S3A2505-100.000-L-X-R 数据手册
RoHS Compliant
Pb - Lead Free
Ltr
Date
Revisions
Electrical Specifications:
Frequency Range
13.500 - 156.250
±100
±50
±25
±3
-10 to +70
-40 to +85
-55 to +125
Frequency Stability over Temperature
Aging per Year
Standard
Extended
Operating Temperature Range
Storage Temperature Range
Supply Voltage
Input Current
Output Voltage
Differential Output Voltage (Vod)
Offset Voltage (Vos)
Output Symmetry
Output Type
Output Load (Between Q ansd QN)
13.500 - 156.250 Mhz
Logic High (Voh)
Logic Low (Vol)
13.500 - 99.999Mhz
100.000 - 156.250Mhz
Rise and Fall Time
Enable-Disable Function
Enable High Input Voltage
Enable Low Input Voltage
Phase Jitter (12 KHz to 20 MHz)
MHz
PPM Max
ºC
2.5 ± 5%
3.3 ± 5%
50
50
1.6
1.6
0.9
0.9
247 (Min) 330 (Typ) 454 (Max)
1.125 (Min) 1.250 (Typ) 1.375 (Max)
45 to 55
LVDS - Complimentary Output
100
1
0.5
1
Ω
1
0.5
ns Max
Q Pin 4 - QN Pin 5
Operating
High Impedance
2.31
0.99
Vdd Min
Vdd Max
ps RMS
Tri-State
INH - Pin 1
High - Pin 1
Low - Pin 1
1.75
0.75
Vdd
mA Max
Vdd Min
Vdd Max
mV
V
Temperature stability is Inclusive of all conditions:
Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage,
supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C.
Specification Title:
11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC
All dimensions are millimeters.
CAD:
TCR
EG
Review:
JL
Appr:
Page:
1/4
Date: June 29, 2016
Clock Oscillator
3.2 x 2.5 millimeter Surface Mount - 6 Pad
General Product Specification
Part Number:
S3A Series
www.aker-usa.com
Appr
Mechanical Outline:
Package is Seam Sealed Ceramic-Metal.
Dimensions are millimeters.
PCB Solder Pad Layout:
Pad Connection:
Top View
Page:
2/4
Date: June 29, 2016
P/N:
Pin Connection
1- INH
2- NC
3- GND
4- Output - Q
5- Comp. Output - QN
6- Vdd
S3A Series
www.aker-usa.com
Carrier Tape Dimensions:
Solder Reflow Characteristics:
Page:
3/4
Date: June 29, 2016
P/N:
www.aker-usa.com
S3A Series
How to build a Part Number:
Series
Package
S
3A
Parameter
3.2 x 2.5 mm - 6 Pad
Supply Voltage
25
33
+2.5 Vdd ± 5%
+3.3 Vdd ± 5%
Temperature Stability
10
05
025
±100 PPM
±50 PPM
±25 PPM
Frequency
Output Load
Temperature Range
Packaging
13.500 - 156.250
L
See Notes
X
R
MHz
LVDS
0 to +70 ºC
-40 to +85 ºC
Tape and Reel
Part Number Example:
S3A3310-155.520-L-X-R
S3A: 3.2 x 2.5 mm SMD Package - 6 Pad
33: +3.3 Vdd Supply Voltage
10: ±100 PPM Temperature Stability
155.520 MHz Nominal Frequency
L: LVDS - Complimentary Output
X: -40 to + 85° C Extended Temperature Range
R: Tape and Reel
Notes:
1- Standard Temperature Range does not need to be included in Part Number
description.
2- Product is shipped in Tape and Reel configuration. Each reel contains
1000 pieces.
3- Quantities less than 1000 are shipped bulk in ESD pouches.
4- Specification subject to change without notice.
Page:
4/4
Date: June 29, 2016
P/N:
www.aker-usa.com
S3A Series
S3A2505-100.000-L-X-R 价格&库存
很抱歉,暂时无法提供与“S3A2505-100.000-L-X-R”相匹配的价格&库存,您可以联系我们找货
