come visit our site http://www.txccorp.com
SMD TCXO
3.2 X 2.5 X 1.0 mm
7Q Series
Oscillators
Series
Think of Frequency Think of
Features
.Temperature Stability: ± 0.5 ppm ~ ± 2.0 ppm.
.Operating Temperature Range: - 30 ℃ ~ 85 ℃.
BT
.Supply Voltage: 1.8 V ~ 3.3 V.
A
.Voltage Control Function Available.
P1
2
k0
3
T3
.Frequencies: 16.367667 MHz, 16.368 MHz, 16.369 MHz, 16.8 MHz, 19.2 MHz,
20 MHz, 26 MHz, 33.6 MHz, 38.4 MHz, 40 MHz.
.Applications: GPS, WiMAX, Cellular and Wireless Communications.
.RoHS Compliant / Pb Free.
Electrical Specifications
7Q
Clipped Sinewave
Output Load
10KΩ // 10 pF
Oscillation Mode
Fundamental
Supply Voltage
1.8 ~ 3.3 V
Frequency Range
13 ~ 52 MHz
Clipped Sinewave Output Voltage
0.8 Vp-p Min.
Vs. Temperature ( - 30 ~ + 85 ℃ )
Frequency Stability
± 0.2 ppm Max.
Vs. Supply Voltage ( Vcc = Typical ± 0.1 V )
± 0.2 ppm Max.
Frequency Tolerance at 25 ℃ after 2 Reflows with Typical
Applied to Auto Frequency Control Pin
Slope of Frequency Drift
Storage Temperature Range
Auto Frequency Control ( AFC ) Range *
Supply Current
Start-up Time
Harmonics
Phase Noise at 1 kHz offset
Aging ( at 25 ℃ )
± 0.5 / ± 2.0 ppm
Vs. Load ( Load varies ± 10 % )
± 2.5 ppm Max.
± 0.1 ppm / ℃ Typical ; ± 0.5 ppm / ℃ Max.
- 40 ~ + 85 ℃
± 7 ~ ± 16 ppm (1.4+/- 1V)
2.0 mA Max.
5 ms Max.
- 5 dBc Max.
- 130 dBc / Hz
± 1 ppm / year Max.
* AFC Range is selective and disable is acceptable.
Dimensions
Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com
Item / Type
Output Type
Units: mm
91
很抱歉,暂时无法提供与“7Q-40.000MBV-T”相匹配的价格&库存,您可以联系我们找货
