TXECADSANF-26.000000 数据手册
TX Type
3.2 x 2.5 mm SMD Voltage Controlled Temperature
ature
Compensated Crystal Oscillator
Actual Size
FEATURE
- Typical 3.2 x 2.5 x 0.9 mm SMD.
- For automatic assembly.
- Compactness and lightweight.
- Low power consumption.
- VCTCXO available.
- Low thickness
TYPICAL APPLICATION
- GPS
- WiMAX, WLAN
- Mobile Phone
RoHS Compliant
DIMENSION (mm)
SOLDER PAD LAYOUT (mm)
[ BOTTOM VIEW ]
[ TOP VIEW ]
0.1μF
2.30±0.15
3.20±0.15
1.70±0.15
2.50±0.15
#2
#2
#1
#1
1.80
#4
#3
0.90
#3
0.60±0.10
#4
Pin#
1
0.90±0.10
[ SIDE VIEW ]
0.25±0.04
0.70±0.10
2.40
Function
Vcon:VC-TCXO
GND / NC:TCXO
GND
Output
VDD
2
3
4
1.00
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
ELECTRICAL SPECIFICATION
3.3 / 3.0 / 2.8 V
Parameter
Supply Voltage Variation (VDD)
Frequency Range
Standard Frequency
Frequency Tolerance*
Frequency stability
Vs Supply Voltage (±5%) change
Vs Load (±10%) change
Vs Aging (@1st year)
Supply Current 10 MHz Fo 26 MHz
26 MHz Fo 52 MHz
Output Level (Clipped sine wave)
Load
Control Voltage Range (VCTCXO)
Pulling Range (VCTCXO)
Vc Input Impedance (VCTCXO)
Phase Noise @ 19.2 MHz
1.8 V
2.5 V
Min.
Max.
Min.
Max.
Min.
Max.
2.66
3.465
2.375
2.625
1.71
1.89
10
52
10
52
10
52
10, 12.8, 13, 16.367667, 16.368, 16.369, 19.2, 19.44, 20, 25, 26, 27, 30
30.72, 32, 38.4
_
±2.0
_
±2.0
_
±2.0
_
_
_
_
_
±0.2
±0.2
±1.0
1.5
2.0
_
_
_
_
_
±0.2
±0.2
±1.0
1.5
2.0
_
_
_
_
_
±0.2
±0.2
±1.0
1.5
2.0
_
100 Hz
1 kHz
10 kHz
_
0.8
10KΩ//10pF
0.5
2.5
_
±5.0
_
500
0.8
10KΩ//10pF
0.4
2.4
_
±5.0
_
500
0.8
10KΩ//10pF
0.3
1.5
_
±5.0
_
500
-115
-135
-148
-115
-135
-148
-115
-135
-148
_
Start time
Storage Temp. Range
_
_
2
85
-40
-40
2
85
_
-40
Unit
V
MHz
ppm
ppm
ppm
mA
Vp-p
V
ppm
kΩ
dBc/Hz
2
85
mSec
°C
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position.
Frequency at 25°C, 1 hour after reflow.
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
±0.5
±1.0
±1.5
±2.0
±2.5
-20 ~ +70
-30 ~ +85
-40 ~ +85
○: Available Χ:Conditional X: Not available
Note: not all combination of options are available. Other specifications may be available upon request.
6SHFL¿FDWLRQVVXEMHFWWRFKDQJHZLWKRXWQRWLFH
www.taitien.com
sales@taitien.com.tw
Rev(14)01/2020
87
TXECADSANF-26.000000 价格&库存
很抱歉,暂时无法提供与“TXECADSANF-26.000000”相匹配的价格&库存,您可以联系我们找货
