MEC5-070-01-L-RA-W2-TR 数据手册
MICRO EDGE CARD SYSTEMS
0.50 mm, 0.635 mm, 0.80 mm, 1.00 mm, 1.27 mm, 2.00 mm PITCH
FEATURES & BENEFITS
• Up to 56 Gbps PAM4
• PCI Express® 4.0 (MEC5 Series)
• Solutions for .062" (1.60 mm), and .093" (2.36 mm) thick cards
• Choice of pitch: 0.50 mm, 0.635 mm, 0.80 mm,
• Vertical, right-angle, edge mount
Staggered press-fit tails
(MEC8-VP)
• Available in surface mount and through-hole
Justification beam ensures
card and body are flushed
(MEC5)
KEY SPECIFICATIONS
SERIES
PITCH
TOTAL
POSITIONS
INSULATOR
MATERIAL
CONTACT
MATERIAL
OPERATING
TEMP RANGE
CURRENT
RATING
VOLTAGE
RATING
LEAD-FREE
SOLDERABLE
MEC5
0.50 mm
60-200
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
1.5 A (2 pins)
125 VAC
Yes
MEC6
0.635 mm
20-140
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
2.4 A (2 pins)
195 VAC
Yes
MEC8
0.80 mm
20-140
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
1.8 A (4 pins)
185 VAC
Yes
MEC1
1.00 mm
20-140
Black LCP
Phosphor Bronze
-55 ℃ to +125 ℃
2.2 A (2 pins)
250 VAC
Yes
MECF
1.27 mm
10-100
Black/Natural LCP
BeCu
-55 ℃ to +125 ℃
3.5 A (2 pins)
280 VAC
Yes
MEC2
2.00 mm
10-100
Black/Natural LCP
BeCu
-55 ℃ to +125 ℃
3.5 A (2 pins)
238 VAC
Yes
F-221
samtec.com/EdgeCard
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
(0.50 mm) .0197" PITCH • MICRO EDGE CARD SOCKET
MEC5
POSITIONS
PER ROW
-030, -040, -050,
-060, -070, -080
01
PLATING
OPTION
–L
=10 µ" (0.25 µm)
Gold on contact,
Matte Tin on tail
(-RA & -DV)
-090, -100
(-DV only)
TAIL
OPTION
–DV
WELD TAB
OPTION
–W1
Vertical
–K
= Weld Tab
Through-hole
(Required for
-DV option)
–RA
Right-angle
OTHER
OPTION
= Polyimide Pick
& Place Pad
(Required for
-DV)
(Not available
in -RA)
–W2
= Weld Tab
Surface Mount
(Not available
for -DV)
MEC5-DV
POSITIONS
PER ROW
B
A
No. of Positions x (0.50) .0197 + (10.38) .409
B
(4.60)
.181
A
(4.60)
.181
Leave blank for
Tray Packaging
–TR
= Tape & Reel
–FR
= Full Reel
Tape & Reel
(must order max.
quantity per reel;
contact Samtec
for quantity
breaks)
Card Mates:
(1.60 mm) .062"
thick card with
standard board
tolerance
“X”R
(5.85)
.230
(5.85)
(10.25)
.230
.404
(10.25)
.404
C
A
B
C
–030
(17.10)
.673
N/A
(21.63)
.852
–040
(22.10)
.870
N/A
(26.63)
1.048
–050
(29.60)
1.165
(15.48)
.609
(34.13)
1.344
–060
(34.60)
1.362
(17.98)
.708
(39.13)
1.541
–070
(39.60)
1.559
(20.48)
.806
(44.13)
1.737
–080
(44.60)
1.756
(22.98)
.905
(49.13)
1.934
–090
(49.60)
1.953
(25.48)
1.003
(54.13)
2.131
–100
(54.60)
2.150
(27.98)
1.102
(59.13)
2.328
Note: Polarization rib is not present on
–030 & -040 positions
C
View complete specifications at: samtec.com?MEC5-DV
MEC5-RA
POSITIONS
PER ROW
Card Mates:
(1.60 mm) .062"
thick card with
standard board
tolerance
–30
–40
–50
–60
(10.25)
.404
–70
–80
A
B
(23.38)
.920
(28.38)
1.117
(35.88)
1.413
(40.88)
1.609
(45.88)
1.806
(50.88)
2.003
(17.10)
.673
(22.10)
.870
(29.60)
1.165
(34.60)
1.362
(39.60)
1.559
(44.60)
1.756
C
N/A
N/A
(15.44)
.608
(17.94)
.706
(20.44)
.805
(22.94)
.903
A
D
(18.16)
.715
(23.16)
.912
(30.66)
1.207
(35.66)
1.404
(40.66)
1.601
(45.66)
1.798
B
C
(10.25)
.404
D
A
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
(11.38)
.448
(13.53) .532
B
View complete specifications at: samtec.com?MEC5-RA
C
samtec.com/EdgeCard
(11.38)
D
F-221
MEC5-070-01-L-RA-W2-TR 价格&库存
很抱歉,暂时无法提供与“MEC5-070-01-L-RA-W2-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+118.914701+15.38344
- 10+101.0380910+13.07082
- 25+94.7133725+12.25262
- 50+90.1906950+11.66755
- 100+85.90607100+11.11327
- 国内价格 香港价格
- 250+70.63001250+9.13707
- 500+70.18481500+9.07948
