ODEMDLLTNF-100.000000 数据手册
OD-M Type High Frequency and Ultra
Low Noise
7.0 x 5.0mm SMD Crystal Oscillator
Actual Size
FEATURE
- Low Power Supply Voltage: 3.3, 2.5 and 1.8V Supply Options
- Clock Output: LVPECL, LVDS, CML, HCSL and LVCMOS
- Output Frequency Support from 15MHz to 2.1GHz
- Ultra Low Noise, Phase Jitter < 300 fs
(Typical: 150 fs at 12kHz to 20MHz Frequency Offsets)
- Tri-state Enable / Disable Mode.
- Temperature Range: -40 to 85。C
- Pb-free/RoHS Compliant
RoHS Compliant
TYPICAL APPLICATION
- SONET/SDH, Gigabit Ethernet
- SD/HD Video
- Storage Area Networking (SAN)
- FPGA Clock Generation
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ TOP VIEW ]
#1
#2
#7
#8
#3
#3
#2
1.40±0.20
Pin#
0.7
1.70±0.15
[ SIDE VIEW ]
1
2
3
4
5
6
7
8
GND
#1
VDD
0.1µF
6
NC
3.50
#8
#6
1.3
#7
#5
1.6
#4
#4
(LVPECL/LVDS/CML)
5.08
1.00
1.28±0.20
#5
[ TOP VIEW ]
5.7
5.08±0.20
3.46±0.20
5.00±0.20
#6
[ BOTTOM VIEW ]
7.00±0.20
PIN ASSIGNMENTS
CMOS
NC
OE
GND
Output
NC
VDD
NC
NC
5
OUT
4
7
8
1
2
NC
OE
NC
3
GND
(CMOS)
1.18
Functions
LVPECL/LVDS/CML
NC
OE
GND
Output
Comp. Output
VDD
NC
NC
OUT-
1.7
VDD
1.6
To ensure optimal oscillator performance, place
a by-pass capacitor of 0.1μF as close to the part
as possible between Vdd and GND pads.
6
NC
NC
5
OUT
4
7
8
1
2
NC
OE
NC
3
GND
ELECTRICAL SPECIFICATION
Parameter
Supply Voltage Variation (VDD) ±10%
Frequency Range
Standard Frequency
Supply Current
Output Level
Output High
Output Low
Transition Time
(20%-80%)
Rise Time / Fall Time
Duty Cycle
Startup Time
Tri-State Mode (Input to Pin 2)
Standby Current
Phase Noise
Enable
Disable
100kHz offset
1MHz offset
20MHz offset
RMS Phase Jitter (12kHz to 20MHz)
Period Jitter
LVPECL
Max.
Min.
2.5V
Max.
VDD-10%
VDD+10%
VDD-10%
VDD+10%
15
2100
15
2100
100, 106.25, 125, 156.25, 187.5, 200, 212.5, 266, 300, 312.5, 400
_
_
110
95
VDD-1.165
VDD-0.8
VDD-1.165
VDD-0.8
VDD-2.0
VDD-1.55
VDD-2.0
VDD-1.55
unit
V
MHz
mA
V
_
0.35
_
0.35
nSec
45
_
55
8
_
45
_
55
8
_
mSec
0.7 x VDD
_
_
Typ.
1kHz offset
10kHz offset
At VDD=3.3V, Fout=873.515MHz
Min.
3.3V
-106
-115
-123
-133
-150
150
_
0.3 x VDD
110
Max.
_
_
_
_
_
300
50
0.7 x VDD
_
_
Typ.
-106
-115
-123
-133
-150
150
_
0.3 x VDD
95
Max.
_
_
_
_
_
300
50
V
mA
dBc/Hz
fs
ps
Note: not all combination of options are available. Other specifications may be available upon request.
60
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(5)08/2019
Parameter
Supply Voltage Variation (VDD) ±5%
Frequency Range
Standard Frequency
Supply Current
Output Level
Output High
Output Low
Transition Time
(20%-80%)
Min.
_
Max.
_
3.63
15
2.97
2100
_
0.9
Standby Current
Phase Noise
100kHz offset
1MHz offset
10MHz offset
Output Level
Transition Time
(20%-80%)
100kHz offset
1MHz offset
10MHz offset
Period Jitter
Parameter
Supply Voltage Variation (VDD)±10%
Frequency Range
Supply Current
Output High
Output Level
Output Low
Transition Time Rise Time
(20% - 80%)
Fall Time
Duty Cycle
Startup Time
Tri-State mode Enable
(Input to Pin 2) Disable
Stand by Current Disable
Output Load
Phase Noise
1kHz offset
10kHz offset
At VDD=3.3V,
fout=
100kHz offset
873.515MHz
1MHz offset
10MHz offset
RMS Phase Jitter (12KHz to 20MHz)
Period Jitter
0.66
0.7 x VDD
V
0.35
nSec
55
8
_
mSec
0.3 x VDD
90
Max.
