VTKUPLIANF-32.768000
    TAITIEN(泰艺)
    SMD-6
    有源晶振 1.8V 32.768MHz SMD-6
VTKUPLIANF-32.768000 数据手册
VT Type 7.0 x 5.0 mm SMD Voltage Controlled Crystal Oscillator Actual Size FEATURE - Typical 7.0 x 5.0 x 1.75 mm 6 pads ceramic SMD package. - Tight symmetry (45 to 55%) available. - Tri-state enable/disable TYPICAL APPLICATION - Set-top Box, HDTV - WiMAX/WLAN - xDSL/ VoIP, Cable modem RoHS Compliant VT SOLDER Type PAD L AYOUT (mm) DIMENSION (mm) [ TOP VIEW ] [ BOTTOM VIEW ] 5.08±0.20 #4 #1 #2 #3 #4 5.08 #6 #3 #2 1.27±0.20 3.81±0.20 #5 #1 0.1µF 1.40±0.20 Pin# Function 1 Vcon 2 Tri-State 3 GND 4 Outpout 5 NC 6 VDD 0.65 1.75±0.15 [ SIDE VIEW ] 4.00 #5 5.00±0.20 #6 2.00 7.00±0.20 1.80 To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3 V Parameter Supply Voltage Variation (VDD ) Frequency Range Standard Frequency Absolute Pulling Range (APR) Control Voltage Range Supply Current 1.5 MHz Fo < 20 MHz 20 MHz Fo < 50 MHz 80 MHz 50 MHz Fo 80 MHz < Fo < 160 MHz 170 MHz 160 MHz Fo Output Level (CMOS) Output High (Logic “1”) Output Low (Logic “0”) Transition Time: Rise/Fall Time+ 1.5 MHz Fo < 20 MHz 20 MHz Fo < 50 MHz 80 MHz 50 MHz Fo 80 MHz < Fo 170 MHz Start Time Tri-State(Input to Pin 2) Enable (High voltage or floating) Disable (Low voltage or GND) Period Jitter (Pk-Pk) RMS Phase Jitter (Integrated 12kHz~20MHz) Linearity Modulation Bandwidth (BW) 1.5 MHz Fo 170 MHz Input Impedance 1.5 MHz Fo 170 MHz 100 Hz Phase Noise@30.72MHz 1 kHz 10 kHz Min. VDD-5% 1.5 Max. VDD+5% 170 Unit V MHz 10,20,25,27,32.768,35.328,38.88,61.44,122.88, 153.6 _ ±50 0.3 3.0 10 20 30 40 50 _ _ _ _ _ _ 5 4 3 2 5 2.31 _ _ _ _ _ 0.99 40 1 10 15 _ 10000 _ _ V 0.33 _ _ _ _ _ -55 mA _ 2.97 Aging (@ 25°C 1st year) Storage Temp. Range ppm V -115 -135 -150 nSec mSec V pSec pSec % kHz kΩ dBc/Hz ±3 125 ppm °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. + Transition times are measured between 10% and 90% of VDD, with an output load of 15pF. FREQ. STABILIT Y vs. TEMP. RANGE Temp. (°C) ppm ±25 ±50 -10 ~ +60 -20 ~ +70 -40 ~ +85 * ○: Available △:Conditional X: Not available * Inclusive of calibration @ 25 °C, operating temperature range, input voltage variation, load variation, aging (1st year), shock, and vibration Note: not all combination of options are available. Other specifications may be available upon request. 68 Specifications subject to change without notice. www.taitien.com sales@taitien.com.tw Rev(20)09/2019
VTKUPLIANF-32.768000 价格&库存
很抱歉,暂时无法提供与“VTKUPLIANF-32.768000”相匹配的价格&库存,您可以联系我们找货
