LFOCXO063804BULK
LFOCXO063804BULK
    IQD
    SMD-6
    有源晶振 38.88MHz 3.3V SMD-6
LFOCXO063804BULK 数据手册
OCXO Specification Part No. + Packaging: LFOCXO063804Bulk Customer Part: Description Oven controlled crystal oscillator (OCXO) with voltage control on a FR4 base with a metal lid. Model IQOV-162-3 Model Issue number 2 Frequency Parameters Frequency 38.880MHz Frequency Tolerance ±500.00ppb ±20.00ppb Frequency Stability Operating Temperature Range Ageing -40.00 to 85.00°C ±5ppb max per day, ±500ppb max per year Frequency Tolerance (measurement referenced to frequency observed with TA=25°C, Vs=3.3V, VC=1.65V and after 15 minutes of operation, within 30 days after ex-works): ±500ppb Frequency Stability: TA varied over temperature, measurement referenced to frequency observed with fref=(fmax+fmin )/2, Vs=3.3V, VC=1.65V, load=15pF, temperature variable speed less than 2°C per minute. Ageing: Vs, VC, TA constant measurement referenced to frequency observed with TA=25°C, Vs= 3.3V, VC=1.65V and after 30 days of operation. Supply Voltage Variation (measurement referenced to frequency observed with TA=25°C, Vs varied from 3.13V to 3.47V, VC =1.65V and load=15pF): ±10ppb max Load Variation (5% load change measurement referenced to frequency observed with TA=25°C, Vs=3.3V, VC =1.65V and load=15pF): ±10ppb max Short Term Stability - Allan Variance (temperature stability, no EMI\EMC or other interference,test after power for 1hr ref. to 25°C; 1s, using PN9000 equipment): 0.1ppb max / 1sec Outline (mm) Electrical Parameters 3.3V ±5% Supply Voltage Current Draw: Warm up: 600mA max Steady state (@ 25°C): 300mA max Warm-Up Time (@ 25°C, F
LFOCXO063804BULK 价格&库存
很抱歉,暂时无法提供与“LFOCXO063804BULK”相匹配的价格&库存,您可以联系我们找货
