OXEIDLJANF-0.032768
OXEIDLJANF-0.032768
    TAITIEN(泰艺)
    SMD-4
    有源晶振 3.3V SMD-4 32.768KHz
OXEIDLJANF-0.032768 数据手册
Low Current Consumption 32.768kHz OX-I Type 3.2 x 2.5 mm SMD Crystal Oscillator Actual Size FEATURE - Low Power Supply Voltage: 1.8V, 2.5V and 3.3V Supply Options - Singled-end Output: CMOS - Frequency: 32.768kHz - Low Current Consumption: < 18 μA - Temperature Range: -40oC to 125oC Operation - Pb-free/RoHS Compliant RoHS Compliant TYPICAL APPLICATION - RTC Module - Smartphone - IoT - Wearable Device – Watch, Medical DIMENSION (mm) SOLDER PAD L AYOUT (mm) 0.1 μF [ B O T T O M V IE W ] [ TO P VIEW ] 2.10 ± 0.15 1.65 ± 0.15 #2 #2 0.65 ± 0.15 #1 #4 #1 1.60 #3 #3 2.50 ± 0.15 #4 1.10 3.20 ± 0.15 2.10 0.90 ± 0.15 Pin# 0.35 0.95 ± 0.15 [ S ID E V IE W ] 1 2 3 4 Function 1.20 Tri-state GND Output VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3V Parameter Supply Voltage Variation (VDD) 2.5V 1.8V Min. Max. Min. Max. Min. Max. VDD-10% VDD+10% VDD-5% VDD+5% VDD-5% VDD+5% Frequency Range 32.768 Supply Current (No Load) Output Level Transition Time+ (10%-90%) Unit V kHz - 18 - 18 - 18 uA Output High 2.97 - 2.25 - 2.25 - V Output Low - 0.33 - 0.25 - 0.25 V nSec Rise Time / Fall Time Duty Cycle Startup Time - 15.0 - 15.0 - 15.0 45 55 45 55 45 55 % - 20 - 20 - 20 mSec Tri-State Mode Enable 0.7 x VDD - 0.7 x VDD - 0.7 x VDD - (Input to Pin 2) Disable - 0.3 x VDD - 0.3 x VDD - 0.3 x VDD - 3 - 3 - 3 Output Loading (CMOS) - 15 - 15 - 15 pF Aging (@ 25oC, 1st Year) - 3 - 3 - 3 ppm -55 +125 -55 +125 -55 +125 Stand by Current Storage Temp. Range V uA o C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position +Transition times are measured between 10% and 90% of VDD,withan output load of 15pF FREQ. STABILITY vs. TEMP. RANGE ppm Temp.( oC) ±20 25 30 50 -10~+60 -20~+70 -40~+85 -40~+105 -40~+125 * O: Available △:Conditional X: Not available *Inclusive of calibration @ 25℃, operating temperature range, input voltage variation, st load variation, aging (1 year), shock, and vibration load variation Note: not all combination of options are available. Other specifications may be available upon request. 28 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(2) 11/2021
OXEIDLJANF-0.032768 价格&库存
很抱歉,暂时无法提供与“OXEIDLJANF-0.032768”相匹配的价格&库存,您可以联系我们找货
