LFTVXO063703BULK
LFTVXO063703BULK
    IQD
    SMD-8
    有源晶振 19.2MHz 3.3V SMD-8
LFTVXO063703BULK 数据手册
TCVCXO Specification Part No. + Packaging: LFTVXO063703Bulk Customer Part: Description Temperature compensated voltage controlled crystal oscillator (TCVCXO) 8 pad version Model Model Issue number IQXT-200-3-B 1 Frequency Parameters Frequency 19.20MHz Frequency Tolerance Tolerance Condition Frequency Stability ±0.50ppm @ 25°C, 3.3V & VC=1.65V ±0.28ppm Operating Temperature Range Ageing -20.00 to 70.00°C ±0.02ppm max per day, ±1.0ppm max per year Frequency Tolerance (measurement referenced to frequency observed with TA=25°C, Vs=3.3V, VC=1.65V and within 30 days after ex-works): ±0.5ppm Frequency Stability: TA varied over temperature, measurement referenced to frequency observed with TA=25°C, Vs=3.3V, VC=1.65V, load=15pF and temperature variable speed less than 2°C per minute. Ageing: TA=25°C, Vs=3.3V, VC=1.65V and after 1hr of operation. Supply Voltage Variation (measurement referenced to frequency observed with TA=25°C, Vs varied from 3.13V to 3.47V, VC=1.65V and load=15pF): ±0.1ppm max Load Variation (5% load change measurement referenced to frequency observed with TA=25°C, Vs=3.3V, VC=1.65V and load=15pF): ±0.1ppm max Short Term Stability (@ 25°C after 10mins power on): 5E-10/s typ @ 10MHz Outline (mm) Electrical Parameters 3.3V ±5% Supply Voltage Current Draw 10.000mA Current: TA=25°C, Vs=3.3V, VC=1.65V and load=15pF Frequency Adjustment Pulling ±10ppm to ±15ppm Control Voltage 1.65V ±1.65V Linearity: ±10% max Slope: Positive Input Impedance: 100kΩ min Output Details HCMOS Output Compatibility Drive Capability 15pF Rise and Fall Time 8.0ns max 45/55% Duty Cycle Output Low (@ Vs=3.3V, load=15pF): 0.4V max Output High (@ Vs=3.3V, load=15pF): 2.4V min Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 14:44 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 TCVCXO Specification Part No. + Packaging: LFTVXO063703Bulk Customer Part: Noise Parameters Phase Noise (@ 10MHz typ): -90dBc/Hz @ 10Hz -115dBc/Hz @ 100Hz -135dBc/Hz @ 1kHz -145dBc/Hz @ 10kHz -148dBc/Hz @ 100kHz -150dBc/Hz @ 1MHz Environmental Parameters Storage Temperature Range: -55 to 105°C ESD Level: HBM, Class 2: 2000V to 4000V, JEDEC JS-001-2010 Machine Model, Class B: 200V to 400V, JEDEC JS-001-2010 Shock: IEC 60068-2-27, Test Ea: 100G acceleration for 6ms, sinewave, in 3 mutually perpendicular planes Vibration: IEC 60068-2-6, Test Fc: 10Hz-2000Hz, 0.75mm amplitude, 10G acceleration, 30mins per cycle, in 3 mutually perpendicular planes, test duration 2hrs Manufacturing Details Moisture Sensitivity Level: 2 Maximum Reflow Temperature: 260°C (30secs max) Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant 2 Packaging Details Pack Style: Bulk Pack Size: 1 Loose in bulk pack Alternative packing option available Outline (mm) -B = 8 pad version Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 4 Aug 21 14:44 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFTVXO063703BULK 价格&库存
很抱歉,暂时无法提供与“LFTVXO063703BULK”相匹配的价格&库存,您可以联系我们找货
