RZB92DHFR-S329
RZB92DHFR-S329
    SULLINS
    SMD
    CONN PCI CARDEDGE FEMALE 184POS
RZB92DHFR-S329 数据手册
8 7 4 5 3 2 6 .592 15.04 2.490 63.25 .500 12.70 1 ITEM NO. QTY. DESCRIPTION 1 1 B92HN-A352 2 184 EZB-DHH 3 2 BOARD LOCK 1.650 41.91 DRAWING # REF 10133 10011 10131 F F 1.550 39.37 2.400 60.96 .150 3.81 E .050 1.27 .070 1.78 E .150 3.81 5.040 128.02 .370 9.40 .015 A .300 7.62 INSERTION DEPTH .610 15.49 .550 13.97 D D A BOARD LOCK FITS .096 HOLE .570 14.48 .135 3.43 4.910 124.71 SECTION A-A 11 POSITION 49 POSITION 32 POSITION C B A C NOTES: 1. THIS SPECIFICATION COVERS THE REQUIREMENT FOR A DUAL 92/184 ROW EDGECARD CONNECTOR 2. INSULATOR MATERIAL: POLYPHENYLENE SULFIDE. (BLACK) 3. CONTACT MATERIAL: PHOSPHOR BRONZE. 4. PLATING: .00001" GOLD ON CONTACT SURFACE .0001 INCH TIN/LEAD ON TERMINAL .00005 INCH NICKEL UNDERPLATE 5. TEMPERATURE: -65 C TO 125 C 6. UL FLAMMABILITY RATING: 94V-0 7. VOLTAGE RATING: 125 VDC MINIMUM AT SEA LEVEL. 8. CURRENT RATING: 1 AMP COMPUTER 9. VOLTAGE DROP: 30 MILLI VOLT AT RATED CURRENT GENERATED DOCUMENT DO 10. INSULATION RESISTANCE: 1000 MEGA OHM NOT CHANGE MANUALLY 11. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND DATE CODE. PROPRIETARY AND CONFIDENTIAL 12. BOARD THICKNESS ACCOMMMODATED: .054/.070[1.3716/1.7780] THIS DRAWING AND DESIGN IS THE 13. BOARD INSERTION FORCE: 6 OUNCE AVERAGE PER CONTACT PAIR USING .062 [1.57]PCB PROPERTY OF SULLINS ELECTRONICS. IT MAY NOT BE USED FOR ANY 14. BOARD WITHDRAWL FORCE: 1 OUNCE MINIMUM PER CONTACT PAIR USING .062[1.57] PCB PURPOSE OTHER THAN BY THE OWNER. SULLINS ELECTRONICS DOES NOT 15. TOLERANCE: .005" UNLESS OTHERWISE NOTED. AUTHORIZE THE REPRODUCTION OR CONVEYANCE OF ANY INFORMATION 16. MODIFICATION: PCI 64 BIT, 3.3 VOLT. 92 POSITION CONNECTOR WITHOUT GUIDE POST. CONTAINED HEREIN. 8 1 1 7 6 5 4 B A REV. 120 ORIGINAL RELEASE ECO NO. DESCRIPTION UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL 1/32 ANGULAR: 1 TWO PLACE DECIMAL .02 THREE PLACE DECIMAL .005 FOUR PLACE DECIMAL .0005 DATE NAME DRAWN 1/13/04 ARIA CHECKED 1/13/04 AJT COMMENTS: USED ON APPLICATION 3 MATERIAL NOTED FINISH N/A AN AJT DATE BY APPV'D SULLINS ELECTRONICS A PART NO./DESCRIPTION: RZB92DHFR-S329 INTERPRET GEOMETRIC TOLERANCING PER: NEXT ASSY 1/13/04 SIZE DWG. NO. C REV 10134 SCALE: 2:1 DO NOT SCALE DRAWING 2 A SHEET 1 OF 1 1
RZB92DHFR-S329 价格&库存
很抱歉,暂时无法提供与“RZB92DHFR-S329”相匹配的价格&库存,您可以联系我们找货
