HIF6H-100PA-1.27DS(71) 数据手册
0.635mm Pitch ID Cable Connectors
HIF6H Series
■Features
1. Batch Insulation Displacement of 0.635mm Pitch ID
Cable Connector
The 0.635mm pitch cable can be insulated and displaced at a
time. HIF6 series is displaced two sheets cable with one sheet
cable.
2. Applicable Cable 30 AWG
The applicable cable is 30 AWG cable.
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
3. Achieve Bus-line Connection
This connector allows connection to No. 1 pin. By changing the
cover, bus-line connection can be allowed.
4. Compatibility
This connector allows engagement with the HIF6A(B) series
header. However, the lock header is used for the HIF6H series
only.
Note : HIF6H series should be ordered together with the cable.
■Product Specifications
Rating
Current rating : 0.5A
Item
1. Insulation Resistance
Operating Temperature Range : -55 to +85ç(Note 1) Storage Temperature Range : -10 to +60ç(Note 2)
Voltage rating : 125V AC Operating Moisture Range : -40 to 80%
: -40 to 70%(Note 2)
Storage Humidity Range
Specification
Condition
1000MΩ min.
250V DC
2. Withstanding voltage
No flashover or insulation breakdown.
300V AC/1 minute
3. Contact Resistance
30mΩ max.
0.1A
4. Vibration
No electrical discontinuity of 1μs or more
Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Insulation resistance : 1000MΩ min.
6. Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
( -65ç : 30 minutes ->15 to 35ç : 5 minutes max.
(125ç : 30 minutes-> 15 to 35ç : 5 minutes max.) 5 cycles
No damage, cracks, or parts looseness.
7. Durability (Mating/un-mating) Contact resistance : 30mΩ max.
8. Resistance to Soldering heat
500 cycles
No deformation of components affecting performance.
Solder Bath : 260ç for 10 seconds
Manual soldering : 360ç for 5 seconds
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
■Materials / Finish
Part
Material
Finish
Remarks
Black
UL94V-0
Selective gold plated
Insulator
PBT
Socket Contact
Copper alloy
Pin header contact
Brass
B87
HIF6H Series●0.635mm Pitch ID Cable Connectors
■ Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Pin Header
HIF6H - * P A - 1.27 DSA
q
w
q Series Name
e
r
t
y
: HIF 6H
w Number of contacts : 34, 40, 50, 60, 80, 100
e P : Pin header
r A : Selective gold plating
t Contact Pitch
: 1.27mm
y Contact style
: DS : Right angle type
DSA : Straight type
●Socket
HIF6H - * D - 1.27 R
q
q Series Name
w
e
r
t
: HIF6H : Standard type
HIF6HB : Bus connection type
e D : Socket
r Contact Pitch : 1.27mm
t R : ID type
* If needed, please order HIF6H series connectors with cable attached.
Designate the connection circuit and cable length.
B88
BFunction Block Chart
Pin Header
Socket
HIF6-*PA-1.27DS
HIF6-*D-1.27R
Use two pieces of
HIF6-*PA-1.27DSA
1.27mm cables.
HIF6H-*PA-1.27DS
HIF6H (B) -*D
-1.27R
Use a piece of
HIF6H -*PA-1.27DSA
HIF6A (B) -*PA
-1.27DSA
HIF6A (B) -*PA
-1.27DS
0.635mm cable.
HIF6A (B) -*DA
-1.27DSA
HIF6A (B) -*DA
-1.27DS
B89
■Socket
Combination Pattern
Body
Cover B
(40.60.80.100 contacts)
(34.50 contacts)
(34.50 contacts)
Unit : mm
Part No.
No. of Contacts
A
B
C
HIF6H-034D-1.27R(20)
34
27.44
20.32
21.84
HIF6H-040D-1.27R(20)
40
31.25
24.13
25.65
HIF6H-050D-1.27R(20)
50
37.60
30.48
32.00
HIF6H-060D-1.27R(20)
60
43.95
36.83
38.35
HIF6H-080D-1.27R(20)
80
56.65
49.53
51.05
HIF6H-100D-1.27R(20)
100
69.35
62.23
63.75
RoHS
YES
Designate the connection circuit and cable length on catalog pages B94 and B95.
