SIT1602AI-22-XXE-54.000000
    SITIME(赛特时脉)
    SMD3225_4P
    有源晶振 54MHz ±25ppm 2.25V~3.63V SMD-4
SIT1602AI-22-XXE-54.000000 数据手册
SiT1602 Low Power, Standard Frequency Oscillator The Smart Timing Choice The Smart Timing Choice Features Applications  51 standard frequencies between 3.75 MHz and 77.76 MHz  100% pin-to-pin drop-in replacement to quartz-based XO  Excellent total frequency stability as low as ±20 PPM  Low power consumption of 3.6 mA typical  Standby mode for longer battery life  Fast startup time of 5 ms  LVCMOS/HCMOS compatible output  Industry-standard packages: 2.0 x 1.6, 2.5 x 2.0, 3.2 x 2.5, 5.0 x 3.2, 7.0 x 5.0 mm x mm  Instant samples with Time Machine II and field programmable oscillators  Pb-free, RoHS and REACH compliant  Ideal for DSC, DVC, DVR, IP CAM, Tablets, e-Books, SSD, GPON, EPON, etc  Ideal for high-speed serial protocols such as: USB, SATA, SAS, Firewire, 100M / 1G / 10G Ethernet, etc. Electrical Characteristics[1] Parameter and Conditions Symbol Min. Typ. Max. Unit Condition Frequency Range Output Frequency Range f (Refer to the frequency list page 10) MHz 51 standard frequencies between 3.75 MHz and 77.76 MHz Frequency Stability and Aging Frequency Stability F_stab -20 – +20 PPM -25 – +25 PPM – +50 PPM -50 Inclusive of Initial tolerance at 25°C, 1st year aging at 25°C, and variations over operating temperature, rated power supply voltage and load. Operating Temperature Range Operating Temperature Range T_use -20 – +70 °C Extended Commercial -40 – +85 °C Industrial Supply Voltage and Current Consumption Supply Voltage Current Consumption Vdd Idd 1.62 1.8 1.98 V 2.25 2.5 2.75 V Contact SiTime for 1.5V support 2.52 2.8 3.08 V 2.7 3.0 3.3 V 2.97 3.3 3.63 V 2.25 – 3.63 V – 3.8 4.5 mA No load condition, f = 20 MHz, Vdd = 2.8V to 3.3V – 3.6 4.2 mA No load condition, f = 20 MHz, Vdd = 2.5V – 3.4 3.9 mA No load condition, f = 20 MHz, Vdd = 1.8V – 4 mA Vdd = 2.5V to 3.3V, OE = GND, output is Weakly Pulled Down Vdd = 1.8 V. OE = GND, output is Weakly Pulled Down OE Disable Current I_OD – – – 3.8 mA Standby Current I_std – 2.6 4.3 A ST = GND, Vdd = 2.8V to 3.3V, Output is Weakly Pulled Down – 1.4 2.5 A ST = GND, Vdd = 2.5V, Output is Weakly Pulled Down 0.6 1.3 A ST = GND, Vdd = 1.8V, Output is Weakly Pulled Down – LVCMOS Output Characteristics Duty Cycle Rise/Fall Time DC 45 – 55 % Tr, Tf – 1 2 ns All Vdds Vdd = 2.5V, 2.8V, 3.0V or 3.3V, 20% - 80% – 1.3 2.5 ns Vdd =1.8V, 20% - 80% – – 2 ns Output High Voltage VOH 90% – – Vdd IOH = -4 mA (Vdd = 3.0V or 3.3V) IOH = -3 mA (Vdd = 2.8V and Vdd = 2.5V) IOH = -2 mA (Vdd = 1.8V) Vdd = 2.25V - 3.63V, 20% - 80% Output Low Voltage VOL – – 10% Vdd IOL = 4 mA (Vdd = 3.0V or 3.3V) IOL = 3 mA (Vdd = 2.8V and Vdd = 2.5V) IOL = 2 mA (Vdd = 1.8V) Input High Voltage VIH 70% – – Vdd Input Low Voltage VIL – – 30% Vdd Pin 1, OE or ST Input Pull-up Impedence Z_in – 87 100 k Pin 1, OE logic high or logic low, or ST logic high 2 – – M Pin 1, ST