EBM12MMBN
EBM12MMBN
    SULLINS
    CONN CARDEDGE MALE 24POS 0.156
EBM12MMBN 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY K 3797 UPDATE P/N CODING TO INCLUDE MOLDED KEY SLOT BETWEEN POSITIONS 1/18/2018 JH L 3832 UPDATE KEY SLOT WIDTH BETWEEN POSITIONS FROM .042 TO .048", ADD S# TO SLOST LOCATION CHART 4/2/2018 JH F D C A +.005 +0.13 .370 9.40 - .015 - 0.38 E 2X .125 3.18 E FITS EDGECARDS THAT ACCEPT .062[1.57] PCB'S .156 3.96 B D (.025 0.64 ) DEPTH FROM TOP OF INSULATOR TO TOP OF PIN MA = .100±.025 2.54±0.64 MV = .130 .025 [3.30 0.64] MB = .180 .025 [4.57 0.64] MD = .250 .025 [6.35 0.64] MJ = .500 .025 [12.70 0.64] MK = .560 .025 [14.22 0.64] A .540±.010 13.72±0.25 D .050±.010 1.27±0.25 .250 6.35 .030 0.76 .025 0.64 A _ _M_ _M_ _D STD = .150 3.81 ROW SPACING S189 = .200 [5.08] ROW SPACING SECTION A-A C C .150 3.81 (FOR STANDARD) .200[5.08] (FOR S189) A .145 3.68 .043 1.09 MIN .156 3.96 2X .125 3.18 FOR Z OR V MOLUNTING C PCB LAYOUT RECOMMENDED (COMPONENT SIDE) B A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 950 VAC 8. CURRENT RATING: 3 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHMS 11. CONNECTOR IDENTIFICATION: PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 12. MODIFICATION: SEE PART NUMBER CODING 8 7 6 5 B CUSTOMER COPY Pb RoHS COMPLIANT 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 03/14/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE MALE, RIGHT ANGLE BEND, .156 CC PART NUMBER _ _M_ _M(MA,MV,MB,MD,MJ,MK)_(-S189) SIZE C CAGE CODE 54453 SCALE: 3:1 3 A 2 DWG. NO. C11076 SHEET 1 OF 4 1 REV L FILE NAME: C11076, _ _M_ _M(MA,MV,MB,MD,MJ,MK)_-OMIT, S189, S_ _ _ _ STD KEY SLOT BETWEEN POSITIONS 8 7 4 5 6 1 2 3 F C F E 2X #4-40 THREADED INSERTS E E _ _M_ _M_ _N _ _M_ _M_ _T D D C C C C 2X .125 3.18 .125 3.18 B .125 3.18 _ _M_ _M_ _Z B 2X #4-40 THREADED INSERTS _ _M_ _M_ _V CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 03/14/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE MALE, RIGHT ANGLE BEND, .156 CC PART NUMBER _ _M_ _M(MA,MV,MB,MD,MJ,MK)_(-S189) SIZE C CAGE CODE 54453 SCALE: 2:1 3 A 2 DWG. NO. C11076 SHEET 2 OF 4 1 REV L FILE NAME: C11076, _ _M_ _M(MA,MV,MB,MD,MJ,MK)_-OMIT, S189, S_ _ _ _ STD KEY SLOT BETWEEN POSITIONS 8 7 4 5 6 1 2 3 WITHOUT MOLDED KEY SLOT F F E E WITH MOLDED KEY SLOT (SEE PAGE 4) D D C C B B CUSTOMER COPY Pb A RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 03/14/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE MALE, RIGHT ANGLE BEND, .156 CC PART NUMBER _ _M_ _M(MA,MV,MB,MD,MJ,MK)_(-S189) SIZE C CAGE CODE 54453 SCALE: 3:1 3 A 2 DWG. NO. C11076 SHEET 3 OF 4 1 REV L FILE NAME: C11076, _ _M_ _M(MA,MV,MB,MD,MJ,MK)_-OMIT, S189, S_ _ _ _ STD KEY SLOT BETWEEN POSITIONS 8 7 4 5 6 1 2 3 STANDARD KEY SLOT LOCATION TABLE*** F F E E G .048±.002 1.22±0.05 D D ('D' MOUNTING AS SHOWN FOR EXAMPLE) C C B B CUSTOMER COPY Pb A ***CONNECTOR TOTAL POSITIONS MUST BE AT LEAST ONE POSITION LONGER THAN KEY SLOT LOCATION RoHS COMPLIANT 8 7 6 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 03/14/08 MNH TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER _ _M_ _M(MA,MV,MB,MD,MJ,MK)_-S_ _ _ _ SIZE C CAGE CODE 54453 SCALE: 3:1 3 A MALE, RIGHT ANGLE BEND, .156 CC, KEY SLOT BETWEEN POSITIONS 2 DWG. NO. C11076 SHEET 4 OF 4 1 REV L FILE NAME: C11076, _ _M_ _M(MA,MV,MB,MD,MJ,MK)_-OMIT, S189, S_ _ _ _ STD KEY SLOT BETWEEN POSITIONS
EBM12MMBN 价格&库存
很抱歉,暂时无法提供与“EBM12MMBN”相匹配的价格&库存,您可以联系我们找货
