Low Current Consumption 32.768kHz
OY-I Type
2.5 x 2.0mm SMD Crystal Oscillator
Actual Size
FEATURE
- Low Power Supply Voltage: 3.3, 2.5, 1.8 Supply Options
- Singled-end Output: CMOS
- Frequency: 32.768kHz
- Low Current Consumption: 18uA Max
- Temperature Range: -40 to 85oC Operation
- Pb-free/RoHS Compliant
RoHS Compliant
TYPICAL APPLICATION
- RTC Module
- Smartphone
- IoT
- Wearable Device
OY_PY
- Watch, Medical
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
1.625 ± 0.10
#1
#1
0.675 ± 0.10 0.675
0.81 ± 0.15
0.29
Pin#
1
2
3
4
0.80
1.225
#4
#2
#2
[ S ID E V IE W ]
#3
0.57 ± 0.10
#3
1.225 ± 0.10
2.50 ± 0.20
2.00 ± 0.20
#4
0.1 μF
[ B O T T O M V IE W ]
[ TO P VIEW ]
1.625
Function
0.90
Tri-state
GND
Output
VDD
Might cause malfunction if do not
To ensure optimal oscillator
place a by-pass capacitor of 0.1μF
followperformance,
the recommendation.
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
3.3 V
Parameter
Min.
Transition Time
(10%-90%)
_
18
_
2.97
_
Output High
Output Low
Rise Time / Fall Time
Duty Cycle
Startup Time
Tri-State Mode (Input to Pin 2)
2.5 V
Min.
Max.
VDD-10% VDD+10% VDD-5%
Supply Voltage Variation (VDD )
Frequency Range
Supply Current (No Load)
Output Level
Max.
Enable
Disable
Standby Current
Output Loading (CMOS)
Aging (@ 25°C 1st year)
Storage Temp. Range
0.33
_
2.25
_
1.8 V
Min.
VDD+5%
32.768
18
_
0.25
VDD-5%
Max.
VDD+5%
_
2.25
_
18
_
unit
V
kHz
uA
0.25
V
nSec
_
15.0
_
15.0
_
15.0
45
_
55
45
_
55
45
_
55
_
mSec
_
_
0.7xVDD
0.7xVDD
0.7xVDD
_
_
_
0.3xVDD
0.3xVDD
0.3xVDD
_
_
_
3
3
3
_
_
_
15
15
15
_
_
_
±3
±3
±3
-55
125
-55
125
-55
125
V
µA
pF
ppm
°C
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
±20
±25
±50
-10~+60
-20~+70
-40~+85
○: Available △:Conditional
X: Not available
* Inclusive of calibration @ 25 °C, operating temperature range, input
voltage variation, load variation, aging (1st year), shock, and vibration
Note: not all combination of options are available. Other specifications may be available upon request.
30
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(3)11/2019
OYKIDLJANF-0.032768 价格&库存
很抱歉,暂时无法提供与“OYKIDLJANF-0.032768”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 200+18.05510200+2.33591
- 400+17.30923400+2.23941
- 600+16.88748600+2.18485
- 1000+16.370981000+2.11803
- 1400+16.039801400+2.07518
- 2000+15.695932000+2.03069
- 国内价格 香港价格
- 1+24.975431+3.23124
- 10+21.6688510+2.80345
- 25+20.4952225+2.65161
- 50+19.6460650+2.54175
- 100+18.83403100+2.43669
