8
7
4
5
6
1
2
3
REVISIONS
F
1.78 .070
11.65 .459
A PIN# 1
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
1595
INITIAL RELEASE
11/31/07
VJ
B
1707
UPDATE P/N CODING CHART, PLATING
05/30/08
ASK
C
1933
UPDATE DRAWING VIEWS, NOTES & DIM.
3/09/2009
JH
F
B
A
10.00 .394
E
E
+0.20
+.008
1.77
.070
- 0.10
- .004
B PIN# 1
CL KEY
1.50 .059
5.10±0.15 .201±.006
1.50 .059
14.50 .571
3.75 .148 MAX.
C
0.95 .037
D
8.80 .346
A
7.40 .291
D
3.55 .140
4.40 .173
7.60 .299
1.00 .039
0.35±0.05 .014±.002 TYP.
2X1.25 .049
2X3.25 .128
1.35 .053
C
A
TAIL LENGTH
(SEE PART NUMBER CODING)
1.65 .065
D
SECTION A-A
0.80±0.15 .031±.006
4.40±0.15 .173±.006
1.00 .039 TYP.
C
B
1.00 .039
0.25±0.05 .010±.002 TYP.
2.20±0.08 .087±.003
NOTES:
1. INSULATOR MATERIAL: NYLON46, UL 94V-0.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 1.1 AMP.
5. INSULATOR RESISTANCE: 1000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 30 MILLI OHMS MAX.
7. DIELECTRIC WITHSTANDING: 300V AC.
8. INSEERTION FORCE: 117gf (1.15 N) MAX PER CONTACT PAIR USING A 1.70 mm (.067") STEEL CARD.
9. WITHDRAWAL FORCE: 15.3gf (0.15 N) MIN PER CONTACT PAIR USING A 1.44 mm (.057") STEEL CARD.
10. OPERATING TEMPERATURE: -55° C TO +85° C.
11. PROCESSING TEMP.: 260° C FOR 10 SECS MAX.
(INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES
MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED
INDICATED TEMPERATURE AND TIME.)
B
2.05±0.08 .081±.003
UNLESS OTHERWISE SPECIFIED:
Pb
A
DIMENSIONS ARE IN MM[INCHES]
TOLERANCES:
ANGULAR: 5
.X= .30 [.012]
.XX= .20 [.008]
.XXX= .10 [.004]
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
8
7
6
11.25 .443
MAX.
5
4
DRAWN
NAME
3/09/09
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
PCI EXPRESS, 1mm CC, DIP SOLDER
N_E_ _DHHN-T9_ _
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
DATE
REV
11045
SCALE: 5:1
2
C
SHEET 1 OF 2
1
FILE NAME: Z:\COMPONENTS\Taiwan\ECO PENDING TAIWAN\1912\11045, N_E_ _DHHN-T9_ _ PRINT: 3/19/2009
A
8
7
4
5
6
1
2
3
F
F
1.50 .059
1.90±0.05 .075±.002
1.50 .059
0.70 .028
B PIN #1
1.00 .039 TYP.
E
E
6.00 .236
MIN.
3.60 .142
10.00 .394
5.00 .197
A
12.15 .478
F
ADD-IN CARD EDGE-FINGER DIMENSIONS
(TOLERANCE: 0.05[.002])
D
D
D
10.00 .394
1.65 .065
A PIN #1
C
A
1.35 .053
1.25 .049
C
3.25 .128
1.00 .039 TYP
B PIN #1
RECOMMENDED PCB LAYOUT
B
2X
2.35±0.05 .093±.002
0.70±0.08 .028±.003
B
Pb
A
DESCRIPTION
PART NUMBER
N_E_ _DHHN-T9_ _
SIZE DWG. NO.
RoHS COMPLIANT C
REV
11045
SCALE: NTS
8
7
6
5
4
3
2
C
SHEET 2 OF 2
1
A
很抱歉,暂时无法提供与“NWE82DHHN-T921”相匹配的价格&库存,您可以联系我们找货
