8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
C
2668
D
2828
E
3535
F
E
DESCRIPTION
DATE
ADD 'LCP' MATERIAL AND REMOVE 'NYLON 9T'
09/06/2012
UPDATE PROCESSING TEMPERATURE FOR NYLON 6T
MATERIAL, ADD 2-POSITION DIMENSION ON TABLE, 04/09/2015
UPDATE LCP OPERATING TEMP TO -40 C TO +125 C
(WAS -40 C TO +105 C)
ADD WARP TOLERANCE AND SMT TAIL COPLANAR 10/05/2016
TOLERANCE ON DRAWING
BY
LH
LH
F
LH
B 0.012[ 0.30]
PIN 1
E
.100 2.54
_R_C_ _ _S_ _C-M30RC
(STANDARD)
A
B 0.012[ 0.30]
PIN 1
.039 1.00
D
D
.100 2.54
PIN 1
C DIM.
_R_C_ _ _S_ _D-M30RC
(OPPOSITE BEND, ONLY APPLICABLE ON EVEN PIN COUNTS)
.100 2.54
.200 5.08
RECOMMEND PCB LAYOUT
(STANDARD)
A
C
C
A
HEAD DIM.
PIN 1
.100 2.54
.200 5.08
C DIM.
.160 4.06
B
.004[0.10] 02-25 POSITIONS
.098 2.50
.100 2.54
.025 0.64
(OPPOSITE BEND)
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, BLACK.
2. CONTACT MATERIAL: SEE PART NUMBER CODING.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 3 AMPS.
5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
6. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
7. DIELECTRIC WITHSTANDING: 1000 V AC.
8. OPERATING TEMPERATURE: SEE PART NUMBER CODING.
8
7
B
TAIL DIM .010[0.25]
02 - 10, 0.10mm MAX.
11 - 25, 0.20mm MAX.
26 - 40, 0.30mm MAX.
A
.039 1.00
.005[0.12] 26-40 POSITIONS
6
Pb
RoHS COMPLIANT
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN INCHES [MM]
TOLERANCES:
ANGULAR:
.XX= .01 [.3]
.XXX= .008 [.20]
.XXXX= .0040 [.100]
DRAWN
DATE
NAME
03/22/2011 LH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER MALE .100"[2.54mm]PITCH, SMT
PART NUMBER
SIZE
C
_R_C_ _ _S(AB,FB,ZS,ZT)_-M30RC
CAGE CODE
54453
SCALE: 4:1
3
2
DWG. NO.
REV
11657
SHEET 1 OF 1
1
E
FILE NAME: 11657, _R_C_ _ _S(AB,FB,ZS,ZT)_-M30RC
A
很抱歉,暂时无法提供与“NREC015SABC-M30RC”相匹配的价格&库存,您可以联系我们找货
