8
7
4
5
6
1
2
3
REVISIONS
REV. ECO NO.
K
2966
L
3277
F
E
D
B
A
PIN A2
PIN A1
2X
DESCRIPTION
DATE
FIX INCHES[MM] TO MM[INCHES] IN SHEET FORMAT,
UPDATE DWG FORMAT
BY
5/27/2014 JHSU
UPDATE TOL OF BOARD LOCK HEIGHT DIM TO 0.25mm
(WAS 0.13mm) & UPDATE BOM ON PRODUCTION COPY 8/7/2015
F
MG
3.18 .125
PIN 1 INDICATOR
E
E
1.91 .075
SEE NOTE 13
PIN B1
1.00 .039
PIN B2
0.36 .014 X 0.30[.012]
+0.13
+.005
9.40
.370
- 0.38
- .015
C
0.76 .030
A
D
D
9.14 .360
21.84 .860
15.11±0.25 .595±.010
7.62 .300
INSERTION DEPTH
6.35 .250
3X 2.00 .079
C
A
HA = 2.54±0.64 .100±.025
HB = 4.32 0.64 [.170 0.025]
TAIL LENGTH
_ _ E _ _ DHAD
_ _ E _ _ DHBD
3X 2.00 .079
PIN A1
PIN A2
C
SECTION A-A
F
A
1.02 .040 MIN
1.00 .039
2.00 .079
2.64 .104
OPTIONAL FOR 'R' MOUNTING
3.00 .118
B
B
2X 3.18 .125
OPTIONAL FOR 'S' MOUNTING
NOTES:
2.79 .110
PIN B2
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
PIN B1
3. PLATING: .SEE PART NUMBER CODING
D
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
PCB LAYOUT RECOMMENDED
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 225 VAC
UNLESS OTHERWISE SPECIFIED: DRAWN
8. CURRENT RATING: 1 AMP
DIMENSIONS ARE IN MM [INCHES]
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
TOLERANCES:
10. INSULATION RESISTANCE: 5000 MEGA OHMS
ANGULAR: 1
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
DECIMALS
.X= .5 [.02]
13. BOARD THICKNESS ACCOMMODATED: 1.57 0.20[.062 .008]
.XX= .13 [.005]
14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A 1.57[.062] TEST BLADE
.XXX= .013 [.0005]
RoHS
COMPLIANT
15. WITHDRAWAL FORCE: 1/2 OZ MIN PER CONTACT PAIR USING 1.57[.062] PCB
CUSTOMER COPY
A
Pb
8
7
6
5
4
DATE
NAME
11/24/03 JFW
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
3
TITLE
PART NUMBER
SIZE
C
_ _ E _ _ DHA (HB) _
CAGE CODE
54453
SCALE: 3:1
2
A
EDGECARD, 1MM CC, RA
DWG. NO.
C10093
SHEET 1 OF 3
1
REV
L
FILE NAME: C10093, _ _E_ _DH_ _, DHA, DHB
8
7
4
5
6
1
2
3
D
2X #4-40 THREADED INSERT
F
F
D
E
E
12.32 .485
2X
15.11 .595
3.18 .125
D
2.79 .110
_ _ E _ _ DHAS
_ _ E _ _ DHBS
_ _ E _ _ DHAT
_ _ E _ _ DHBT
D
F
C
C
C
C
B
B
3.00 .118
_ _ E _ _ DHAR
_ _ E _ _ DHBR
CUSTOMER COPY
_ _ E _ _ DHAN
_ _ E _ _ DHBN
Pb
A
RoHS COMPLIANT
8
7
4.41 .174
6
5
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
11/24/03 JFW
TOLERANCES:
ANGULAR:
1
DECIMALS
.X= .5 [.02]
.XX= .13 [.005]
.XXX= .013 [.0005]
TITLE
PART NUMBER
SIZE
C
2
CAGE CODE
54453
SCALE: 3:1
3
A
DWG. NO.
C10093
SHEET 2 OF 3
1
REV
L
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
11/24/03 JFW
TOLERANCES:
ANGULAR:
1
DECIMALS
.X= .5 [.02]
.XX= .13 [.005]
.XXX= .013 [.0005]
TITLE
PART NUMBER
SIZE
C
2
CAGE CODE
54453
SCALE: 3:1
3
A
DWG. NO.
C10093
SHEET 3 OF 3
1
REV
L
很抱歉,暂时无法提供与“RZE15DHAS”相匹配的价格&库存,您可以联系我们找货
