HSEC8-160-01-L-RA-BL 数据手册
HIGH-SPEED
EDGE CARD SYSTEMS
0.60 mm, 0.80 mm and 1.00 mm PITCH
FEATURES & BENEFITS
• 56 Gbps PAM4 performance
• PCI Express® 3.0, 4.0 and 5.0
• Edge Rate® contacts optimized for
signal integrity performance and cycle life
• Up to 200 positions available
• Vertical, right-angle, edge mount,
pass-through orientations
• Power/signal combo, press-fit tails,
rugged weld tabs, locks and latches
• Mating cable assemblies available
Rugged tucked
beam technology
(HTEC8)
KEY SPECIFICATIONS
Differential pair for
increased speed
(HSEC8-DP)
Custom designs allow
for misalignment in
the X-Y axes (HSEC1)
SERIES
PITCH
TOTAL
POSITIONS
INSULATOR
MATERIAL
CONTACT
MATERIAL
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
HSEC6
0.60 mm
56-168
Black LCP
Copper Alloy
-55 ℃ to +125 ℃
0.8 A (12 pins)
300 VAC
Yes
HTEC8
0.80 mm
40-200
Black LCP
Copper Alloy
-55 ℃ to +125 ℃
3.0 A (2 pins)
215 VAC
Yes
HSEC8
0.80 mm
18-200
Black LCP
BeCu
-55 ℃ to +125 ℃
2.8 A (2 pins)
240 VAC
Yes
HSEC1
1.00 mm
20-140
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
2.2 A (2 pins)
215 VAC
Yes
F-221
samtec.com/EdgeCard
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(0.80 mm) .0315" PITCH • RIGHT-ANGLE & EDGE MOUNT SOCKET
HSEC8
POSITIONS
PER ROW
1
09, 10, 13, 20,
25, 30, 40, 49,
50, 60
CARD
THICKNESS
–01
PLATING
OPTION
RA
–L
= (1.60 mm) .062"
thick card
= 10 µ" (0.25 µm)
Gold on contact area,
Matte Tin on tail
–S
Card Mates:
(1.60 mm) .062"
thick card,
HSC8
(9.30)
.366
Leave blank for
Tray Packaging
–L2
= Tape & Reel
A
40
(43.80) 1.724
(51.80) 2.039
(22.90) .902
(44.60) 1.756
60
(59.80) 2.354
(26.90) 1.059
(52.60) 2.071
40-BL
(51.30) 2.020
(18.90)
.474.744
50-BL
(5.20)
(59.30) 2.335
(22.90) .902
(44.60) 1.756
60-BL
(67.30) 2.650
(26.90) 1.059
(52.60) 2.071
No. of Positions x (0.80) .0315 + (8.61) .339
Cable Mates:
ECDP
A
B
B
C
(18.90) .744
(36.60) 1.441
(12.05)
.205
–TR
= ECDP Latching
(09, 13, 25, 49 only)
POSITIONS PER ROW
No. of Positions x
(0.80)
50 .0315 + (5.38) .212
"X"R
–BL
= Board Locks (09, 13,
25, 40, 49, 50, 60 only)
= 30 µ" (0.76 µm)
Matte Tin on tail
HSEC8-RA
OTHER
OPTIONS
–FR
= Full Reel
Tape & Reel Packaging
(must order max.
quantity per reel;
contact Samtec for
quantity breaks)
(36.60) 1.441
C
(9.30)
(9.30)
.366.366
-BL OPTION
of Positions
No. No.
of Positions
x x
40, 50, & 60 POSITIONS
(0.80)
.0315
+ (5.38)
(0.80)
.0315
+ (5.38)
.212.212
of Positions
x (0.80)
.0315
+ (8.61)
No. No.
of Positions
x (0.80)
.0315
+ (8.61)
.339.339
(9.30)
.366
(12.05)
(12.05)
.474.474
(5.20)
(5.20)
.205.205
No. of Positions x
(0.80) .0315 + (5.38) .212
10, 20 & 30 POSITIONS
A A
C C
B B
View complete specifications at: samtec.com?HSEC8-RA
.474
HSEC8
1
POSITIONS
PER ROW
(12.05)
(5.20)
.205
01
B
10, 20, 30, 40,
50, 60
A
PLATING
OPTION
C
D
–L
EM2
–EM2
= 10 µ" (0.25 µm)
Matte Tin on tail
=(1.60 mm) .062"
thick PCB
–S
= 30 µ" (0.76 µm)
Matte Tin on tail
HSEC8-EM
Cable Mates:
ECDP
POSITIONS PER ROW
B + (18.40) .724
No. of A
No. of Positions x (0.80) .0315 + (7.80) .307
A
(7.00)
.276
(7.00)
.276
40
B
40,
50 &x (0.80)
60 POSITIONS
No. of
Positions
.0315 + (15.20) .598
B
A
No. of Positions x (0.80) .0315 + (18.40) .724
Card Mates:
(1.60 mm) .062"
thick card,
HSC8
A
B
(18.90) .744
(36.60) 1.441
No. of Positions x (0.80) .0315 + (15.20) .598
(7.00)
.276
50
(22.90) .902
(44.60) 1.756
60
(26.90) 1.059
(52.60) 2.071
No. of Positions x (0.80) .0315 + (4.60) .181
20 &x 30
POSITIONS
No. 10,
of Positions
(0.80)
.0315 + (4.60) .181
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
View complete specifications at: samtec.com?HSEC8-EM
samtec.com/EdgeCard
F-221
HSEC8-160-01-L-RA-BL 价格&库存
很抱歉,暂时无法提供与“HSEC8-160-01-L-RA-BL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+106.25040
- 10+101.99520
- 30+94.61880
- 100+70.54560
