8
7
4
5
6
1
2
3
REVISIONS
E
D
B
A
F
2X
D
.125 3.18
THRU
REV.
ECO. NO
DESCRIPTION
DATE
BY
D
556
UPDATE PRINT TO BE FOR SULLINS CUSTOMERS ONLY. SHOW
ONLY CUSTOMER REQUIREMENTS
3/2/2005
MNH
E
669
ADDED UP TO 100 POSITIONS
7/5/2005
TT
F
880
UPDATED FORMAT
3/21/2006
MNH
G
1496
3/18/2008
VJ
H
2475
10/20/2011
JH
J
3028
ADDED HEADER TO FOURTH ROW, TABULATED MATERIAL
ADDED POSI # TO 100, UPDATED DIM A ( WAS A1 & A2),
INSPECTION NOTE 16 & 17, DIM SIDE MTG HOLES TO TOP
INSULATOR EDGE, CONTACT GAP .030 .010, INSERTION
FORCE 8OZ, PROCESSING TIME 20 SEC FOR 'G' & 'J' MTL
UPDATE INSERT FROM FAR SIDE ON 'A' MOUNTING
7/30/2014
JHSU
F
.075 1.91
SEE NOTE 13
.050 1.27 TYP
A+.050[1.27]
E
2X
E
D
C
.125 3.18
THRU
A
.030±.010 0.76±0.25
GAP WIDTH
B
.541 13.74
INSERTION
DEPTH
.250 6.35
2X .428 10.87
.030±.010 0.76±0.25
LOWER GAP
+.005
+0.13
.375
9.53
- .015
- 0.38
(.017 0.43 ) DEPTH
FROM TOP OF INSULATOR
TO TOP OF PIN
.445 11.30
CONTACT POINT
.900±.010 22.86±0.25
D
.250 6.35
C
A
_ _B_ _DKBS
.123 3.12
CONTACT POINT
2X .472±.015 11.99±0.38
B
3X .100 2.54
ROW SPACING
.025 0.64
4X .185±.025 4.70±0.64
TAIL LENGTH
SECTION A-A
A+.050[1.27]
A
C
A1
B1
3X .100 2.54
B2
A1
.043 1.09 MIN
A2
A1
DETAIL C
SCALE 3 : 1
D
RECOMMENDED PCB LAYOUT
COMPONENT SIDE
B
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING
2. CONTACT MATERIAL: SEE PART NUMBER CODING
3. PLATING: SEE PART NUMBER CODING
4. OPERATING TEMPERATURE: SEE PART NUMBER CODING
5. PROCESSING TEMP: SEE PART NUMBER CODING
6. UL FLAMMABILITY RATING: 94V-0
7. OPERATING VOLTAGE: 225 VAC MINIMUM AT SEA LEVEL
8. CURRENT RATING: 3 AMP
9. CONTACT RESISTANCE: 30 MILLI OHMS MAX
10. INSULATION RESISTANCE: 5000 MEGA OHMS
11. DURABILITY: 500 CYCLES MIN
12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE
13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20]
14. INSERTION FORCE: 8 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE
15. WITHDRAWAL FORCE: 1 OZ MIN PER CONTACT PAIR USING .062[1.57] PCB
7
6
C
A2
2X .125 3.18
NOT REQUIRED FOR
H, I, OR N MOUNTING
.338 8.57
8
FIRST POSITION
INDICATOR
B1
.472 11.99
A
SECTION B-B
.010 0.25 MAX GAP
BETWEEN UPPER AND
LOWER INSULATORS
.050 1.27
.050 1.27
.100 2.54
A2
B2
D
5
B1
B2
DETAIL D
SCALE 3 : 1
B
CUSTOMER COPY
Pb
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
5/24/2005 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1.5
4
3
2
A
BI-LEVEL, .050 CC, RAB
_ _B_ _ DKB_
DWG. NO.
C10214
SHEET 1 OF 4
1
REV
J
FILE NAME: C10214, _ _B_ _DKB_
8
7
4
5
6
1
2
3
D
F
F
2X
.125 3.18
THRU
2X #4-40
THREADED INSERT
(FROM FAR SIDE)
E
D
E
2X .428 10.87
_ _B_ _DKBH
_ _B_ _DKBA
D
D
D
2X #4-40
THREADED
INSERTS
C
C
C
B
B
_ _B_ _DKBI
_ _B_ _DKBN
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
5/24/2005 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1.5
8
7
6
5
4
3
2
A
_ _B_ _ DKB_
DWG. NO.
C10214
SHEET 2 OF 4
1
REV
J
8
7
4
5
6
.093 2.36
1
2
3
A
F
.100 2.54 TYP
B1 (A1 OPPOSITE)
F
CL OF
BOARD
.050 1.27 TYP
.062±.008 1.57±0.20
.245 6.22 TYP.
.591 15.01
.295 7.49
.245 6.22
E
.060 1.52 TYP
B2 (A2 OPPOSITE)
E
.093 2.36
.025 0.64
REQ'D FOR RIGID MOUNT PCB ONLY
E
A
F
DAUGHTER CARD LAYOUT NUMBER 1
90 POSITION SHOWN
REFER TO PAGE 4 TO DETERMINE LAYOUT TO USE
D
D
.093 2.36
A
CL OF
BOARD
.100 2.54 TYP.
B1 (A1 OPPOSITE)
.050 1.27 TYP.
C
.245 6.22 TYP.
.591 15.01
.295 7.49
C
60.0°
.245 6.22
.060 1.52 TYP.
B2 (A2 OPPOSITE)
.062±.008 1.57±0.20
.093 2.36
.025 0.64
.020 0.51
A
F
B
DETAIL E
SCALE 10 : 1
B
DAUGHTER CARD LAYOUT NUMBER 2
88 POSITION SHOWN
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
5/24/2005 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
8
7
6
5
4
3
2
A
_ _B_ _ DKB_
DWG. NO.
C10214
SHEET 3 OF 4
1
REV
J
8
7
4
5
6
1
2
3
F
F
E
E
D
D
C
C
B
B
CUSTOMER COPY
Pb
A
RoHS COMPLIANT
5/24/2005 MNH
TOLERANCES:
ANGULAR:
1
DECIMALS
.XX= .02 [.5]
.XXX= .005 [.13]
.XXXX= .0005 [.013]
TITLE
PART NUMBER
SIZE
C
CAGE CODE
54453
SCALE: 2:1
8
7
6
5
4
3
2
A
_ _B_ _ DKB_
DWG. NO.
C10214
SHEET 4 OF 4
1
REV
J
很抱歉,暂时无法提供与“ACB12DKBS”相匹配的价格&库存,您可以联系我们找货