_
_
_
_
_
0.7 x VDD
_
_
Typ.
300
150
_
50
300
50
Max.
_
3.63
15
2.97
2100
45
_
0.7 x VDD
_
_
Min.
_
Typ.
150
_
2.75
2100
0.35
55
8
_
45
_
0.3 x VDD
90
Max.
_
_
_
_
_
-107
-117
-125
-135
-150
150
_
0.7 x VDD
_
_
fs
ps
unit
Min.
Max.
1.71
_
1.89
_
15
2100
Typ.
300
150
_
50
Min
2.25
15
15
0.66
MHz
mA
V
0.35
0.35
nSec
55
8
_
45
_
55
8
_
mSec
300
50
0.7 x VDD
_
_
Typ.
-107
-117
-125
-135
-150
150
_
HCSL
2.5V
Max.
2.97
700
115
700
1.15
0.15
0.4
0.4
55
8
0.3 x VDD
V
_
0.3 x VDD
80
Max.
_
_
_
_
_
-107
-117
-125
-135
-150
dBc/Hz
50
_
_
90
80
70
VDD
VDD-0.085
VDD
VDD-0.085
VDD
VDD-0.32
VDD-0.6
VDD-0.32
VDD-0.6
VDD-0.32
_
V
mA
300
1.8V
Max.
_
2.25
15
0.3 x VDD
70
Max.
_
_
_
_
_
-106
-115
-123
-133
-150
CML
2.5V
Min.
_
_
0.3 x VDD
80
Max.
_
_
_
_
_
-106
-115
-123
-133
-150
3.3V
Min.
3.63
15
15
mA
_
Typ.
1kHz offset
10kHz offset
MHz
70
1.6
_
45
_
0.7 x VDD
_
_
Enable
Disable
Standby Current
Phase Noise
V
55
8
_
VDD-0.085
VDD-0.6
2100
0.35
_
Duty Cycle
Startup Time
15
_
3.3V
Output High
Output Low
1.89
_
45
_
Parameter
Frequency Range
Standard Frequency
Supply Current
1.71
_
55
8
_
150
_
Period Jitter
2.75
2100
Max.
0.35
Typ.
2.25
15
unit
Min.
_
-106
-115
-123
-133
-150
1kHz offset
10kHz offset
1.8V
Max.
_
45
_
0.7 x VDD
_
_
Enable
Disable
Min.
_
_
_
90
80
_
_
1.6
1.6
_
_
0.9
0.9
_
Duty Cycle
Startup Time
LVDS
2.5V
3.3V
0.3 x VDD
70
Max.
_
_
_
_
_
fs
50
ps
Unit
Min.
1.71
15
15
0.66
0.7xVDD
Max.
1.89
700
94
2100
1.15
0.15
0.4
0.4
55
8
0.3 x VDD
94
115
0.7x VDD
Typ.
Max.
Typ.
Max.
Typ.
Max.
-87
-110
-127
-138
-153
150
300
50
-87
-110
-127
-138
-153
150
300
50
-87
-110
-127
-138
-153
150
300
50
100
50 ohms to GND
dBc/Hz
300
1.8V
Max.
2.75
700
100
2100
1.15
0.15
0.4
0.4
55
8
0.3 x VDD
V
mA
V
MHz
mA
V
V
nSec
nSec
mSec
V
V
mA
dBc/Hz
dBc/Hz
dBc/Hz
dBc/Hz
dBc/Hz
fs
ps
www.taitien.com
Rev(5)
61
Parameter
Frequency Range
Standard Frequency
Supply Current
Min.
_
Max.
_
3.63
15
2.97
250
_
0.9 x VDD
_
Output Level
Output High
Output Low
Transition Time
(20%-80%)
Duty Cycle
Fout 100MHZ
Startup Time
CMOS
2.5V
3.3V
Enable
Disable
Period Jitter
Min.
_
2.25
15
1.8V
Max.
_
2.75
250
unit
Min.
Max.
1.71
_
1.89
_
15
250
90
80
70
_
_
_
0.9 x VDD
0.9 x VDD
_
_
0.1 x VDD
0.1 x VDD
0.1 x VDD
_
1.2
_
1.5
_
2
45
40
_
55
60
8
_
45
40
_
55
60
8
_
45
40
_
55
60
8
_
0.7 x VDD
_
_
0.3 x VDD
100
0.7 x VDD
_
_
0.3 x VDD
100
0.7 x VDD
_
_
0.3 x VDD
100
V
MHz
mA
V
nSec
mSec
V
mA
FREQ. STABILITY vs. TEMP. RANGE
Temp. (°C)
ppm
±20
±25
±30
±50
-20~+70
-40~+85
62
X
○: Available △:Conditional X: Not available
* Inclusive of calibration @ 25 °C, operating temperature range, input
voltage variation, load variation, aging (1st year), shock, and vibration
www.taitien.com
Rev(5)
