RBB110DHAN
RBB110DHAN
    SULLINS
    DIP
    CONN EDGE DUAL FMALE 220POS .050
RBB110DHAN 数据手册
High Density Card Edge .050” [1.27 mm] Contact Centers, .915” [23.24 mm] Insulator Height, Right Angle for .031” [0.79 mm], .062” [1.57 mm] or .093” [2.36 mm] Mating PCB High Density Card Edge SPECIFICATIONS • Accommodates .031” ± .006” [0.79 mm ± 0.15 mm], .062” ± .008” [1.57 mm ± 0.20 mm] or .093” ± .008” [2.36 mm ± 0.20 mm] mating PCB • PPS or PA9T insulator • Molded-in key available • High reliability/high cycle hairpin bellow & cantilever contacts • 1 Amp current rating per contact for contacts fully energized • UL Flammability Rating: 94V-0 • Operating Temperature: -65°C up to +200°C READOUT & TERMINATION TYPE HAIRPIN CANTILEVER .595” [15.11] .595” [15.11] 3X .100” [2.54] 3X .100” [2.54] .014” X .012” [0.36 X 0.30] POST .016” [0.41] SQ. POST .100” [2.54] (YY) .100” [2.54] (HA) .170” [4.32] (HB) DUAL READOUT (D) PCB LAYOUT PIN A1 3X .100” [2.54] Ø .040” [1.02] MIN. .100” [2.54] .050” [1.27] PIN A2 2X Ø.104” [2.64] FOR 'R' MOUNTING .150” [3.81] .410” [10.41] .050”[1.27] PIN B1 2X Ø.125” [3.18] FOR 'S' MOUNTING A F D PIN B2 COMPONENT SIDE MOUNTING STYLE Ø.125” [3.18] Ø.125” [3.18] .250” [6.35] .250” [6.35] .174” [4.41] CLEARANCE HOLE (D) 22 NO MOUNTING EARS (N) NO MOUNTING EARS METAL BOARD LOCK(R) SIDE MOUNTING (S) #4-40 .250” [6.35] THREADED INSERT (T) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com High Density Card Edge .050” [1.27 mm] Contact Centers, .915” [23.24 mm] Insulator Height, Right Angle for .031” [0.79 mm], .062” [1.57 mm] or .093” [2.36 mm] Mating PCB PART NUMBER OPTIONS G B B 10 D HA S - Sxxx All platings are Lead Free and have .000050” Nickel underplate Contact Surface Termination B = .000010” Gold .000100” Pure Tin, Matte C = .000030” Gold .000100” Pure Tin, Matte ***M = .000030” Gold .000010” Gold Overall ***(YY termination only) CONTACT CENTERS B = .050” [1.27 mm] ** Consult factory for special soldering guidelines. YY termination with 'M' plating only. DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. CARD LAYOUT (S) MOUNTING SHOWN E D B PIN A1 .300 [7.62] INSERTION DEPTH PIN A2 4X Ø .125 [3.18] .370 [9.40] PIN B1 REFER TO TERMINATION TYPE OPPOSITE PAGE PIN B2 .040 [1.02] R .030 [0.76] MAX. .360 [9.14] C .610 [15.49] .915 [23.24] .075 [1.91] MAX. .050 [1.27] A .300 [7.62] MIN. (B - .014[0.36]) ±.005[0.13] .250 [6.35] .050 [1.27] TYP. 60° F A High Density Card Edge MODIFICATION CODE (Consult Factory) OMIT FOR STANDARD -S1648 = .031”±.006” [0.79 ± 0.15] Mating PCB -S1763 = .093”±.008” [2.36 ± 0.20] Mating PCB (For HA & HB Termination Only) MOUNTING STYLE (Opposite Page) S = Side Mounting D = Flush Mounting N = No Mounting T = Flush Mounting With Threaded Insert R = Metal Board Lock TERMINATION TYPE (Opposite Page) HA, YY = .100” [2.54 mm] Staggered Right Angle HB = .170” [4.32 mm] Staggered Right Angle READOUT (Opposite Page) D = Dual NUMBER OF CONTACT POSITIONS See Chart Below MATERIALS (INSULATOR/CONTACT) G = PA9T/Phosphor Bronze R = PPS/Phosphor Bronze J = PA9T/Beryllium Copper A = PPS/Beryllium Copper F = PPS/Spinodal** Refer to Page 7 for Operating/Processing Temperatures CONTACT FINISH - RoHS Compliant .062 ±.008 [1.57±0.20] .020 [0.51] POSITIONS/ CONTACTS 05/10 06/12 08/16 09/18 10/20 13/26 14/28 15/30 16/32 20/40 22/44 24/48 25/50 28/56 30/60 34/68 35/70 40/80 41/82* 44/88 45/90 50/100 55/110 56/112 60/120 62/124 64/128 65/130 66/132 70/140 75/150 79/158 80/160 81/162 85/170* 90/180 92/184* 95/190 96/192* 100/200 105/210 106/212 108/216* 110/220 120/240 A±.005 B±.005 0.200 0.250 0.350 0.400 0.450 0.600 0.650 0.700 0.750 0.950 1.050 1.150 1.200 1.350 1.450 1.650 1.700 1.950 2.000 2.150 2.200 2.450 2.700 2.750 2.950 3.050 3.150 3.200 3.250 3.450 3.700 3.900 3.950 4.000 4.200 4.450 4.550 4.700 4.750 4.950 5.200 5.250 5.350 5.450 5.950 0.300 0.350 0.450 0.500 0.550 0.700 0.750 0.800 0.850 1.050 1.150 1.250 1.300 1.450 1.550 1.750 1.800 2.050 2.100 2.250 2.300 2.550 2.800 2.850 3.050 3.150 3.250 3.300 3.350 3.550 3.800 4.000 4.050 4.100 4.300 4.550 4.650 4.800 4.850 5.050 5.300 5.350 5.450 5.550 6.050 INCHES C±.015 D±.010 0.490 0.540 0.640 0.690 0.740 0.890 0.940 0.990 1.040 1.240 1.340 1.440 1.490 1.640 1.740 1.940 1.990 2.240 2.290 2.440 2.490 2.740 2.990 3.040 3.240 3.340 3.440 3.490 3.540 3.740 3.990 4.190 4.240 4.290 4.490 4.740 4.840 4.990 5.040 5.240 5.490 5.540 5.640 5.740 6.240 E±.020 0.776 1.090 0.826 1.140 0.926 1.240 0.976 1.290 1.026 1.340 1.176 1.490 1.226 1.540 1.276 1.590 1.326 1.640 1.526 1.840 1.626 1.940 1.726 2.040 1.776 2.090 1.926 2.240 2.026 2.340 2.226 2.540 2.276 2.590 2.526 2.840 2.576 2.890 2.726 3.040 2.776 3.090 3.026 3.340 3.276 3.590 3.326 3.640 3.526 3.840 3.626 3.940 3.726 4.040 3.776 4.090 3.826 4.140 4.026 4.340 4.276 4.590 4.476 4.790 4.526 4.840 4.576 4.890 4.776 5.090 5.026 5.340 5.126 5.440 5.276 5.590 5.326 5.640 5.526 5.840 5.776 6.090 5.826 6.140 5.926 6.240 6.026 6.340 ‘N’ Mounting Only F±.010 A±0.13 B±0.13 0.350 0.400 0.500 0.550 0.600 0.750 0.800 0.850 0.900 1.100 1.200 1.300 1.350 1.500 1.600 1.800 1.850 