8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
F
2868
UPDATE 'BOM' ON PRODUCTION DRAWING
11/26/2013
KV
H
3182
UPDATE DWG FORMAT, UPDATE INSERT
INSTALLATION IN 'V' MOUNTING
4/16/2015
MG
3613
ADD S2196, REMOVE 'A' MATERIAL, ADD 'Q'
MATERIAL, ADD PCB LAYOUT RECOMMENDED TO
CUSTOMER DRAWING, UPDATE 'R' MATERIAL
OPERATING TEMPERATURE, REMOVE 'Y' & 'S'
PLATING
2/1/2017
EP
F
J
2X
E
F
D
C
A
.125 3.18
THRU
E
+.005
+0.13
.370
9.40
- .015
- 0.38
B
(.025 0.64 ) DEPTH FROM
TOP OF INSULATOR TO
TOP OF PIN
D
A
FITS EDGECARDS THAT
ACCEPT .062 1.57 PCB's
D
.540±.010 13.72±0.25
.250 6.35
.030 0.76
C
ACCOMMODATES
.062[1.57] PCB
.025 0.64
SECTION A-A
MR = .175±.025 4.45±0.64
MN = .545 .025[13.84 0.64]
A
.100 2.54
_ _C_ _M(MR,MN)D
_ _C_ _M(MR,MN)D-S2196
B
A
C
B
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE:SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 700 VAC
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
12. MODIFICATION: SEE PART NUMBER CODING.
8
7
6
5
CUSTOMER COPY
Pb
RoHS COMPLIANT
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
_ _C_ _M(MR,MN)_-(S2196)
CAGE CODE
54453
SCALE: 3:1
3
A
MALE, CARD EXTENDER, .100 CC
2
DWG. NO.
C11050
SHEET 1 OF 3
1
REV
J
FILE NAME: C11050, _ _C_ _M(MR,MN)_-(OMIT,S2196)
8
7
4
5
6
E
F
1
2
3
2X #4-40
THREADED
INSERTS
F
C
E
E
_ _C_ _M(MR, MN)T
_ _C_ _M(MR, MN)T-S2196
_ _C_ _M(MR, MN)N
_ _C_ _M(MR, MN)N-S2196
D
D
C
C
C
C
.125 3.18
.125 3.18
B
.125 3.18
B
2X #4-40
THREADED
INSERTS
_ _C_ _M(MR, MN)Z
_ _C_ _M(MR, MN)Z-S2196
_ _C_ _M(MR, MN)V
_ _C_ _M(MR, MN)V-S2196
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 3:1
3
A
2
DWG. NO.
C11050
SHEET 2 OF 3
1
REV
J
8
7
4
5
6
1
2
3
F
F
E
E
D
D
B - .020[0.51] MAX
A
.070 1.78 MAX
MR =.245 6.22 MIN
MN = .615[15.62] MIN
.100 2.54 TYP
RECOMMENDED PCB LAYOUT
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
8
7
6
5
4
02/05/08 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
3
A
2
DWG. NO.
C11050
SHEET 3 OF 3
1
REV
J
很抱歉,暂时无法提供与“ECC17MMRD”相匹配的价格&库存,您可以联系我们找货
