ACC70DKMH-S1191
ACC70DKMH-S1191
    SULLINS
    CONN EDGE DUAL FMALE 140POS .100
ACC70DKMH-S1191 数据手册
Female Card Edge .100” [2.54 mm] Contact Centers, .610” [15.49 mm] Profile, .400” [10.16 mm] Wide Body, Dip Solder/Wire Wrap/Right Angle/Card Extender for .062” or .093” Mating PCB SPECIFICATIONS READOUT • Accommodates .062” ± .008” [1.57 mm ± 0.20 mm] or .093” ± .008” [2.36 mm ± 0.20 mm] mating PCB • PPS, PBT or PA9T insulator • 3 Amps current rating for one contact energized • 30 milli Ohms maximum at rated current • UL Flammability Rating: 94V-0 DUAL (D) TERMINATION TYPE Female Card Edge L .625” [15.88] .320” [8.13] .150” [3.81] L L .200” [5.08] ACCOMMODATES .062” [1.57] PCB RIGHT ANGLE (KA, KE, KU, KJ) DIP SOLDER/WIRE WRAP (KS, KD, KM) CARD EXTENDER (KR, KN) TERMINATION TERMINATION TYPE POST LENGTH L ±.025”ʺ [0.64] FITS MIN. HOLE SIZE STANDOFF KD DIP SOLDER .160ʺ [4.06] .043ʺ [1.09] YES KS DIP SOLDER .190ʺ [4.83] .040ʺ [1.02] YES KM WIRE WRAP .560ʺ [14.22] .040ʺ [1.02] YES KA RIGHT ANGLE .100ʺ [2.54] .043ʺ [1.09] NO KE RIGHT ANGLE .180ʺ [4.57] .043ʺ [1.09] NO KU RIGHT ANGLE .250ʺ [6.35] .043ʺ [1.09] NO KJ RIGHT ANGLE .500ʺ [12.70] .043ʺ [1.09] NO KR CARD EXTENDER .235ʺ [5.97] N/A NO KN CARD EXTENDER .605ʺ [15.37] N/A NO MOUNTING STYLE Ø.125” [3.18] #4-40 Ø.125” [3.18] .250” [6.35] .245” [6.22] CLEARANCE HOLE (H) 56 THREADED INSERT (I) SIDE MOUNTING (S) NO MOUNTING EARS (N) www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com Female Card Edge .100” [2.54 mm] Contact Centers, .610” [15.49 mm] Profile, .400” [10.16 mm] Wide Body, Dip Solder/Wire Wrap/Right Angle/Card Extender for .062” or .093” Mating PCB PART NUMBER OPTIONS A B C 30 D KE H - S1191 MATERIALS (INSULATOR/CONTACT) E = PBT/Phosphor Bronze R = PPS/Phosphor Bronze G = PA9T/Phosphor Bronze H = PBT/Beryllium Copper A = PPS/Beryllium Copper J = PA9T/Beryllium Copper (Consult factory for other materials.) Refer to Page 7 for Operating/Processing Temperatures MODIFICATION CODE (Consult Factory) -S1243 = For .062” ± .008” [1.57 mm ± 0.20 mm] PCB -S1191 = For .093” ± .008” [2.36 mm ± 0.20 mm] PCB MOUNTING STYLE (Opposite Page) H = Clearance Holes I = Threaded Inserts S = Side Mounting N = No Mounting CONTACT FINISH - RoHS Compliant TERMINATION TYPE (Opposite Page) KD, KS = .025” [0.64 mm] Square Dip Solder KM = .025” [0.64 mm] Square Wire Wrap KA, KE, KU, KJ = .025” [0.64 mm] Square Right Angle KN, KR = .025” [0.64 mm] Square Card Extender All platings are Lead Free and have .000050” Nickel underplate Contact Surface Termination B = .000010” Gold .000100” Pure Tin, Matte C = .000030” Gold .000100” Pure Tin, Matte Y = .000030” Gold .000005” Gold CONTACT CENTERS C = .100” [2.54 mm] NUMBER OF CONTACT POSITIONS See Chart Below READOUT (Opposite Page) D = Dual REFER TO MOUNTING STYLE A B D E .297 [7.54] INSERTION DEPTH .250 C [6.35] .400 [10.16] .180 [4.57] .060 [1.52] .610 [15.49] .100 [2.54]TYP. F REFER TO TERMINATION TYPE .025 [0.64] SQUARE Tolerances on non-critical dimensions may very slightly due to shrinkage differential