32.768kHz Series
OX / OY Type
3.2 x 2.5 / 2.5 x 2.0 mm SMD Oscillator
Actual Size
Actual Size
FEATURE
- Tight symmetry (45 to 55%) available.
- Operation voltage: 1.8V, 2.5V, 3.3V
- Tri-state enable/disable
- Built-in ASIC enables reduction of current consumption.
TYPICAL APPLICATION
- Typically used for real time clock application.
- Mobile Phone
- DSC,Set-top Box ,HDTV
- Car navigation systems.
RoHS Compliant
DIMENSION (mm)
SOLDER PAD L AYOUT (mm)
[ TO P VIEW ]
2.10 ± 0.15
1.65 ± 0.15
#2
#2
0.35
0.95 ± 0.15
Pin#
1.20
Tri-state
GND
Output
VDD
To ensure optimal oscillator performance, place a by-pass capacitor of 0.1μF
as close to the part as possible between Vdd and GND pads.
0.1 μF
[ B O T T O M V IE W ]
1.625 ± 0.10
#2
#2
#1
0.675 ± 0.10
0.81 ± 0.15
Pin#
1
2
3
4
1.225
#4
0.80
#3
0.57 ± 0.10
1.225 ± 0.10
#3
2.00 ± 0.20
2.50 ± 0.20
0.29
2.10
Function
1
2
3
4
[ TO P VIEW ]
#1
#1
0.90 ± 0.15
[ S ID E V IE W ]
[ S ID E V IE W ]
0.65 ± 0.15
#1
#4
1.60
#3
#3
2.50 ± 0.15
#4
1.10
3.20 ± 0.15
#4
0.1 μF
1.625
0.675
Function
0.90
Tri-state
GND
Output
VDD
ELECTRICAL SPECIFICATION
Parameter
Min.
Supply Voltage Variation (VDD)
Supply Current (@ 15pF load)
(@ no load)
Duty Cycle
Output Level (CMOS) Output High (Logic “1”)
Output Low (Logic “0”)
Transition Time:Rise/Fall Time+
Start Time
Tri-State(Input to Pin 1) Enable (High voltage or floating)
Disable (Low voltage or GND)
st
Aging (@25 C 1 year)
3.3V
VDD-10%
45
2.97
2.31
Max.
VDD+10%
120
80
55
0.33
50
2
0.99
±3
Min.
2.5V
VDD-10%
45
2.25
1.75
Max.
VDD+10%
Min.
1.8V
VDD-10%
120
80
55
0.25
50
2
0.75
±3
Storage Temp. Range
-55
125
-55
125
Standard frequencies are frequencies which the crystal has been designed and does not imply a stock position
+Transition times are measured between 10% and 90% of VDD,withan output load of 15pF
45
1.62
1.26
Unit
Max.
VDD+10%
V
120
80
55
0.18
50
2
0.54
-55
125
V
nSec
mSec
V
±3
ppm
FREQ. STABILITY vs. TEMP. RANGE
Temp. (℃ )
ppm
±20
±25
±40
- 1 0 ~+ 6 0
-20~+70
-4 0 ~+8 5
-40~+105
-40~+125
±50
* O: Available △:Conditional
X: Not available
*Inclusive of calibration @ 25℃, operating temperature range, input voltage variation,
load variation, aging (1st year), shock, and vibration load variation
Note: not all combination of options are available. Other specifications may be available upon request.
30
Specifications subject to change without notice.
www.taitien.com
sales@taitien.com.tw
Rev(8) 05/2020
OYKTELJANF-0.032768 价格&库存
很抱歉,暂时无法提供与“OYKTELJANF-0.032768”相匹配的价格&库存,您可以联系我们找货
