TAETALSANF-40.000000 数据手册
TA Type
7.0 x 5.0 mm SMD Voltage Controlled Temperature
e
Compensated Crystal Oscillator
Actual Size
FEATURE
- Typical 7.0 x 5.0 x 1.9 mm ceramic SMD package.
- For automatic assembly.
- Compactness and light weight.
- Low power consumption.
- VCTCXO available.
TYPICAL APPLICATION
- Femtocell , Base Stations
- WLAN/WiMAX/WIFI, Wireless Communications
- Mobile Phone
DIMENSION (mm)
RoHS Compliant
SOLDER PAD LAYOUT (mm)
[TOP VIEW]
[BOTTOM VIEW]
7.00±0.20
5.08±0.15
#3
5.08
4.00±0.15
#4
#2
#2
4.20
0.80±0.15
#1
0.1µF
#1
1.20
#3
5.00±0.20
#4
1.40±0.15
[SIDE VIEW]
Pin#
0.7±0.12
1.90±0.20
1
2
3
4
Function
1.50
Vcon:VC-TCXO
GND/NC:TCXO
GND
OUTPUT
VDD
To ensure optimal oscillator performance, place a
by-pass capacitor of 0.1ȝF as close to the part as
possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
3.3 / 3.0 V
2.5 V
Min.
Max.
Min.
Max.
VDD-5%
VDD+5%
VDD-5%
VDD+5%
52
5
52
5
5, 6.4, 8, 8.192, 10, 12.5, 12.8, 16, 16.384, 19.44, 25, 26
_
_
±2.0
±2.0
Parameter
Supply Voltage Variation (VDD)
Frequency Range
Standard Frequency (for CMOS)
Standard Frequency (for Clipped Sine Wave)
Frequency Tolerance*
Frequency stability
Vs Supply Voltage (±5%) change
Vs Load (±10%) change
Vs Aging
Supply Current (CMOS output)
Supply Current (Clipped Sine Wave)
Output Level (CMOS)
Output High (Logic “1”)
Output Low (Logic “0”)
Duty
_
_
_
_
_
90%VDD
_
45
0.8
Output (Clipped Sine Wave)
Load (CMOS)
Load (Clipped Sine Wave)
Control Voltage Range (VCTCXO)
Pulling Range (VCTCXO)
Vc Input Impedance (VCTCXO)
Phase Noise @ 19.2 MHz
100 Hz
1 kHz
10 kHz
Start Time
Storage Temp. Range
±0.1
±0.2
±1.0
6
3.5
_
_
_
_
_
_
90%VDD
10%VDD
55
_
15pF
10 KΩ // 10pF
0.5
2.5
±5.0
±12.0
_
100
-115
-135
-148
_
2
-55
125
_
45
0.8
±0.1
±0.2
±1.0
6
3.5
Unit
V
MHz
ppm
ppm
mA
_
10%VDD
55
_
15pF
10 KΩ // 10pF
0.4
2.4
±5.0
±12.0
_
100
-115
-135
-148
_
2
-55
125
V
Vp-p
V
ppm
kΩ
dBc / Hz
mSec
°C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
Frequency at 25°C, 1 hour after reflow.
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
-20 ~ +70
-30 ~ +85
-40 ~ +85
±0.5
±1.0
ż
* : Available Χ:Conditional X: Not available
“ 10~26MHz and Pulling
TAETALSANF-40.000000 价格&库存
很抱歉,暂时无法提供与“TAETALSANF-40.000000”相匹配的价格&库存,您可以联系我们找货