per insulator material; Consult factory. POSITIONS/ CONTACTS 04/08 05/10 06/12 07/14* 08/16 09/18 10/20 12/24 13/26* 15/30 16/32 17/34* 18/36* 20/40 22/44 24/48* 25/50 28/56* 30/60 31/62* 35/70 36/72* 40/80 43/86 44/88 49/98* 50/100 55/110 60/120* 61/122* 65/130 70/140 INCHES A±.008 0.300 0.400 0.500 0.600 0.700 0.800 0.900 1.100 1.200 1.400 1.500 1.600 1.700 1.900 2.100 2.300 2.400 2.700 2.900 3.000 3.400 3.500 3.900 4.200 4.300 4.800 4.900 5.400 5.900 6.000 6.400 6.900 B±.012 0.500 0.600 0.700 0.800 0.900 1.000 1.100 1.300 1.400 1.600 1.700 1.800 1.900 2.100 2.300 2.500 2.600 2.900 3.100 3.200 3.600 3.700 4.100 4.400 4.500 5.000 5.100 5.600 6.100 6.200 6.600 7.100 C±.015 0.660 0.760 0.860 0.960 1.060 1.160 1.260 1.460 1.560 1.760 1.860 1.960 2.060 2.260 2.460 2.660 2.760 3.060 3.260 3.360 3.760 3.860 4.260 4.560 4.660 5.160 5.260 5.760 6.260 6.360 6.760 7.260 D±.010 0.975 1.075 1.175 1.275 1.375 1.475 1.575 1.775 1.875 2.075 2.175 2.275 2.375 2.575 2.775 2.975 3.075 3.375 3.575 3.675 4.075 4.175 4.575 4.875 4.975 5.475 5.575 6.075 6.575 6.675 7.075 7.575 Female Card Edge DIMENSIONS Dimensions in [ ] are in millimeters, all others are in inches. MILLIMETERS E±.020 1.235 1.335 1.435 1.535 1.635 1.735 1.835 2.035 2.135 2.335 2.435 2.535 2.635 2.835 3.035 3.235 3.335 3.635 3.835 3.935 4.335 4.435 4.835 5.135 5.235 5.735 5.835 6.335 6.835 6.935 7.335 7.835 F±.015 0.542 0.642 0.742 0.842 0.942 1.042 1.142 1.342 1.442 1.642 1.742 1.842 1.942 2.142 2.342 2.542 2.642 2.942 3.142 3.242 3.642 3.742 4.142 4.442 4.542 5.042 5.142 5.642 6.142 6.242 6.642 7.142 A±0.20 7.62 10.16 12.70 15.24 17.78 20.32 22.86 27.94 30.48 35.56 38.10 40.64 43.18 48.26 53.34 58.42 60.96 68.58 73.66 76.20 86.36 88.90 99.06 106.68 109.22 121.92 124.46 137.16 149.86 152.40 162.56 175.26 B±0.30 12.70 15.24 17.78 20.32 22.86 25.40 27.94 33.02 35.56 40.64 43.18 45.72 48.26 53.34 58.42 63.50 66.04 73.66 78.74 81.28 91.44 93.98 104.14 111.76 114.30 127.00 129.54 142.24 154.94 157.48 167.64 180.34 C±0.38 16.76 19.30 21.84 24.38 26.92 29.46 32.00 37.08 39.62 44.70 47.24 49.78 52.32 57.40 62.48 67.56 70.10 77.72 82.80 85.34 95.50 98.04 108.20 115.82 118.36 131.06 133.60 146.30 159.00 161.54 171.70 184.40 D±0.25 24.77 27.31 29.85 32.39 34.93 37.47 40.01 45.09 47.63 52.71 55.25 57.79 60.33 65.41 70.49 75.57 78.11 85.73 90.81 93.35 103.51 106.05 116.21 123.83 126.37 139.07 141.61 154.31 167.01 169.55 179.71 192.41 E±0.51 31.37 33.91 36.45 38.99 41.53 44.07 46.61 51.69 54.23 59.31 61.85 64.39 66.93 72.01 77.09 82.17 84.71 92.33 97.41 99.95 110.11 112.65 122.81 130.43 132.97 145.67 148.21 160.91 173.61 176.15 186.31 199.01 F±0.38 13.77 16.31 18.85 21.39 23.93 26.47 29.01 34.09 36.63 41.71 44.25 46.79 49.33 54.41 59.49 64.57 67.11 74.73 79.81 82.35 92.51 95.05 105.21 112.83 115.37 128.07 130.61 143.31 156.01 158.55 168.71 181.41 * Consult factory for availability. www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 57
ACC70DKMH-S1191 价格&库存
很抱歉,暂时无法提供与“ACC70DKMH-S1191”相匹配的价格&库存,您可以联系我们找货
ACC70DKMH-S1191
  • 10+388.7116710+50.31468
