IQXT-205-3
IQXT-205-3 is a 2.0 x 1.6mm SMD Temperature Compensated Crystal Oscillator (TCXO) in a hermetically
sealed package with a wide operating temperature range.
Model Name
Description
IQXT-205-3-18
A 1.8V version
IQXT-205-3-25
A 2.5V version
IQXT-205-3-28
A 2.8V version
IQXT-205-3-30
A 3.0V version
IQXT-205-3-33
A 3.3V version
IQD Frequency Products Ltd ■ Station Road ■ Crewkerne ■ Somerset ■ TA18 8AR ■ United Kingdom
Tel: +44 (0)1460 270200 ■ Fax: +44 (0)1460 72578 ■ Email: info@iqdfrequencyproducts.com
Registered in England No: 06478545 ■ VAT Registration No: GB932 4502 45
TCXO Specification
IQXT-205-3-18
ISSUE 1; March 2018
Outline (mm)
Description
IQXT-205-3-18 is a 2.0 x 1.6mm SMD Temperature
Developed frequencies: 16.368, 16.369, 19.2, 26.0, 33.6, 38.4
and 52.0MHz
Frequency Parameters
Frequency
13.0MHz to 52.0MHz
±1.50ppm
@ 25°C ±2°C
±0.50ppm
±1ppm max per year @ 25°C
±2°C
Frequency Tolerance: Referred to nominal frequency before
reflow soldering.
IR Reflow Resistance (@ 25°C ±2°C ref to frequency before
reflow): ±1ppm max, 24hrs after reflow
Supply Voltage Variation (@ ±5% change): ±0.1ppm max
Load Variation (@ ±10% change): ±0.1ppm max
Frequency Tolerance Max
Tolerance Condition
Frequency Stability
Ageing
Electrical Parameters
1.8V ±5%
Supply Voltage
Absolute Maximum Ratings: Supply Voltage: -0.6V to 4.6V
Operating Temperature Ranges
-40 to 105°C
Output Details
Output Compatibility
Clipped Sine
Drive Capability
10kΩ//10pF
Output: DC coupled
Output Level: 0.8V pk-pk min
Start Up Time (90% of V pk-pk): 2ms max
Start Up Time (within ±0.5ppm): 2ms max
Noise Parameters
Phase Noise (typ): -135dBc/Hz @ 1kHz
Environmental Parameters
Storage Temperature Range: -40 to 105°C
Ordering Information
*Minimum info required
Frequency*
Model*
Output
Frequency Stability (over operating temperature range)*
Operating Temperature Range*
Supply Voltage
Example
26.0MHz IQXT-205-3-18
Clipped Sine ±0.5ppm –40 to 105C 1.8V
Compliance
RoHS Status (2011/65/EU)
REACh Status
MSL Rating (JDEC-STD-033):
Compliant
Compliant
Not Applicable
TCXO Specification
IQXT-205-3-18
ISSUE 1; March 2018
Packaging Details
Pack Style: Cutt
Pack Size: 100
Cut tape
Pack Style: Reel
Pack Size: 2,000
Tape & reel in accordance with EIA-481-D
Electrical Specification - maximum limiting values 1.8V ±5%
Frequency
Min
Frequency
Max
Temperature
Range
Stability
(Min)
Current
Draw
Rise and Fall
Time
Duty Cycle
°C
ppm
mA
ns
13.0MHz
29.999999MHz
-40 to 105
±0.5
1.5
30.0MHz
39.999999MHz
-40 to 105
±0.5
1.7
40.0MHz
52.0MHz
-40 to 105
±0.5
2
This document was correct at the time of printing; please contact your local sales office for the latest version.
Click to view latest version on our website.
TCXO Specification
IQXT-205-3-25
ISSUE 1; March 2018
Outline (mm)
Description
IQXT-205-3-25 is a 2.0 x 1.6mm SMD Temperature
and 52.0MHz
Frequency
13.0MHz to 52.0MHz
±1.50ppm
@ 25°C ±2°C
±0.50ppm
±2°C
reflow soldering.
Tolerance Condition
Frequency Stability
Ageing
2.5V ±5%
Supply Voltage
-40 to 105°C
Output Details
Clipped Sine
Drive Capability
10kΩ//10pF
Output: DC coupled
Noise Parameters
Frequency*
Model*
Output
Supply Voltage
Example
26.0MHz IQXT-205-3-25
Clipped Sine ±0.5ppm –40 to 105C 2.5V
Compliance
REACh Status
Compliant
Compliant
Not Applicable
TCXO Specification
IQXT-205-3-25
ISSUE 1; March 2018
Packaging Details
Pack Style: Cutt
Pack Size: 100
Cut tape
Pack Style: Reel
Pack Size: 2,000
Electrical Specification - maximum limiting values 2.5V ±5%
Frequency
Min
Frequency
Max
Temperature
Range
Stability
(Min)
Current
Draw
Rise and Fall
Time
Duty Cycle
°C
ppm
mA
ns
13.0MHz
29.999999MHz
-40 to 105
±0.5
1.5
30.0MHz
39.999999MHz
-40 to 105
±0.5
1.7
40.0MHz
52.0MHz
-40 to 105
±0.5
2
TCXO Specification
IQXT-205-3-28
ISSUE 1; March 2018
Outline (mm)
Description
IQXT-205-3-28 is a 2.0 x 1.6mm SMD Temperature
and 52.0MHz
Frequency
13.0MHz to 52.0MHz
±1.50ppm
@ 25°C ±2°C
±0.50ppm
±2°C
reflow soldering.
