LFSPXO019083BULK
LFSPXO019083BULK
    IQD
    SMD7050_4P
    有源晶振 32MHz 5V 0℃~+70℃ HCMOS, TTL
LFSPXO019083BULK 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO019083Bulk Customer Part: Description Standard 7 x 5mm crystal oscillator in a ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPS-72 Model Issue number 14 Frequency Parameters Frequency 32.0MHz Frequency Stability ±50.00ppm Operating Temperature Range Ageing 0.00 to 70.00°C ±3ppm per year max Electrical Parameters 5.0V ±10% Supply Voltage Current Draw 30.000mA Note: parameters are referenced to 15pF load Outline (mm) Output Details HCMOS/TTL Output Compatibility Drive Capability 15pF std, 50pF max Rise and Fall Time 6.0ns max 45/55% Duty Cycle Start up time: 10ms max 1.1ms typ to 90% of final amplitude (under ideal conditions @ 25°C) Output Control Standby Operation: Logic ‘1’ (>70% Vs) to pad 1 enables oscillator output. Logic ‘0’ (
LFSPXO019083BULK 价格&库存
很抱歉,暂时无法提供与“LFSPXO019083BULK”相匹配的价格&库存,您可以联系我们找货