2.100 2.150 2.300 2.350 2.600 2.850 2.900 3.100 3.200 3.300 3.350 3.400 3.600 3.850 4.050 4.100 4.150 4.350 4.600 4.700 4.850 4.900 5.100 5.350 5.400 5.500 5.600 6.100 5.08 6.35 8.89 10.16 11.43 15.24 16.51 17.78 19.05 24.13 26.67 29.21 30.48 34.29 36.83 41.91 43.18 49.53 50.80 54.61 55.88 62.23 68.58 69.85 74.93 77.47 80.01 81.28 82.55 87.63 93.98 99.06 100.33 101.60 106.68 113.03 115.57 119.38 120.65 125.73 132.08 133.35 135.89 138.43 151.13 7.62 8.89 11.43 12.70 13.97 17.78 19.05 20.32 21.59 26.67 29.21 31.75 33.02 36.83 39.37 44.45 45.72 52.07 53.34 57.15 58.42 64.77 71.12 72.39 77.47 80.01 82.55 83.82 85.09 90.17 96.52 101.60 102.87 104.14 109.22 115.57 118.11 121.92 123.19 128.27 134.62 135.89 138.43 140.97 153.67 MILLIMETERS C±0.38 D±0.25 12.45 13.72 16.26 17.53 18.80 22.61 23.88 25.15 26.42 31.50 34.04 36.58 37.85 41.66 44.20 49.28 50.55 56.90 58.17 61.98 63.25 69.60 75.95 77.22 82.30 84.84 87.38 88.65 89.92 95.00 101.35 106.43 107.70 108.97 114.05 120.40 122.94 126.75 128.02 133.10 139.45 140.72 143.26 145.80 158.50 E±0.51 19.71 27.69 20.98 28.96 23.52 31.50 24.79 32.77 26.06 34.04 29.87 37.85 31.14 39.12 32.41 40.39 33.68 41.66 38.76 46.74 41.30 49.28 43.84 51.82 45.11 53.09 48.92 56.90 51.46 59.44 56.54 64.52 57.81 65.79 64.16 72.14 65.43 73.41 69.24 77.22 70.51 78.49 76.86 84.84 83.21 91.19 84.48 92.46 89.56 97.54 92.10 100.08 94.64 102.62 95.91 103.89 97.18 105.16 102.26 110.24 108.61 116.59 113.69 121.67 114.96 122.94 116.23 124.21 121.31 129.29 127.66 135.64 130.20 138.18 134.01 141.99 135.28 143.26 140.36 148.34 146.71 154.69 147.98 155.96 150.52 158.50 153.06 161.04 ‘N’ Mounting Only F±0.25 8.89 10.16 12.70 13.97 15.24 19.05 20.32 21.59 22.86 27.94 30.48 33.02 34.29 38.10 40.64 45.72 46.99 53.34 54.61 58.42 59.69 66.04 72.39 73.66 78.74 81.28 83.82 85.09 86.36 91.44 97.79 102.87 104.14 105.41 110.49 116.84 119.38 123.19 124.46 129.54 135.89 137.16 139.70 142.24 154.94 * Consult factory for availability for sizes not shown. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 23
RBB110DHAN
物料型号:SULLINS High Density Card Edge
器件简介:这是一种高密度的板卡边缘连接器,具有0.050" [1.27 mm]的接触中心间距和0.915" [23.24 mm]的绝缘体高度,适用于0.031" [0.79 mm]、0.062" [1.57 mm]或0.093" [2.36 mm]的配合PCB。
引脚分配:文档中提供了详细的引脚分配图,包括不同型号的引脚布局,例如PIN A1和PIN A2等。
参数特性: - 接触中心间距:0.050" [1.27 mm] - 绝缘体高度:0.915" [23.24 mm] - 电流额定值:每个接触点1安培 - UL阻燃等级:94V-0 - 工作温度范围:-65°C至+200°C
功能详解:连接器具有高可靠性和高循环寿命的铰接式接触点,以及可选的成型键。
应用信息:适用于需要高密度连接的应用场合。
封装信息:提供了多种安装风格和材料选项,例如PPS或PA9T绝缘体,以及不同的接触材料。
RBB110DHAN 价格&库存
很抱歉,暂时无法提供与“RBB110DHAN”相匹配的价格&库存,您可以联系我们找货
