8W-48.000MBE-T
8W-48.000MBE-T
    TXC(台晶)
    SMD-4
    有源晶振 48MHz 3.3V SMD-4
8W-48.000MBE-T 数据手册
8W MHz CMOS Oscillator Features Applications Frequency range : 4MHz to 125MHz Compact and thin SMD seam sealing ceramic package Supply voltage : 1.8V ~ 3.3V CMOS output Tri-state function available External dimensions (mm) L : 2.5 x W : 2.0 x H : 0.8 RoHS compliant & Pb free Mobile phone, Wearables Networking, Server, Storage Wireless communications Fibre channel, Ethernet, SATA, SAS, PCI-E, USB, WLAN, BT Notebook, HDD, SSD, Graphics card, Computer peripherals Audio, Video, Gaming, DSC, IP CAM, Portable consumer products Electrical Characteristics Item 8W Frequency Range (F0) 4MHz ~ 125MHz Frequency Stability (Fstab) ±50ppm, ±25ppm Operating Temperature Range (T OTR) Supply Voltage (VDD) Current Consumption (IDD) 1.8V, 2.5V, 3.3V Output Load (CL) 15 pF Output Voltage High (VOH) 90% VDD Min. Output Voltage Low (VOL) 10% VDD Max. Rise & Fall Time (Tr / Tf) 5 ns Max. Duty Cycle 45% ~ 55% Start-up Time 5 ms Max. Enable Voltage High, Logic "1" 70% VDD Min. Enable Voltage Low, Logic "0" 30% VDD Max. Storage Temperature Range (TSTR) VDD ± 10% 10 mA Max. CMOS Aging (Faging) Note [1] -40°C ~ +85°C Output Type Phase Jitter, RMS Conditions 1 ps Max. ±3 ppm Max. 10% ~ 90% of VDD Input to Pin1 Note [2] Note [3] at 25°C±3°C,first year -55°C ~ +125°C Notes: [1] Inclusive of frequency tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, supply voltage, and load. [2] Output will be enable if Pin1 is Logic "1" or Open; Output will be disable if Pin1 is Logic "0". [3] Freq. 10MHz~40MHz, integrated 12kHz~5MHz; Freq. >40MHz, integrated 12kHz~20MHz. Rev. 1.02-a Page 1 www.txccrystal.com 8W MHz CMOS Oscillator Dimensions (Unit: mm) Ordering Information 8W - 30.000M - B E - T Frequency in Hz Packaging Method T Please contact us for available frequencies Supply Voltage B C D Rev. 1.02-a Tape & Reel Frequency Stability 3.3 V 2.5 V 1.8 V A D E Page 2 ± 25 ppm (-10˚C ~ +70˚C) ± 25 ppm (-40˚C ~ +85˚C) ± 50 ppm (-40˚C ~ +85˚C) www.txccrystal.com 8W MHz CMOS Oscillator Packing (Unit: mm) (Unit: mm) Reflow Profile Solder melting point : 220°C ± 10°C, 60 sec. Min. Peak temperature : 260°C ± 10°C, 10 sec. Min. (°C) 10 sec 260 220 180 150 120 sec Rev. 1.02-a 60 sec Page 3 Time (sec) www.txccrystal.com
8W-48.000MBE-T
物料型号:8W MHz CMOS Oscillator
器件简介:这是一种紧凑型、超薄的CMOS振荡器,频率范围从4MHz到125MHz,适用于多种应用领域。
引脚分配:1号引脚为使能控制,2号引脚为地,3号引脚为输出,4号引脚为电源。
参数特性: - 频率范围:4MHz至125MHz - 频率稳定性:±50ppm或±25ppm(注1) - 工作温度范围:-40°C至+85°C - 供电电压:1.8V、2.5V或3.3V - 最大电流消耗:10mA - 输出类型:CMOS - 输出负载:15pF - 高电平输出电压:至少90% VDD - 低电平输出电压:最多10% VDD - 上升/下降时间:最多5ns - 占空比:45%至55% - 启动时间:最多5ms - 使能电压高/低:至少70% VDD/最多30% VDD(注2) - 相位抖动:最多1ps(注3) - 老化:最多±3ppm(第一年在25°C±3°C)
功能详解:该振荡器具有三态功能,可在1.8V至3.3V的供电电压下工作,并且符合RoHS和无铅标准。它采用SMD密封陶瓷封装。
应用信息:适用于网络、服务器、存储、无线通信、移动电话、可穿戴设备、光纤通道、以太网、SATA、SAS、PCI-E、USB、WLAN、蓝牙等。
封装信息:外部尺寸为长2.5mm x 宽2.0mm x 高0.8mm。
8W-48.000MBE-T 价格&库存
很抱歉,暂时无法提供与“8W-48.000MBE-T”相匹配的价格&库存,您可以联系我们找货
