LFSPXO076040REEL
LFSPXO076040REEL
    IQD
    SMD2520_4P
    有源晶振 25.000000MHz 0.9V -40℃~+85℃ CMOS
LFSPXO076040REEL 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO076040Reel Customer Part: Description 0.9V low voltage oscillator in a hermetically sealed 2.5 x 2.0mm surface mount ceramic package. Model IQXO-691 2520-09 Model Issue number 2 Frequency Parameters Frequency 25.0MHz Frequency Stability ±50.00ppm Operating Temperature Range Ageing -40.00 to 85.00°C ±3ppm max in 1st year @ 25°C Electrical Parameters Supply Voltage Current Draw 0.9V ±5% 10.000mA Output Details Output Compatibility Drive Capability Rise and Fall Time Duty Cycle Output Voltage Levels: Output Low (VoL): 10%Vs max Output High (VoH): 90%Vs min Start Up Time: 10ms max Outline (mm) CMOS 15pF max 7.0ns max 45/55% Output Control Standby Operation: Logic ‘1’ (≥70% Vs) to pad 1 enables oscillator output. Logic ‘0’ (≤30% Vs) to pad 1 disables oscillator output; when disabled the oscillator output goes to the high impedance state. No connection to pad 1 enables oscillator output (internal pull-up resistor). Standby Current: 100μA max Recommended Solder Pad Layout Noise Parameters RMS Phase Jitter (12kHz to 20MHz): 1ps max Environmental Parameters Storage Temperature Range: -55 to 125°C Mechanical Shock: MIL-STD-883, Method 2002, Condition B. Vibration: MIL-STD-883, Method 2007, Condition A. Moisture Resistance: MIL-STD-883, Method 1004. Thermal Cycling: MIL-STD-883, Method 1010, Condition B. Solderability: MIL-STD-883, Method 2003. Resistance to Soldering Heat: MIL-STD-202, Method 210, Condition K. Fine Leak Test: MIL-STD-883, Method 1014, Condition A. Gross Leak Test: MIL-STD-883, Method 1014, Condition C. Manufacturing Details Note: Please connect a bypass capacitor of 0.1μF between +Vs and circuit ground. RoHS Terminations Au RoHS Reflow Temp 260°C max for 10secs max Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 3 Aug 21 16:37 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 1 of 2 Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO076040Reel Customer Part: Compliance RoHS Status (2015/863/EU) REACh Status MSL Rating (JDEC-STD-033): Compliant Compliant 1 Packaging Details Pack Style: Reel Pack Size: 3,000 Tape & reel in accordance with EIA-481D Alternative packing option available Sales Office Contact Details: UK: +44 (0)1460 270200 France: 0800 901 383 Germany: 0800 1808 443 USA: +1.760.318.2824 Printed on 3 Aug 21 16:37 using Part Data Sheet V1.0018 Email: info@iqdfrequencyproducts.com Web: www.iqdfrequencyproducts.com Page 2 of 2
LFSPXO076040REEL
1. 物料型号:IQXO-691 2520-09,封装为LFSPXO076040Reel。 2. 器件简介:这是一个0.9V低电压振荡器,采用密封的2.5 x 2.0mm表面贴装陶瓷封装。 3. 引脚分配:文档中未明确列出引脚分配,但提到了振荡器输出控制,逻辑“1”(≥70% Vs)使能振荡器输出,逻辑“0”(≤30% Vs)禁用振荡器输出。 4. 参数特性: - 频率:25.0MHz - 频率稳定性:±50.00ppm - 工作温度范围:-40.00至85.00°C - 老化:在25°C下第一年最大±3ppm - 供电电压:0.9V ±5% - 电流消耗:10.000mA 5. 功能详解: - 输出细节:兼容CMOS,驱动能力15pF最大,上升和下降时间最大7.0ns,占空比45/55%,输出电压水平低(VoL)最大10%Vs,高(VoH)最小90%Vs。 - 启动时间:最大10ms - 待机操作:逻辑“1”启用振荡器输出,逻辑“0”禁用并使振荡器输出进入高阻抗状态。 - 噪声参数:12kHz至20MHz的RMS相位抖动最大1ps。 6. 应用信息:文档中未明确列出应用信息,但根据其参数特性,适用于需要高精度时钟信号的电子设备。 7. 封装信息:2.5 x 2.0mm表面贴装陶瓷封装,符合EIA-481D标准,卷装,每卷3000个,提供替代包装选项。
LFSPXO076040REEL 价格&库存
很抱歉,暂时无法提供与“LFSPXO076040REEL”相匹配的价格&库存,您可以联系我们找货
