LFSPXO019080REEL
LFSPXO019080REEL
    IQD
    SMD7050_4P
    有源晶振 12.000000MHz 5V 0℃~+70℃ HCMOS, TTL
LFSPXO019080REEL 数据手册
Crystal Clock Oscillator Specification Part No. + Packaging: LFSPXO019080Reel Customer Part: Description Standard 7 x 5mm crystal oscillator in a ceramic package with a seam sealed metal lid, hermetically sealed. Model CFPS-72 Model Issue number 14 Frequency Parameters Frequency 12.0MHz Frequency Stability ±50.00ppm Operating Temperature Range Ageing 0.00 to 70.00°C ±3ppm per year max Electrical Parameters 5.0V ±10% Supply Voltage Current Draw 20.000mA Note: parameters are referenced to 15pF load Outline (mm) Output Details HCMOS/TTL Output Compatibility Drive Capability 15pF std, 50pF max Rise and Fall Time 10.0ns max 45/55% Duty Cycle Start up time: 10ms max 1.1ms typ to 90% of final amplitude (under ideal conditions @ 25°C) Output Control Standby Operation: Logic ‘1’ (>70% Vs) to pad 1 enables oscillator output. Logic ‘0’ (
LFSPXO019080REEL
- 物料型号: LFSPXO019080Reel - 器件简介: 标准7 x 5mm晶体振荡器,采用陶瓷封装和密封金属盖,密封性良好。 - 引脚分配: 1. 待机操作,2. GND,3. 输出,4. +Vs - 参数特性: - 频率: 12.0MHz ±50.00ppm (0.00到70.00°C),±3ppm每年最大 - 工作温度范围: 0.00到70.00°C - 老化: 未具体说明 - 供电电压: 5.0V ±10% - 电流消耗: 20.000mA - 功能详解: - 输出兼容: HCMOS/TTL,15pF标准负载,50pF最大负载 - 驱动能力: 10.0ns最大上升和下降时间 - 占空比: 45/55% - 启动时间: 最大10ms - 待机操作: 逻辑“1”(>70% Vs)启用振荡器输出,逻辑“0”(<30% Vs)禁用输出 - 待机电流: 最大10μA,典型2.3µA @ 25°C - 应用信息: 未具体说明,但根据参数特性,适用于需要高精度时钟信号的应用。 - 封装信息: 封装风格为卷带,符合EIA-481-D标准,包装大小为1,000。
LFSPXO019080REEL 价格&库存
很抱歉,暂时无法提供与“LFSPXO019080REEL”相匹配的价格&库存,您可以联系我们找货
