EBC36MMNN
EBC36MMNN
    SULLINS
    CONN CARDEDGE MALE 72POS 0.100
EBC36MMNN 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY F 2868 UPDATE 'BOM' ON PRODUCTION DRAWING 11/26/2013 KV H 3182 UPDATE DWG FORMAT, UPDATE INSERT INSTALLATION IN 'V' MOUNTING 4/16/2015 MG 3613 ADD S2196, REMOVE 'A' MATERIAL, ADD 'Q' MATERIAL, ADD PCB LAYOUT RECOMMENDED TO CUSTOMER DRAWING, UPDATE 'R' MATERIAL OPERATING TEMPERATURE, REMOVE 'Y' & 'S' PLATING 2/1/2017 EP F J 2X E F D C A .125 3.18 THRU E +.005 +0.13 .370 9.40 - .015 - 0.38 B (.025 0.64 ) DEPTH FROM TOP OF INSULATOR TO TOP OF PIN D A FITS EDGECARDS THAT ACCEPT .062 1.57 PCB's D .540±.010 13.72±0.25 .250 6.35 .030 0.76 C ACCOMMODATES .062[1.57] PCB .025 0.64 SECTION A-A MR = .175±.025 4.45±0.64 MN = .545 .025[13.84 0.64] A .100 2.54 _ _C_ _M(MR,MN)D _ _C_ _M(MR,MN)D-S2196 B A C B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE:SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 700 VAC 8. CURRENT RATING: 3 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 12. MODIFICATION: SEE PART NUMBER CODING. 8 7 6 5 CUSTOMER COPY Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 02/05/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _C_ _M(MR,MN)_-(S2196) CAGE CODE 54453 SCALE: 3:1 3 A MALE, CARD EXTENDER, .100 CC 2 DWG. NO. C11050 SHEET 1 OF 3 1 REV J FILE NAME: C11050, _ _C_ _M(MR,MN)_-(OMIT,S2196) 8 7 4 5 6 E F 1 2 3 2X #4-40 THREADED INSERTS F C E E _ _C_ _M(MR, MN)T _ _C_ _M(MR, MN)T-S2196 _ _C_ _M(MR, MN)N _ _C_ _M(MR, MN)N-S2196 D D C C C C .125 3.18 .125 3.18 B .125 3.18 B 2X #4-40 THREADED INSERTS _ _C_ _M(MR, MN)Z _ _C_ _M(MR, MN)Z-S2196 _ _C_ _M(MR, MN)V _ _C_ _M(MR, MN)V-S2196 CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 02/05/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _C_ _M(MR,MN)_-(S2196) CAGE CODE 54453 SCALE: 3:1 3 A MALE, CARD EXTENDER, .100 CC 2 DWG. NO. C11050 SHEET 2 OF 3 1 REV J FILE NAME: C11050, _ _C_ _M(MR,MN)_-(OMIT,S2196) 8 7 4 5 6 1 2 3 F F E E D D B - .020[0.51] MAX A .070 1.78 MAX MR =.245 6.22 MIN MN = .615[15.62] MIN .100 2.54 TYP RECOMMENDED PCB LAYOUT C C B B CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 02/05/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C _ _C_ _M(MR,MN)_-(S2196) CAGE CODE 54453 SCALE: 2:1 3 A MALE, CARD EXTENDER, .100 CC 2 DWG. NO. C11050 SHEET 3 OF 3 1 REV J FILE NAME: C11050, _ _C_ _M(MR,MN)_-(OMIT,S2196)
EBC36MMNN
1. 物料型号:文档中提到了多种型号,例如C04M到C59M,以及C60M,这些型号可能代表不同的配置或尺寸。
2. 器件简介:文档描述了一种名为"MALE, CARD EXTENDER, .100 CC"的器件,这似乎是一种用于电路板的连接器。
3. 引脚分配:文档提供了详细的引脚分配信息,包括每个型号的引脚数量和相应的尺寸。
4. 参数特性:包括了操作温度范围、加工温度、UL阻燃等级、操作电压、电流额定值、接触电阻和绝缘电阻等。
5. 功能详解:文档中提到了连接器的不同特性,如接触材料、绝缘材料、镀层等,并指出了不同材料和镀层的适用性。
6. 应用信息:文档建议了PCB布局的推荐方式,以及不同材料和镀层的适用性。
7. 封装信息:提供了连接器的尺寸和形状信息,以及不同型号的详细尺寸。
EBC36MMNN 价格&库存
很抱歉,暂时无法提供与“EBC36MMNN”相匹配的价格&库存,您可以联系我们找货
