Think of Frequency Think of
SMD LVPECL SAW
Oscillators - Differential Output
5.0 x 3.2 x 1.2 mm CS Series
come visit our site http://www.txccorp.com
Oscillators
Series
Features
.SAW base solution.
.3.3V and 2.5V operation available.
1H
SY 00
S
C
T B 212.5
.LVPECL output, output frequencies 150 MHz to 700 MHz.
.Excellent low phase noise and jitter.
.Tri-State function available.
.Applications : Fibre Channel, Gigabit Ethernet, Serial ATA, Serial
Attached SCSI, PCI-Express, SDH / SONET.
.RoHS Compliant / Pb Free.
Electrical Specifications
CS
Output Type
LVPECL
Output Load
50 Ω
Oscillation Mode
Fundamental
Supply Voltage (VDD)
2.5 V , 3.3 V
Frequency Range
150 ~ 700 MHz
Overall Frequency Stability *
± 100 ppm , or specify
Operating Temperature Range
-10 ~ + 70 ℃ , - 5 ~ + 85 ℃ , or specify
Storage Temperature Range
- 55 ~ + 125 ℃
Voltage Vol ( Max. ) / Voh ( Min. )
VDD - 1.62 V / VDD - 1.025 V
Rise ( Tr ) / Fall ( Tf ) Time ( 20 % ~ 80 % )
1 nS Max.
Supply Current
80 mA Max.
Symmetry
45 ~ 55 %
Start-up Time
10 mS Max.
Phase Jitter ( 12 KHz ~ 20 MHz )
1 pS Max.
* Inclusive of frequency tolerance at 25 ℃, variation over temperature, supply voltage variation, aging and vibration.
Dimensions
5.0±0.2
5
4
1
2
3
1.2±0.2
3.2±0.2
6
Land Pattern:
1.27
0.89
4
2
3
5
4
2.60
1.60
5
1.20
1
6
1.27 1.27
Pad dimension tolerance ±0.2 mm
70
Pin Function:
1. Enable Control or NC
2. Enable Control or NC
3. GND
4. OUT
5. OUTN
6. VDD
6
0.64
0.90
Remark : Specification subject to change without prior notice. Please confirm with our sales. http://www.txccorp.com
Item / Type
12
3
Power Supply Decoupling Capacitor is Required.
Units: mm
很抱歉,暂时无法提供与“CS-425.000MCC-T”相匹配的价格&库存,您可以联系我们找货
