SXO53C3C481-125.000M
    SUNTSU
    SMD5032_4P
    有源晶振 125.000000 MHz -25~+25ppm 3.3V -40℃~+85℃ CMOS
SXO53C3C481-125.000M 数据手册
Ceramic SMT 4 Pad CMOS Oscillator SXO53C Series 5.0mm x 3.2mm Features Applications • ±20ppm (Frequency Stability) Available • Micro Processors • Ceramic Package • SONET/SDH/DWDM • CMOS • Storage Area/Networking • Tape and Reel • Digital Video • Base Stations • Part Numbering Guide SXO 53 C 3 A 48 1 X - 50.000M SUNTSU OSC 5.0mm x 3.2mm CMOS SUPPLY VOLTAGE 1 : 1.8V±5% 2 : 2.5V±5% 3 : 3.3V±5% CO M P L I A N T FREQUENCY STABILITY A : ±50ppm B : ±30ppm C : ±25ppm *D : ±20ppm Cage Code : 4GUT4 To customize your parameters, contact a Suntsu representative. * For Frequency stability option D, contact a Suntsu representative. ** For operating temperatures up to -55-125°C contact a Suntsu representative. Electrical Parameters Units Minimum Frequency Range KHz 32.768 Frequency Range MHz 1 200 ppm -20 +20 See part numbering guide for options See part numbering guide for options Frequency Stability (Includes Initial Tolerance at 25°C, Frequency Stability over Operating Temperature, Output Load Change, Supply Voltage Change, and First Year Aging at 25°C.) Operating Temperature Typical OPERATING TEMPERATURE RANGE 07 : 0°C - +70°C 16 : -10°C - +60°C 17 : -10°C - +70°C 27 : -20°C - +70°C 38 : -30°C - +85°C 48 : -40°C - +85°C FREQUENCY MHz LOAD BLANK : 15pF X : 30pF TRI-STATE (ENABLE/DISABLE) Y : 50pF BLANK : No Connection 1: Pin 1 Maximum °C -40 +85 Storage Temperature °C -55 +125 Supply Voltage (VDD) - 1.8V option V 1.710 1.8 1.890 Supply Voltage (VDD) - 2.5V option V 2.375 2.5 2.625 Supply Voltage (VDD) - 3.3V option V 3.135 3.3 3.465 1.8V 2.5V 3.3V Frequency Range Current (IDD) 32.768KHz mA 5 5 5 1.0000MHz - 34.999MHz mA 8 10 16 Maximum Value 35.000MHz - 59.999MHz mA 10 20 25 Maximum Value Maximum Value 60.000MHz - 99.000MHz mA 25 30 40 Maximum Value 100.000MHz - 160.000MHz mA 35 40 50 Maximum Value 15 See part numbering guide for options Output Load (CMOS) pF Output Logic Levels High (VOH) Output Logic Levels Low (VOL) Rise (TR) and Fall (TF) Time Remarks V 0.9*VDD V 0.1*VDD 32.768KHz ns 200 1.0000MHz - 34.999MHz ns 10 35.000MHz - 99.999MHz ns 6 100.000MHz - 160.000MHz ns Symmetry (Duty Cycle) 3 % 45 Tri-State Input Voltage - Enable V 0.7*VDD Tri-State Input Voltage - Disable V 0.3*VDD Start-Up Time ms 10 Phase Jitter (12kHz ~ 20MHz) ps 1 www.suntsu.com Specifications are subject to change without notice. 50 55 No Connection Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO53C Series 5.0mm x 3.2mm Outline Drawing & Land Pattern All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. Test Circuit (CMOS) Waveform (CMOS) Typical Phase Noise Performance (Measured By Agilent E5052A) Frequency - 50.000MHz www.suntsu.com Specifications are subject to change without notice. Frequency - 100.000MHz Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO53C Series 5.0mm x 3.2mm Typical Jitter Performance (Measured By Agilent E5052A) Frequency - 50.000MHz Frequency - 100.000MHz Reflow Profile Part Marking Tp (Time At 260°C. 20-40 Sec) 260 Rup (Ramp Up, 3°C/Sec Max) 217 Temperature (°C) 200 TI (Time Above 217°C. 60-150Sec) 150 Rdn (Ramp Down, 6°C/Sec Max) Ts (Preheat Time. 60-180Sec) T 25°C to Peak (480Sec Max) Time (sec) Tape And Reel Dimensions All dimensions are in millimeters (mm) unless otherwise noted. Drawings are not to scale. 1,000pcs/Reel www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301 Ceramic SMT 4 Pad CMOS Oscillator SXO53C Series 5.0mm x 3.2mm Environmental Specifications Mechanical Specifications Temperature Cycling MIL-STD-883, Method 1010, Condition B Mechanical Shock MIL-STD-202, Method 213, Condition B Fine Leak Test MIL-STD-883, Method 1014, Condition A Vibration MIL-STD-883, Method 2007, Condition A Gross Leak Test MIL-STD-883, Method 1014, Condition C Moisture Resistance MIL-STD-883, Method 1004 Solderability MIL-STD-883, Method 2003 Resistance to Solvents MIL-STD-202, Method 215 Moisture Sensitivity J-STD-020, MSL 1 Resistance to Soldering Heat MIL-STD-202, Method 210, Condition K www.suntsu.com Specifications are subject to change without notice. Suntsu Electronics, Inc. 142 TECHNOLOGY DR., SUITE 150 IRVINE, CA 92618 Call: +1-949-783-7300 | Fax: +1-949-783-7301
物料型号:SXO53C系列
器件简介:SXO53C系列是一款陶瓷表面贴装4引脚CMOS振荡器,具有±20ppm的频率稳定性,适用于多种应用领域。
引脚分配: - 1:频率输入(1.8V±5%,2.5V±5%,3.3V±5%) - 2:接地(GND) - 3:输出(OUTPUT) - 4:三态控制(TRI-STATE)
参数特性: - 频率范围:32.768KHz至200MHz - 频率稳定性:-20ppm至+20ppm(根据选项不同) - 工作温度范围:-40℃至+85℃(根据选项不同) - 存储温度范围:-55℃至+125℃ - 供电电压:1.8V、2.5V、3.3V选项 - 输出负载:15pF(BLANK)、30pF(X)、50pF(Y)
功能详解: - 三态控制:允许振荡器输出在使能或禁用状态下切换。 - 频率稳定性选项:提供不同的稳定性选项,如±50ppm、±30ppm、±25ppm等。
应用信息: - 微处理器 - SONET/SDH/DWDM - 存储区域/网络 - 数字视频基站
封装信息:5.0mm x 3.2mm的陶瓷SMT封装。
环境规格和机械规格遵循MIL-STD-883和J-STD-020等标准。
典型相位噪声性能和典型抖动性能通过Agilent E5052A测量。
回流焊曲线和标记信息也包含在文档中。
联系方式:Suntsu Electronics, Inc. 提供了电话和传真号码以及网站。
注意事项:规格如有变更,恕不另行通知。
SXO53C3C481-125.000M 价格&库存
很抱歉,暂时无法提供与“SXO53C3C481-125.000M”相匹配的价格&库存,您可以联系我们找货
