MPSL-0156-43-DW-1KGH
    SULLINS
    CONN EDGE DUAL FMALE 86POS 0.156
MPSL-0156-43-DW-1KGH 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY A 2472 INITIAL RELEASE 10/11/2011 JH 16 FIRST POSITION INDICATOR F E D B A 2X .125 3.18 THRU 16 .030±.010 0.76±0.25 E .075 1.91 CARDSLOT 16 +.005 +0.13 .370 9.40 - .015 - 0.38 C .180 4.57 1 A .250 6.35 .020 0.51 .297 7.54 INSERTION DEPTH 16 .610 15.49 D .025 0.64 FITS .040 [1.01] MIN. HOLE .156 3.96 TYP 17 2 A .060 1.52 17 2X .125 3.18 FOR MOUNTING STYLE 1, 2, 5 OR 6 D A CONTACT MARKINGS (LETTERS G, I, O & Q NOT USED) .200 5.08 .156 3.96 TYP B A 17 INSPECTION VALIDATION REQUIRED. FIT CHECK ROW SPACING AND PITCH USING SULLINS INSPECTION BOARD. MUST FIT FREELY WITHOUT FORCE 18. MODIFICATION: SEE PART NUMBER CODING. 8 7 SIZES 06-25 & 30 1 2 ... 23 24 ... A B ... A B ... SIZES 28 & 31 1 2 ... 23 24 ... A B ... A B ... SIZES 36 - 43 A B ... A B ... 1 2 ... 23 24 ... PCB LAYOUT RECOMMENDED NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: SEE PART NUMBER CODING. 3. PLATING: SEE PART NUMBER CODING. 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING. 5. PROCESSING TEMP: SEE PART NUMBER CODING. 6. UL FLAMMABILITY RATING: 94V-0 7. DIELECTRIC WITHSTANDING VOLTAGE: 950 VAC MINIMUM AT SEA LEVEL 8. CURRENT RATING: 3 AMPS PER CONTACT 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. DURABILITY: 500 CYCLES MIN 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE 15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB 16 UNLESS OTHERWISE SPECIFIED INSPECTION VALIDATION REQUIRED 6 C 29 30 H J 30 31 J K X Y 42 43 CONTACT ID SCALE 4:1 B REF: _ _M_ _DRS_-(OMIT, S38, S81, S328) _ _M_ _DRM_-(OMIT, S38, S81, S328) 2 _ _ M-DRS, DRM CONTACT PIN 10030 A/R 1 M _ _ M_(-A_ _) .156 CC, HIGH PROFILE BODY 10020 1 ITEM PART NO DESCRIPTION DWG NO QTY BILL OF MATERIALS DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 5 D SECTION A-A SCALE 2 : 1.25 MP_ _-_156-_ _-DW-5H_ _Z_ (REF:_ _ M _ _ DRSH) MP_ _-_156-_ _-DW-5_ _Z_ (REF: _ _ M _ _ DRMH) C 16 H=.190±.025 4.83±0.64 OMIT=.560 .025[14.22 0.64] (SEE PN CODING) .200 5.08 ROW SPACING F .040 1.02 E 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 10/11/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, HP PART NUMBER SIZE C MP_ _-_156-_ _-DW-_ (H) _ _(Z)_ CAGE CODE 54453 SCALE: 2:1.25 2 DWG. NO. REV 11894 SHEET 1 OF 3 1 A FILE NAME: 11894, MP_ _-_156-_ _DW-_ (H, OMIT) _ _(Z)_, REF _ _M_ _DRS (DRM) _ (OMIT, -S38, S81, S328) 8 7 D F 4 5 6 2X #4-40 THREADED INSERTS .250 6.35 2X 1 2 3 .125 3.18 THRU D F .250 6.35 E E MP_ _-_156-_ _-DW-1H_ _(Z)_ (REF:_ _ M _ _ DRSD) MP_ _-_156-_ _-DW-1_ _(Z)_ (REF: _ _ M _ _ DRMD) MP_ _-_156-_ _-DW-6H_ _Z_ (REF:_ _ M _ _ DRSI) MP_ _-_156-_ _-DW-6_ _Z_ (REF: _ _ M _ _ DRMI) D D 2X #4-40 THREADED INSERTS C C D C .250 6.35 MP_ _-_156-_ _-DW-4H_ _Z_ (REF:_ _ M _ _ DRSN) MP_ _-_156-_ _-DW-4_ _Z_ (REF: _ _ M _ _ DRMN) MP_ _-_156-_ _-DW-2H_ _(Z)_ (REF:_ _ M _ _ DRST) MP_ _-_156-_ _-DW-2_ _(Z)_ (REF: _ _ M _ _ DRMT) B B DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 10/11/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, HP PART NUMBER SIZE C MP_ _-_156-_ _-DW-_ (H) _ _(Z)_ CAGE CODE 54453 SCALE: 1:1 2 DWG. NO. REV 11894 SHEET 2 OF 3 1 A FILE NAME: 11894, MP_ _-_156-_ _DW-_ (H, OMIT) _ _(Z)_, REF _ _M_ _DRS (DRM) _ (OMIT, -S38, S81, S328) 8 7 4 5 6 1 2 3 F F E E D D C C B B DRAWN UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb A TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 8 7 6 5 4 ANGULAR: 30' .02 [.5] .005 [.13] .0005 [.013] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 10/11/2011 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE A EDGECARD, .156 CC, HP PART NUMBER SIZE C MP_ _-_156-_ _-DW-_ (H) _ _(Z)_ CAGE CODE 54453 SCALE: 2:1 2 DWG. NO. REV 11894 SHEET 3 OF 3 1 A FILE NAME: 11894, MP_ _-_156-_ _DW-_ (H, OMIT) _ _(Z)_, REF _ _M_ _DRS (DRM) _ (OMIT, -S38, S81, S328)
MPSL-0156-43-DW-1KGH 价格&库存
很抱歉,暂时无法提供与“MPSL-0156-43-DW-1KGH”相匹配的价格&库存,您可以联系我们找货
  • 1+116.637491+15.09018
