CT-425.000MBB-T
CT-425.000MBB-T
    TXC(台晶)
    SMD-6
    有源晶振 3.3V 425MHz SMD-6
CT-425.000MBB-T 数据手册
Think of Frequency Think of SMD LVDS SAW Oscillators - Differential Output 5.0 x 3.2 x 1.2 mm CT Series Oscillators Series come visit our site http://www.txccorp.com Features .SAW base solution. .3.3V and 2.5V operation available. 1H TSY 500 C T B 156.2 .LVDS output, output frequencies 150 MHz to 700 MHz. .Excellent low phase noise and jitter. .Tri-State function available. .Applications : Fibre Channel, Gigabit Ethernet, Serial ATA, Serial Attached SCSI, PCI-Express, SDH / SONET. .RoHS Compliant / Pb Free. Item / Type CT Output Type LVDS Output Load 100 Ω Oscillation Mode Fundamental Supply Voltage 2.5 V , 3.3 V Frequency Range 150 ~ 700 MHz Overall Frequency Stability * ± 100 ppm , or specify Operating Temperature Range -10 ~ + 70 ℃ , - 5 ~ + 85 ℃ , or specify Storage Temperature Range - 55 ~ + 125 ℃ Voltage Vol(Min.) / Voh (Max.) 0.9 V / 1.6 V Rise ( Tr ) / Fall ( Tf ) Time ( 20 % ~ 80 % ) 1 nS Max. Supply Current 80 mA Max. Symmetry 45 ~ 55 % Start-up Time 10 mS Max. Phase Jitter ( 12 KHz ~ 20 MHz ) 1 pS Max. Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com Electrical Specifications * Inclusive of frequency tolerance at 25 ℃, variation over temperature, supply voltage variation, aging and vibration. Dimensions 5.0±0.2 5 4 1 2 3 1.2±0.2 3.2±0.2 6 Land Pattern: 1.27 6 0.89 5 4 2 3 5 4 1.20 1 6 2.60 1.60 0.64 0.90 Pin Function: 1. Enable Control or NC 2. Enable Control or NC 3. GND 4. OUT 5. OUTN 6. VDD 1.27 1.27 Pad dimension tolerance ±0.2 mm 12 3 Power Supply Decoupling Capacitor is Required. Pad dimension tolerance ±0.2 mm Units: mm 71
CT-425.000MBB-T 价格&库存
很抱歉,暂时无法提供与“CT-425.000MBB-T”相匹配的价格&库存,您可以联系我们找货
