Mounting Option
02-.128 (3.25) Dia. Mounting Holes
Contact Detail
520-P.C. Tail .025x.013(0.64x0.33) - Tail LG.=.125(3.18)
.100 [2.54] Contact Spacing x .140 [3.56] Row Spacing
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
ORIGINAL
1
1.775 45.09
1.600 40.64
Card Slot Accpets .054 (1.37)
To .070 (1.78) Thick P.C. Board
0.330 8.38
0.295 7.49
Card Slot
0.125 3.18
Point of Contact
A
0.437 11.10
SECTION A-A
A
See Accompanying Pages for:
Contact Bend Details
Mounting Options
Features and Specifications
341/391 Series Card Edge Connector
Part Number: 341-030-520-202
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
341 Assembly
341 ENG MASTER
DATE: SEPT. 03/09
DATE:
SHEET 1 OF 3
ISSUE
1
ISSUE NUMBER
ORIGINAL
1
Bend Detail
0.120 3.05
0.095 2.41
0.165 4.19
0.190 4.82
.205 [5.21]
0.343 8.71
.125 [3.18] to .210 [5.33]
Outside Tails
.125 [3.18] to .185 [4.70]
Outside Tails
.045 [1.14] to .060 [1.52]
Between Tails
Between Tails
555 Contact Code
Outside Tails
Between Tails
556 Contact Code
560 Contact Code
Mounting Options
.010 [0.25]
Radial Float
0.116 2.95 I.D.
Floating Eyelets
.128 [3.25] Dia
Through Holes
Code x01
Code x02
0.250 6.35 Dia.
Code x03
.156 [3.96] Dia
Through Holes
Code x04
M3-0.5 Metric
Threaded Insert
Code x07
#4-40 UNC
Threaded Insert
Code x08
0.328 8.33
0.005 0.13
Vertical Float
Bend Detail and Mounting Options
EDAC INC
TORONTO, ONTARIO
CANADA
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
341 Assembly
341 ENG MASTER
DATE: SEPT. 03/09
DATE:
SHEET 2 OF 3
ISSUE
1
ISSUE NUMBER
ORIGINAL
1
Features
xUL Recognized
x.100 (2.54) Contact Spacing x .140 (3.56) Row Spacing
xAccepts .062 (1.57) Nominal Thickness P.C. Board
xLow Profile Insulator Body .437 (12.01)
xContact Termination Options include P.C. Tail, Wire Hole, and Extender Board Bends
xSingle or Dual Row Configurations
xVariety of Mounting Options
xAccepts Between Contact and In-Contact Polarizing Keys
Specifications
xInsulator Material: Thermoplastic Polyester, UL 94V-0
xContact Material: Copper, Nickel, Tin Alloy CA-725
xContact Plating: Gold on the Mating Area, Tin on the Contact Tails, Nickel
Underplate
xCurrent Rating: 3 Amperes Continuous
xContact Resistance: 10 Milliohms Maximum
xDielectric Withstanding Voltage: 1200 V AC rms at Sea Level Between Adjacent
Contacts
xInsulation Resistance: 5000 Megohms Minimum
xOperating Temperature: -65 to +105 Degrees C
xInsertion Force: 16 oz (4.45 N) Maximum per Contact Pair when Tested with a .070
(1.78) Thick Gauge
xWithdrawal Force: 1 oz (0.28 N) Minimum per Contact Pair when Tested with a .054
(1.37) Thick Gauge
EDAC INC
TORONTO, ONTARIO
CANADA
ACAD REFERENCE NO.
J.LEE
DRAWN:
CHECKED:
SCALE:
NTS
DRAWING NUMBER
341 Assembly
341 ENG MASTER
DATE: SEPT. 03/09
DATE:
SHEET 3 OF 3
ISSUE
1
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
EDAC:
341-030-520-202
很抱歉,暂时无法提供与“341-040-500-204”相匹配的价格&库存,您可以联系我们找货
