09195606953
09195606953
    HARTING(浩亭)
    CONN HEADER R/A 60POS 2.54MM
09195606953 数据手册
SEK IEC 60 603-13 Number of contacts 6--64 SMC male header with angled solder pins and board lock Identification No. of contacts Without levers Part number With short levers With long levers SMC male header with angled solder pins and pcb board lock SEK Length: 2.9 mm for 1.6 mm pcb thickness To hold the connector on the pcb before the soldering ­process, two board locks have been added on the male ­header with angled solder pins. 6 09 19 506 973* 09 19 506 963* 09 19 506 953* 10 09 19 510 973* 09 19 510 963* 09 19 510 953* 14 09 19 514 973* 09 19 514 963* 09 19 514 953* 16 09 19 516 973* 09 19 516 963* 09 19 516 953* 20 09 19 520 973* 09 19 520 963* 09 19 520 953* 24 09 19 524 973* 09 19 524 963* 09 19 524 953* 26 09 19 526 973* 09 19 526 963* 09 19 526 953* 30 09 19 530 973* 09 19 530 963* 09 19 530 953* 34 09 19 534 973* 09 19 534 963* 09 19 534 953* 40 09 19 540 973* 09 19 540 963* 09 19 540 953* 50 09 19 550 973* 09 19 550 963* 09 19 550 953* 60 09 19 560 973* 09 19 560 963* 09 19 560 953* 64 09 19 564 973* 09 19 564 963* 09 19 564 953* 08 44 * Not normally kept in stock For performance level 3 please specify digit For performance level 2 please specify digit S4 = 0.76 µm (30 µinch) Au or PdNi eqivalent 7 6 5 7 6 5 7 6 5
09195606953 价格&库存
很抱歉,暂时无法提供与“09195606953”相匹配的价格&库存,您可以联系我们找货