logic low Input Characteristics Pin 1, OE or ST Note: 1. All electrical specifications in the above table are specified with 15 pF output load and for all Vdd(s) unless otherwise stated. SiTime Corporation Rev. 1.2 990 Almanor Avenue Sunnyvale, CA 94085 (408) 328-4400 www.sitime.com Revised March 26, 2015 SiT1602 Low Power, Standard Frequency Oscillator The Smart Timing Choice The Smart Timing Choice Electrical Characteristics[1] (continued) Parameter and Conditions Symbol Min. Typ. Max. Unit Condition Startup and Resume Timing Startup Time Enable/Disable Time T_start – – 5 ms Measured from the time Vdd reaches its rated minimum value T_oe – – 130 ns f = 110 MHz. For other frequencies, T_oe = 100 ns + 3 * cycles Resume Time T_resume – – 5 ms Measured from the time ST pin crosses 50% threshold Startup Time T_start – – 5 ms Measured from the time Vdd reaches its rated minimum value T_jitt – 1.76 3 ps f = 75 MHz, Vdd = 2.5V, 2.8V, 3.0V or 3.3V – 1.78 3 ps f = 75 MHz, Vdd = 1.8V – 0.5 0.9 ps f = 75 MHz, Integration bandwidth = 900 kHz to 7.5 MHz – 1.3 2 ps f = 75 MHz, Integration bandwidth = 12 kHz to 20 MHz Jitter RMS Period Jitter RMS Phase Jitter (random) T_phj Notes: 1. All electrical specifications in the above table are specified with 15 pF output load and for all Vdd(s) unless otherwise stated. Pin Description Pin Symbol OE/ ST 1 22 H or Open[2]: specified frequency output L: output is high impedance. Only output driver is disabled. Standby H or Open[2]: specified frequency output L: output is low (weak pull down). Device goes to sleep mode. Supply current reduces to I_std. 2 GND Power Electrical ground[3] 3 OUT Output Oscillator output 4 Top View Functionality Output Enable VDD Power OE/ST 1 4 VDD GND 2 3 OUT [3] Power supply voltage Notes: 2. A pull-up resistor of
物料型号:SiT1602
器件简介:SiT1602是一款低功耗的标准频率振荡器,提供51种标准频率范围在3.75 MHz至77.76 MHz之间。它具有100%的引脚对引脚替换石英基XO的能力,并且拥有出色的总频率稳定性,低至±20 PPM。
引脚分配: - 1. OE/ST:输出使能/待机模式 - 2. GND:电源地 - 3. OUT:输出 - 4. VDD:电源电压
参数特性: - 工作频率范围:3.75 MHz至77.76 MHz - 频率稳定性:在特定条件下,初始容差、第一年老化和工作温度、电源电压及负载变化下的总频率稳定性为±20 PPM至±50 PPM - 工作温度范围:-20至+70°C(扩展商业级)或-40至+85°C(工业级) - 电源电压:1.62至3.63V,具体取决于型号 - 典型功耗:3.6 mA - 待机模式电流:根据VDD电压不同,从0.6至4.3 µA - 输出高电平电压(VOH):达到90% VDD - 输出低电平电压(VOL):至少10% VDD
功能详解: - 快速启动时间:5毫秒 - 待机模式:延长电池寿命 - LVCMOS/HCMOS兼容输出 - 可编程驱动强度,优化特定应用的时钟上升/下降时间
应用信息: - 适用于DSC、DVC、DVR、IP摄像头、平板电脑、电子书、SSD、GPON、EPON等 - 适用于高速串行协议,如USB、SATA、SAS、火线、100M/1G/10G以太网等
封装信息: - 行业标准封装尺寸:2.0 x 1.6 mm、2.5 x 2.0 mm、3.2 x 2.5 mm、5.0 x 3.2 mm、7.0 x 5.0 mm
SIT1602AI-22-XXE-54.000000 价格&库存
很抱歉,暂时无法提供与“SIT1602AI-22-XXE-54.000000”相匹配的价格&库存,您可以联系我们找货
  • 1+13.079561+1.67971
  • 10+11.3548510+1.45822
  • 25+10.7350725+1.37862
  • 50+10.2913950+1.32164
  • 100+9.86631100+1.26705
  • 250+9.33030250+1.19822
  • 500+8.94467500+1.14870
  • 1000+8.575011000+1.10122
  • 2500+8.110032500+1.04151
库存:7095
    • 10+4.52000
    • 35+4.06800
    • 100+3.52000
    • 1000+3.25600
    • 4000+3.13500
    库存:6000