Please note that even when socket units are purchased, wiring will not be possible
other than at Hirose Electric.
B90
Cover A
(34.50contacts)
■Socket for bus-line connection
Combination Pattern
Body
Cover B
Cover A
(40.60.80.100
(40.60.80.100
contacts)
contacts)
(34.50 contacts)
(34.50 contacts)
(40.60.80.100
(40.60.80.100contacts)
contacts)
(34.50contacts)
Unit : mm
Part No.
No. of Contacts
A
B
HIF6HB-034D-1.27R(20)
34
27.44
20.32
21.84 20.955
C
D
HIF6HB-040D-1.27R(20)
40
31.25
24.13
25.65 24.765
HIF6HB-050D-1.27R(20)
50
37.60
30.48
32.00 31.115
HIF6HB-060D-1.27R(20)
60
43.95
36.83
38.35 37.465
HIF6HB-080D-1.27R(20)
80
56.65
49.53
51.05 50.165
HIF6HB-100D-1.27R(20)
100
69.35
62.23
63.75 62.865
RoHS
YES
* Please order HIF6H series connectors with cable attached.
Designate the connection circuit and cable length on pages B94 and B95.
Please note that even when socket units are purchased, wiring will not be possible other
B91
■Right Angle Pin Header
BPCB mounting pattern
●indicates mark positions.
Mating Side
Mating Side
(34.50 contacts)
Unit : mm
Part No.
B92
No. of Contacts
A
B
C
D
E
F
HRS No.
HIF6H-034PA-1.27DS(71) 630-0166-4 71
34
39.84
20.32
38.24
27.64
30.48
59.64
HIF6H-040PA-1.27DS(71) 630-0161-0 71
40
43.65
24.13
42.05
31.45
34.29
63.45
HIF6H-050PA-1.27DS(71) 630-0162-3 71
50
50.00
30.48
48.00
37.80
40.64
69.80
HIF6H-060PA-1.27DS(71) 630-0163-6 71
60
56.35
36.83
54.75
44.15
46.99
76.15
HIF6H-080PA-1.27DS(71) 630-0164-9 71
80
69.05
49.53
67.45
56.85
59.69
88.85
HIF6H-100PA-1.27DS(71) 630-0165-1 71
100
81.75
62.23
80.15
69.55
72.39
101.55
RoHS
YES
■Straight Pin Header
(40, 60, 80, 100 contacts)
(34.50contacts)
Guide Key Side
Guide Key Side
(34.50 contacts)
Unit : mm
Part No.
HRS No.
HIF6H-034PA-1.27DSA(71) 630-0176-8 71
No. of Contacts
A
B
C
D
E
F
G
34
39.84
20.32
38.24
27.64
23.84
30.48
59.64
63.45
HIF6H-040PA-1.27DSA(71) 630-0171-4 71
40
43.65
24.13
42.05
31.45
27.65
34.29
HIF6H-050PA-1.27DSA(71) 630-0172-7 71
50
50.00
30.48
48.00
37.80
34.00
40.64
68.80
HIF6H-060PA-1.27DSA(71) 630-0173-0 71
60
56.35
36.83
54.75
44.15
40.35
46.99
76.15
HIF6H-080PA-1.27DSA(71) 630-0174-2 71
80
69.05
49.53
67.45
56.85
53.05
59.69
88.85
HIF6H-100PA-1.27DSA(71) 630-0175-5 71
100
81.75
62.23
80.15
69.55
65.75
72.39 101.55
RoHS
YES
B93
BConnection Circuit Diagram
Type AA
Cable connection
A2
a2 B2
b2
An
an Bn
b1
a1 B1
A1
bn
Type AB
Cable connection
b n —1 B 2
an —1
An
B94
b 1 Bn
A2
an
bn B1
A1
a1
40, 60, 80 and 100 contacts
34, 50 contacts
Cable connection
A2
a2 B2
b2
An
an Bn
b1
a1 B1
A1
bn
Type AB
Cable connection
A2
b n —1 B 2
an —1
An
b 1 Bn
an
bn B1
A1
Type AA
a1
B95
HIF6H-100PA-1.27DS(71) 价格&库存
很抱歉,暂时无法提供与“HIF6H-100PA-1.27DS(71)”相匹配的价格&库存,您可以联系我们找货