Tolerance Condition
Frequency Stability
Ageing
2.8V ±5%
Supply Voltage
-40 to 105°C
Output Details
Clipped Sine
Drive Capability
10kΩ//10pF
Output: DC coupled
Noise Parameters
Frequency*
Model*
Output
Supply Voltage
Example
26.0MHz IQXT-205-3-28
Clipped Sine ±0.5ppm –40 to 105C 2.8V
Compliance
REACh Status
Compliant
Compliant
Not Applicable
TCXO Specification
IQXT-205-3-28
ISSUE 1; March 2018
Packaging Details
Pack Style: Cutt
Pack Size: 100
Cut tape
Pack Style: Reel
Pack Size: 2,000
Electrical Specification - maximum limiting values 2.8V ±5%
Frequency
Min
Frequency
Max
Temperature
Range
Stability
(Min)
Current
Draw
Rise and Fall
Time
Duty Cycle
°C
ppm
mA
ns
13.0MHz
29.999999MHz
-40 to 105
±0.5
1.5
30.0MHz
39.999999MHz
-40 to 105
±0.5
1.7
40.0MHz
52.0MHz
-40 to 105
±0.5
2
TCXO Specification
IQXT-205-3-30
ISSUE 1; March 2018
Outline (mm)
Description
IQXT-205-3-30 is a 2.0 x 1.6mm SMD Temperature
and 52.0MHz
Frequency
13.0MHz to 52.0MHz
±1.50ppm
@ 25°C ±2°C
±0.50ppm
±2°C
reflow soldering.
Tolerance Condition
Frequency Stability
Ageing
3.0V ±5%
Supply Voltage
-40 to 105°C
Output Details
Clipped Sine
Drive Capability
10kΩ//10pF
Output: DC coupled
Noise Parameters
Frequency*
Model*
Output
Supply Voltage
Example
26.0MHz IQXT-205-3-30
Clipped Sine ±0.5ppm –40 to 105C 3.0V
Compliance
REACh Status
Compliant
Compliant
Not Applicable
TCXO Specification
IQXT-205-3-30
ISSUE 1; March 2018
Packaging Details
Pack Style: Cutt
Pack Size: 100
Cut tape
Pack Style: Reel
Pack Size: 2,000
Electrical Specification - maximum limiting values 3.0V ±5%
Frequency
Min
Frequency
Max
Temperature
Range
Stability
(Min)
Current
Draw
Rise and Fall
Time
Duty Cycle
°C
ppm
mA
ns
13.0MHz
29.999999MHz
-40 to 105
±0.5
1.5
30.0MHz
39.999999MHz
-40 to 105
±0.5
1.7
40.0MHz
52.0MHz
-40 to 105
±0.5
2
TCXO Specification
IQXT-205-3-33
ISSUE 1; March 2018
Outline (mm)
Description
IQXT-205-3-33 is a 2.0 x 1.6mm SMD Temperature
and 52.0MHz
Frequency
13.0MHz to 52.0MHz
±1.50ppm
@ 25°C ±2°C
±0.50ppm
±2°C
reflow soldering.
Tolerance Condition
Frequency Stability
Ageing
3.3V ±5%
Supply Voltage
-40 to 105°C
Output Details
Clipped Sine
Drive Capability
10kΩ//10pF
Output: DC coupled
Noise Parameters
Frequency*
Model*
Output
Supply Voltage
Example
26.0MHz IQXT-205-3-33
Clipped Sine ±0.5ppm –40 to 105C 3.3V
Compliance
REACh Status
Compliant
Compliant
Not Applicable
TCXO Specification
IQXT-205-3-33
ISSUE 1; March 2018
Packaging Details
Pack Style: Cutt
Pack Size: 100
Cut tape
Pack Style: Reel
Pack Size: 2,000
Electrical Specification - maximum limiting values 3.3V ±5%
Frequency
Min
Frequency
Max
Temperature
Range
Stability
(Min)
Current
Draw
Rise and Fall
Time
Duty Cycle
°C
ppm
mA
ns
13.0MHz
29.999999MHz
-40 to 105
±0.5
1.5
30.0MHz
39.999999MHz
-40 to 105
±0.5
1.7
40.0MHz
52.0MHz
-40 to 105
±0.5
2
Sales Office Contact Details:
UK: +44 (0)1460 270200
Germany: 0800 1808 443
France: 0800 901 383
USA: +1.760.318.2824
Printed on 20 Mar 18 12:57 using Model Data Sheet V1.2550
Web: www.iqdfrequencyproducts.com
Page 11 of 11
很抱歉,暂时无法提供与“LFTCXO079058”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+30.567461+3.95472
- 10+26.5564110+3.43578
- 25+25.1172925+3.24960
- 50+24.0777850+3.11511
- 100+23.08163100+2.98623
- 250+21.82930250+2.82421
- 500+20.92825500+2.70763
- 1000+20.064791000+2.59592
- 国内价格 香港价格
- 1+30.677861+3.96900
- 国内价格 香港价格
- 10+26.5553510+3.43565
- 25+25.1164425+3.24949
- 50+24.0771450+3.11502
- 100+23.08099100+2.98615
- 250+21.82866250+2.82412
- 500+20.92761500+2.70755
- 1000+20.064181000+2.59584
