TAETBLSANF-20.000000
    TAITIEN(泰艺)
    SMD-4
    有源晶振 20MHz SMD-4 3V~3.3V
TAETBLSANF-20.000000 数据手册
TA Type 7.0 x 5.0 mm SMD Voltage Controlled Temperature e Compensated Crystal Oscillator Actual Size FEATURE - Typical 7.0 x 5.0 x 1.9 mm ceramic SMD package. - For automatic assembly. - Compactness and light weight. - Low power consumption. - VCTCXO available. TYPICAL APPLICATION - Femtocell , Base Stations - WLAN/WiMAX/WIFI, Wireless Communications - Mobile Phone DIMENSION (mm) RoHS Compliant SOLDER PAD LAYOUT (mm) [TOP VIEW] [BOTTOM VIEW] 7.00±0.20 5.08±0.15 #3 5.08 4.00±0.15 #4 #2 #2 4.20 0.80±0.15 #1 0.1µF #1 1.20 #3 5.00±0.20 #4 1.40±0.15 [SIDE VIEW] Pin# 0.7±0.12 1.90±0.20 1 2 3 4 Function 1.50 Vcon:VC-TCXO GND/NC:TCXO GND OUTPUT VDD To ensure optimal oscillator performance, place a by-pass capacitor of 0.1ȝF as close to the part as possible between Vdd and GND pads. ELECTRICAL SPECIFICATION 3.3 / 3.0 V 2.5 V Min. Max. Min. Max. VDD-5% VDD+5% VDD-5% VDD+5% 52 5 52 5 5, 6.4, 8, 8.192, 10, 12.5, 12.8, 16, 16.384, 19.44, 25, 26 8, 8.192, 10, 12.5, 12.8, 16, 16.384, 19.44, 25, 26 _ _ ±2.0 ±2.0 Parameter Supply Voltage Variation (VDD) Frequency Range Standard Frequency (for CMOS) Standard Frequency (for Clipped Sine Wave) Frequency Tolerance* Frequency stability Vs Supply Voltage (±5%) change Vs Load (±10%) change Vs Aging Supply Current (CMOS output) Supply Current (Clipped Sine Wave) Output Level (CMOS) Output High (Logic “1”) Output Low (Logic “0”) Duty _ _ _ _ _ 90%VDD _ 45 0.8 Output (Clipped Sine Wave) Load (CMOS) Load (Clipped Sine Wave) Control Voltage Range (VCTCXO) Pulling Range (VCTCXO) Vc Input Impedance (VCTCXO) Phase Noise @ 19.2 MHz 100 Hz 1 kHz 10 kHz Start Time Storage Temp. Range ±0.1 ±0.2 ±1.0 6 3.5 _ _ _ _ _ _ 90%VDD 10%VDD 55 _ 15pF 10 KΩ // 10pF 0.5 2.5 ±5.0 ±12.0 _ 100 -115 -135 -148 _ 2 -55 125 _ 45 0.8 ±0.1 ±0.2 ±1.0 6 3.5 Unit V MHz ppm ppm mA _ 10%VDD 55 _ 15pF 10 KΩ // 10pF 0.4 2.4 ±5.0 ±12.0 _ 100 -115 -135 -148 _ 2 -55 125 V % Vp-p V ppm kΩ dBc / Hz mSec °C Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position. * Frequency at 25°C, 1 hour after reflow. FREQ. STABILITY vs. TEMP. RANGE Temp. (°C) ppm -20 ~ +70 -30 ~ +85 -40 ~ +85 ±0.5 " ±1.0 ż * : Available Χ:Conditional X: Not available “ 10~26MHz and Pulling
TAETBLSANF-20.000000 价格&库存
很抱歉,暂时无法提供与“TAETBLSANF-20.000000”相匹配的价格&库存,您可以联系我们找货
  • 100+231.80994100+29.99081
