVPECL) Waveform (LVPECL) Typical Phase Noise Performance (Measured By Agilent E5052A) Frequency - 156.250MHz www.suntsu.com Specifications are subject to change without notice. Frequency - 260.000MHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad LVPECL Oscillator SXO75P Series 7.0mm x 5.0mm Typical Jitter Performance (Measured By Agilent E5052A) Frequency - 156.250MHz Frequency - 260.000MHz Reflow Profile Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 1,000pcs/Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 6 Pad LVPECL Oscillator SXO75P Series 7.0mm x 5.0mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Moisture Resistance MIL-STD-883, Method 1004 Solderability MIL-STD-883, Method 2003 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
物料型号:SXO75P系列 器件简介:7.0mm x 5.0mm的陶瓷封装LVPECL振荡器,适用于光纤通道、千兆以太网和PCI Express等应用。 引脚分配:1号引脚为使能/禁用控制,2号引脚为LVPECL信号,其他引脚未详细说明。 参数特性:包括频率稳定性(±20ppm至±50ppm不等,取决于型号),工作温度范围(-40°C至+85°C),存储温度(-55°C至+125°C),供电电压范围(2.5V±5%或3.3V±5%),以及功耗等。 功能详解:文档提供了频率范围、频率稳定性、工作温度、存储温度、供电电压、电流、输出负载、输出逻辑电平、上升和下降时间、占空比、三态输入电压、启动时间、相位抖动等详细电气参数。 应用信息:适用于光纤通道、千兆以太网和PCI Express等高速通信应用。 封装信息:7.0mm x 5.0mm的陶瓷SMT封装,带有6个焊盘,提供了外形图和布局图案。
SXO75P3D481-156.250M 价格&库存
很抱歉,暂时无法提供与“SXO75P3D481-156.250M”相匹配的价格&库存,您可以联系我们找货
