S5A3305-156.250-P-X-R
    AKER(安碁科技)
    SMD5032_6P
    有源晶振 156.250000 MHz 2.5V -40℃~+85℃ LVPECL
S5A3305-156.250-P-X-R 数据手册
RoHS Compliant Pb - Lead Free Ltr Appr Date Revisions Electrical Specifications: Frequency Range 25.000 to 160.000 ±100 ±50 ±25 ±3 0 to +70 -40 to +85 -55 to +125 Frequency Stability over Temperature Aging per Year Standard Extended Operating Temperature Range Storage Temperature Range Supply Voltage 25.000 to 100.000 MHz 100.100 to 160.000 MHz Logic High (Voh) Logic Low (Vol) Input Current Output Voltage 2.5 ± 5% 60 65 1.475 1.095 MHz PPM Max ºC 3.3 ± 5% 60 65 2.275 1.68 45 to 55 LVPECL - Complimentary Output 50 Output Symmetry Output Type Output Load 10.000 to 29.900 MHz 30.000 to 59.900 MHz Rise and Fall Time 1 0.5 Enable-Disable Function Enable High Input Voltage Enable Low Input Voltage Phase Jitter (12 KHz to 20 MHz) mA Max Vdd Min Vdd Max % - : 1 0.5 ns Max Q Pin 4 - QN Pin 5 Operating High Impedance 2.31 0.99 Vdd Min Vdd Max ps RMS Tri-State INH - Pin 1 High - Pin 1 Low - Pin 1 1.75 0.75 Vdd 1 Temperature stability is Inclusive of all conditions: Calibration Tolerance at +25°C, frequency stability over the operating temperature range, supply voltage, supply voltage change, output load changes, shock, vilbration, and 1st year aging at +25°C. Specification Title: 11-3 Chien-Kuo Rd T.E.P.Z. 4027 Taiwan, ROC All dimensions are millimeters. CAD: TCR EG Review: JL Appr: Page: 1/4 Date: Sept. 13, 2007 Clock Oscillator LVPECL - Complimentary Output 3.2 x 5.0 millimeter Surface Mount - 6 Pad General Product Specification Part Number: S5A Series www.aker-usa.com Mechanical Outline: Package is Seam Sealed Ceramic-Metal. Dimensions are millimeters. PCB Solder Pad Layout: Pad Connection: Top View Page: 2/4 Date: Sept. 13, 2007 P/N: Pin Connection 1- INH 2- NC 3- GND 4- Output - Q 5- Comp. Output - QN 6- Vdd S5A Series www.aker-usa.com Carrier Tape Dimensions: Dimensions are millimeters. Solder Reflow Characteristics: Page: 3/4 Date: Sept. 13, 2007 P/N: www.aker-usa.com S5A Series How to build a Part Number: Series Package S 5A Parameter 5.0 x 3.2 mm - 6 Pad Supply Voltage 25 33 +2.5 Vdd ± 5% +3.3 Vdd ± 5% Temperature Stability 10 05 025 ±100 PPM ±50 PPM ±25 PPM - Frequency 25.000 to 160.000 MHz - Output Load P LVPECL - Temperature Range See Notes X 0 to +70 ºC -40 to +85 ºC - Packaging R Tape and Reel Part Number Example: S5A3310-155.520-P-X-R S5A: 3.2 x 5.0 mm SMD Package - 6 Pad 33: +3.3 Vdd Supply Voltage 10: ±100 PPM Temperature Stability 155.520 MHz Nominal Frequency P: LVPECL - Complimentary Output X: -40 to + 85° C Extended Temperature Range R: Tape and Reel Notes: 1- Standard Temperature Range does not need to be included in Part Number description. 2- Product is shipped in Tape and Reel configuration. Each reel contains 1000 pieces. 3- Quantities less than 1000 are shipped bulk in ESD pouches. 4- Specification subject to change without notice. Page: 4/4 Date: Sept. 13, 2007 P/N: www.aker-usa.com S5A Series
S5A3305-156.250-P-X-R 价格&库存
很抱歉,暂时无法提供与“S5A3305-156.250-P-X-R”相匹配的价格&库存,您可以联系我们找货
    • 1+10.38960
    • 200+4.14720
    • 500+4.00680
    • 1000+3.94200
